Old 12-09-2009, 05:35 AM   #1726
Bentley
Wannabe Adventurer
Bentley's Avatar
Oddometer: 234
Originally Posted by Rman237
I didn't think the stock stator would put out enough juice for the road so I stand corrected. I went the Baja Designs kit route which came with the battery...etc.. I'll give you one thing, that headlight is real, real bright on the high beam!!........
http://www.bajadesigns.com/
Where ya at Bentley? You ever ride Cross Creek or Cherokee?
You are probably right about not enough juice "for the road." As jet33 noted, hit the brakes (or the horn), and the lights will dim!
I have not ridden Cross Creek. We ride City Park a lot, as well as Hidden Falls (used to be Boulder Creek). I have ridden at CTOR and Cherokee as well.
Cheers,
Ben
'98 BMW 1100GS
'99 Honda XR400R
He's got everything he wants, a girl, a drink, a song,
If we use his formula, we surely can't go wrong.
from the song "Mexican Joe" by Jim Reeves
Bentley is offline   Reply With Quote
Old 12-09-2009, 09:30 AM   #1727
jet123
Using all my gears
jet123's Avatar
Oddometer: 4,053
I agree with 2old2race...
But if you gotta ride the roads a good amount, rebuild the seat
John
http://rerax.net/index.html
jet123 is offline   Reply With Quote
Old 12-09-2009, 01:41 PM   #1728
Luke
GPoET&P
Luke's Avatar
Oddometer: 3,778
Originally Posted by maskmarney
Hi, I'm looking to buy a XR400 in the spring, and I'm wondering how the engine handles highway miles. I live in SF, CA, and in order to get to some of the places I want to ride(the Mendocino National Forest, for example), I'll need to ride an hour or two on the freeway before taking the country roads and fire roads that I intend to explore. Would this a) be too uncomfortable or b) tax the engine too much to be practicable? Would it simply be better to haul the bike in a truck for a few hours, and then ride it( I do not, however, own a truck)?
I used to ride Mendocino NF from Santa Rosa. It's a long ride on any little bike. Among the bikes that you would want to ride on the trails there, the XR is among the best.
Put some weights on the wheels to balance the rim locks, buy a nice seat, put a little windscreen on it and it will be much better. The same goes for any little bike.
Even then, especially from SF, I'd rent a truck for a day ride. 2.5 hours up, 4 hours of trail riding, 2.5 hours back is a long day. Especially if the last hour is cold, dark, through Marin traffic. For a full weekend, sure, ride up one day, hotel/camp one night and ride back the next day.
I put a lot of highway miles on my XR, and it blew up recently, probably from oil starvation. I don't know if that's a coincidence or not. FWIW the transmission and bottom end were in perfect condition.
If you're sure you just want to ride the fire roads, then a bigger bike would be fine, but the thought of taking anything over 300# on the single track up there makes my joints twitch.
Luke is offline   Reply With Quote
Old 12-09-2009, 06:42 PM   #1729
SwitchThrottle
Bring da amber lamps
SwitchThrottle's Avatar
Oddometer: 1,046
I don't remember where I saw it, but swap to a 14/42 and get a case saver. Swap the 15 on when you will be doing slab work, and bring the 14 with you (along with the wrenches you need to swap). When you get to the trail, swap the 14 back on and ride until you need to slab it home, then swap the 15 back on. You could get two cheap wrenches and cut-n-weld a custom CS/axle nut wrench to save weight. That should help the motor longevity.
2008 Husky sm450r (12k+ miles)
2003 Honda xr400r (street titled) For sale, but not posted anywhere.
Riding a motorcycle is fun. Riding a supermoto is inexplicable.
SwitchThrottle is offline   Reply With Quote
Old 12-09-2009, 06:46 PM   #1730
Hayduke OP
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 41,791
It's just 2 10mm bolts to change the c/s sprocket. I used to do this all the time... carried a 13, a 14, and a 15 tooth cs sprocket with me.
Hayduke is offline   Reply With Quote
Old 12-09-2009, 06:53 PM   #1731
SwitchThrottle
Oddometer: 1,046
True, but you still need to adjust the chain when you swap.
Old 12-09-2009, 06:57 PM   #1732
Hayduke OP
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 41,791
Yep. I could do the whole process in less than 5 min. (mommer timed me. )
Had a small 10 mm ratchet and a axle nut wrench at the ready.
I really liked the chain adjusters on the xr400
Old 12-11-2009, 02:53 AM   #1733
wide
Oddometer: 374
Exactly what I do. The ol girl runs at 55/65 mph (gps) with the 15/42 bung a 14 or 13 on while Im taking a break and away she goes pulling everywhere
wide is online now   Reply With Quote
Old 12-11-2009, 06:00 AM   #1734
r00t4rd3d
ADV Rider
r00t4rd3d's Avatar
Oddometer: 895
Send a message via MSN to r00t4rd3d
Originally Posted by LaOutbackTrail
The foam progressively made the bike do exactly as you were describing, more throttle, less umph. Take the foam off and tryer-out.
I dont think that is a good idea. My buddy put a nylon over his snorkel on his ATV and it ran fine with it on there for a couple days then it got clogged with dirt and it wouldnt run right.
r00t4rd3d is offline   Reply With Quote
Old 12-11-2009, 06:09 AM   #1735
Svart
...is swedish for black
Oddometer: 302
Sounds like it was time to clean the nylon...
The dirty foam in the picture was used as a pre-filter, to keep the real air filter from getting all clogged up by large items. Bug, twigs and the occational squirrel will stay out of the airbox :)
I´m planning to open up my airbox and put a pre-filter there instead. Recently pulled the snorkel and the PO must have had the carb jetted for no snorkel, bike runs better now.
- More than one cylinder? Then you need more than one bike! -
I used to be Honda but now I´m better
Svart is offline   Reply With Quote
Old 12-11-2009, 06:13 AM   #1736
Svart
Oddometer: 302
It just hit me...: dirty nylons. Perfect for my sence of humor :)
Have you pulled the exhaust manifold to have a look at the welds on the inside, just at the beginning of each pipe? At least a third of my pipes were not open so I went at it with a dremel for a while. Got it a bit better, didn´t want to remove all of it in case the weld actually does something besides clog up my exhaust.
Didn´t feel any big difference though.
Old 12-11-2009, 06:15 PM   #1737
DrLewall
DrLewall's Avatar
Oddometer: 24,205
XR400 swingarm bolt
update..you can find my write up here..short story, the sawzall cut the swing arm out!
DrLewall is offline   Reply With Quote
Old 12-11-2009, 07:18 PM   #1738
jet123
Using all my gears
jet123's Avatar
Oddometer: 4,053
I'm sure that will buff right out
Seriously, that sucks!
John
Old 12-11-2009, 07:20 PM   #1739
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,096
its a honda xr, whats the problem? i thought that was how they did it OEM....
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 12-11-2009, 07:40 PM   #1740
jet123
Using all my gears
jet123's Avatar
Oddometer: 4,053
I actually need to check mine so I added it to my winter 'to-do' list.
John
Times are GMT -7.   It's 03:16 AM.
