Old 11-03-2009, 05:55 AM   #1636
Rando
Rando's Avatar
Oddometer: 76
Originally Posted by eakins
you use full legnth or shorty neoprenes? do they sag over time. which brand?
do they collect/hold water around the fork seal area???
rman,
is there center tire clearance to drop down the brace some where it mounts?
seems to be you have about 1.5" which is more than enough. knob clearnace is the only issue & be aware the tire grows some at speed. mud will be sliced back by the brace & a rock coming around is gonna hit either way. i'd say you have 1/4 to 1/2 inch of room to drop the brace on the leg & thus provide better rain drainage. obviously the rsw brace can only go down so far then it hits that widder flanged part of fork leg.
seems like if the brace was mounted a little lower, then the factory boot lower drain holes would be low enough to drain water from the top of the fork leg/fork seal area. pooling water in this area is not good. think about trying to change out fork seals & rust down the road. i've read about this issue over at TT. it's an issue to be addressed. many smear the area around the seal/lower leg with grease, keeping the boot clamp area grease free and then clamp the boot down well. some water always pools in the frok seal cavity (& evaporates) but i think your drain hole location is causing even more to collect than normal.
if you look at the stock location for the fork boots, it down much lower on the fork leg and is clamped to the white molded plastic assy. some pooling water here will not be rusting the plastic piece.
i'd love to see some detail of a superbrace mounted. unless that design has some way for the water to drain out the bottom, it looks to be even worse as far as pooling water on the top of the lower leg.
Hey Bill, I use the full length neoprene's (Moose Racing). I have not found ANY dirt, mud or water under these things after I had them properly secured.
As far as mounting the brace lower...I think you could. Considering brand new knobbies, you may be able to lower this by a half inch or so. Again, after using SS hose clamps to secure the bottom of the boot I have not had an issue with them pulling up or letting debris in the fork slider area. If you come down from Steamboat I will show you...or I could come up in the spring and you can show me some of the area
1993 R1100RSL
2002 XR650R (Supermoto)
2000 XR400R
Rando is offline   Reply With Quote
Old 11-04-2009, 09:00 AM   #1637
Chris W
Chris W's Avatar
Oddometer: 1,152
Question Snorkel
Hi,
Any chance someone has an XR400 snorkel lying around they wouldn't mind parting with?
I got a little water in my box a couple weeks ago crossing a stream. I don't think it would have happened with the snorkel in.
Thanks.
Chris W
IBA #393
"I know I'm getting tired when I start ducking for over passes..." ~ Ardys Kellerman
Chris W is offline   Reply With Quote
Old 11-04-2009, 02:07 PM   #1638
wide
Oddometer: 391
I have seen plenty of XRs being used as dualsporters on here with baggage on the rear. But all the time I read about people saying "watch out on XRs the rear subframe is weak". Why is it that I have never seen pics of where they have broken???
Anyone here upgraded or strengthened their subframes????
wide is offline   Reply With Quote
Old 11-04-2009, 02:44 PM   #1639
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 34,051
Originally Posted by Chris W
Hi,
Thanks.
for future refference..IT'S A MOTORCYCLE, NOT A BOAT!
My Special message for y'all
DrLewall is online now   Reply With Quote
Old 11-04-2009, 03:03 PM   #1640
Hayduke OP
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,039
Tell that to Jjustj;
Underwater Rhymes from topgeek on Vimeo.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 11-04-2009, 10:28 PM   #1641
Ride38
Oddometer: 36
~So far, so good (fingers crossed).
No sign of stress fractures after about 6000 miles of constant soft "baggage" & aux rear gas tank. ~Never really exceeded more than 80lbs though.
Some of the other guys might speak up though.
Sorry for the repeat pic...how do I shrink pics down?
Ride38 screwed with this post 11-04-2009 at 10:48 PM
Ride38 is offline   Reply With Quote
Old 11-05-2009, 03:11 PM   #1642
LaOutbackTrail
Certified Smartass
LaOutbackTrail's Avatar
Oddometer: 5,058
I havent checked mine after my Mexico trip... but just be careful. A fella on the trip broke is sub frame on an XR650L.... the same model bike I replaced with the 400.
When I ever get my welder back from my brother, I am going to add gussets to my sub frame.
LaOutbackTrail is offline   Reply With Quote
Old 11-05-2009, 03:12 PM   #1643
LaOutbackTrail
Certified Smartass
Oddometer: 5,058
Great video hayduke.
Old 11-06-2009, 10:38 AM   #1644
racedawg
Have bike will travel
racedawg's Avatar
Oddometer: 269
Snorkel
Hi,
Thanks.
I have one laying around, I'm sure. P.M. me your info and I'll get it to you.
Racedawg
04 KTM 400 EXC plate /
09 KTM 950 SE
racedawg is offline   Reply With Quote
Old 11-06-2009, 01:29 PM   #1645
wvridgerider
wvridgerider's Avatar
Oddometer: 571
2000 xr 400 suspension
OK I purchased a 200 model, first bike in 18 years. Really pleased with it I need to stiff'n it up some. I weigh 255 and called Eibach, has anyone used these springs?
wvridgerider is offline   Reply With Quote
Old 11-06-2009, 06:37 PM   #1646
utopia
Oddometer: 61
This might help
http://www.4strokes.com/tech/honda/sprngrts.asp
utopia is offline   Reply With Quote
Old 11-06-2009, 09:52 PM   #1647
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,717
Originally Posted by laramie LC4
well said.
the xr is what it is, an outdated, acient design, that still keeps going. its like the energizer bunny of dirt bikes. i love mine but i dont expect much out of it. it always starts, can sit in the corner for months without issues, and in a pinch will always get me where i need to go. its my definition of a perfect back-up/community bike.
laramie
ditto....
NSFW is offline   Reply With Quote
Old 11-07-2009, 12:42 AM   #1648
PAL
Aussie ADVrider
Oddometer: 72
My XR400R
'08 Suzuki DR650
'09 Honda XL1000V Varadero
PAL is offline   Reply With Quote
Old 11-07-2009, 06:26 AM   #1649
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 34,051
you guys and your "pretty" XRs..y'all need to get em in the dirt once in a while and ride em insted of "polishin" them up!
Old 11-07-2009, 07:16 AM   #1650
Ride38
Oddometer: 36
Fork Guards
Hah, true-dat DrLewall!
I'm seeing folks have fork guards. I've been looking arounnd everywhere online but they all seem discontinued.
Anyone know of a pair of Acerbis laying around?
Times are GMT -7.   It's 06:44 AM.
