Old 05-22-2011, 06:53 PM   #3421
grub
Requires Supervision
grub's Avatar
Oddometer: 2,215
Originally Posted by Brewster View Post
NOS 2002 XR400 I picked up a few weeks ago. Just got her plated for dual sport duty.
Nice find, that bike looks like it has never been ridden...
'05 KTM 300 EXC - 1996 BMW R1100GS
grub is offline   Reply With Quote
Old 05-22-2011, 07:04 PM   #3422
Brewster
Brewster's Avatar
Oddometer: 43
It might have an hour or so on it. The engine still smells new when you fire her up. I just got finished uncorking her and got her plated.
She really runs nice.
Brewster
Brewster screwed with this post 06-23-2012 at 10:15 PM
Brewster is offline   Reply With Quote
Old 05-23-2011, 05:20 AM   #3423
Ed@Ford
Oddometer: 1,662
I sure would like to know how you boys find almost new XR400's....my 96 is developing issues.
The swing arm bolt seems to be rusted in place.. The ugly task of repairing has been documented here. Mine is laying on it's left side and I go out and shoot penetrating oil in the pocket where the swing arm nut was....oil seems to disappear quickly....but no puddles anywhere of it coming out. Gonna continue this for a week. (Riding the KLR in the mean time). Maybe hit it with the impact after some more soaking. Soooo...questions are....the swing arm bolt is not threaded into the RH side if the frame...right?...just a slip fit..right? Also, it would seem that if necessary, since the SA bolt is hollow, by drilling successively larger bits, you could drill away both ends of the bolt, and the SA might possibly fall out...right?
Ed@Ford is offline   Reply With Quote
Old 05-23-2011, 06:36 AM   #3424
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,951
SA bolt not threaded into the other side..just a push thru with a nut on the other end..GOOD LUCK! (from someone who knows and has the pix to prove it!)
DrLewall is offline   Reply With Quote
Old 05-23-2011, 06:42 AM   #3425
Ed@Ford
Oddometer: 1,662
Thanks...rode over the weekend....there's nothing...in my opinion...out there to replace it with...except another one..and I can always dream about the 440 model with electric start that they actually sell in Italy!!
Old 05-23-2011, 06:51 AM   #3426
huckleberry
BACK ROAD BOMBER
huckleberry's Avatar
Oddometer: 1,106
Would like to join this forum----anyone know where i can find a nice xr4 in the northeast?
“An adventure is misery and discomfort, relived in the safety of reminiscence.” Marco Polo
09 F 650 GS twin
XR 400
Beta Techno
huckleberry is offline   Reply With Quote
Old 05-23-2011, 06:54 AM   #3427
huckleberry
BACK ROAD BOMBER
Oddometer: 1,106
praytell where did you get this and can i get 1?
09 F 650 GS twin
XR 400
Beta Techno
Old 05-23-2011, 10:38 AM   #3428
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,228
Originally Posted by Ed@Ford View Post
.... Maybe hit it with the impact after some more soaking. Soooo...questions are....the swing arm bolt is not threaded into the RH side if the frame...right?...just a slip fit..right? Also, it would seem that if necessary, since the SA bolt is hollow, by drilling successively larger bits, you could drill away both ends of the bolt, and the SA might possibly fall out...right?
I assume you mean an impact wrench? That won't help much as the main culprits are the swingarm bearings. When you turn the bolt they will just turn freely with it. Turning the bolt does help free it from the engine cases.
Impact -in the form of a big hammer- is your best starting point.
To drill it out you will need to go in around 3 inches on either side to get past the swingarm bearings.
Luke is online now   Reply With Quote
Old 05-23-2011, 11:15 AM   #3429
Gap-year-trip-2010
Oddometer: 1
New entry!!!!
Ive just got an XR400!!! Yay.
2003 Crf250f Front end.
Improved rear fender.
Mikuni 42mm Carb (awesome!)
Michelin T63's (front is sh... off the road)
XR400
rear side.
DSCF5711
Hope the thread entry works.
Gap-year-trip-2010 is offline   Reply With Quote
Old 05-23-2011, 01:46 PM   #3430
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,421
Ok, who's got the skinny on how to upgrade the ol' xr400r to USD forks? i know several of you have done it. let's hear the details, or at least a link to somewhere that does.
i want to know...
1) what forks you used
2) triple clamps
3) axle used
4) brake caliper
5) stem bearings used
6) what front wheel
thanks,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 05-23-2011, 05:56 PM   #3431
Brewster
Brewster's Avatar
Oddometer: 43
I bought it locally from a private party in Phoenix. I pretty much watched craigs list and ebay daily looking for a NOS 400. They are out there but you've got to be quick to act.
Keep looking and be patient.
Cheers,
Brewster
Old 05-23-2011, 05:58 PM   #3432
Brewster
Brewster's Avatar
Oddometer: 43
I have a nice 2001 in the Southwest.
Its in the classifieds over on TT, how about a road trip?
Brewster
Brewster screwed with this post 05-23-2011 at 09:42 PM
Old 05-23-2011, 10:02 PM   #3433
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,228
i want to know...
2) triple clamps
3) axle used
4) brake caliper
6) what front wheel
thanks,
laramie
Mine:
'09 CRF450R front end.
Forks, axle, wheel, brake, triples, stem all from the CRF.
The head bearings and steering stem nuts are XR stock, the stem was machined to fit the XR nuts, but it's length wasn't changed, so the CRF top nut was re-used on the bottom as a spacer.
The castle nut is from the XR, the hex nut is from the CRF.
If I were to do it again I would go with the All-Balls conversion bearings and a spacer.
I had to mill the steering stops off the lower triple clamp to clear the oil cooler and make new ones in the right place for the XR. These were my first attempt. The HDPE wasn't strong enough and I made another set from aluminum.
The XR fender was a direct bolt-on. The brake caliper mounted differently to the fork, so I had to get a new caliper. The hydraulics are identical, the only difference is the carrier bracket. The '02-'07 CRF uses the same caliper bracket as the XR
The steering range sucked because the lower clamp bolts interfere with the gas tank, so I took a heat gun and trailer hitch ball to the tank. It's now almost as good as the stock XR.
In case you need encouragement, I've done most of the big upgrades for my XR and this one was the best.
Old 05-24-2011, 12:07 AM   #3434
huckleberry
BACK ROAD BOMBER
Oddometer: 1,106
can someone fill me in on the pumper carb? Is it really that much better than the stocker?
09 F 650 GS twin
XR 400
Beta Techno
Old 05-24-2011, 09:30 AM   #3435
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,228
I thought the improvement was modest. The difference between a properly jetted stock carb and the mikuni pumper was much less than the difference between stock jetting and correct jetting on the stocker.
Times are GMT -7.   It's 09:05 PM.
