Old 05-30-2011, 03:49 PM   #3481
huckleberry
BACK ROAD BOMBER
huckleberry's Avatar
Oddometer: 1,106
was hopeing some one could tell me if the pivit works brgs are as good as stock stuff. I need some wheel brgs and shock brgs and the pivit works stuff is less expensive.
“An adventure is misery and discomfort, relived in the safety of reminiscence.” Marco Polo
09 F 650 GS twin
XR 400
Beta Techno
huckleberry is offline   Reply With Quote
Old 05-30-2011, 03:58 PM   #3482
Switchblade315
Switchblade315's Avatar
Oddometer: 5,634
I've used them with no problems. would defently use them again.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 05-30-2011, 04:14 PM   #3483
booger1
booger1's Avatar
Oddometer: 878
I've got the pivot works and all balls bearings throughout the bike. Can't tell a differance, only time well do that. they've been on the bike for about 1 1/2 years so far. Pivot bearings in the linkage for about 3 years now.
Eating_goat_with_the_Cartel , Never_ventured_never_gained
oncostaricantime , boundlessbooger , 1998xr400buildwithe-start
Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain
booger1 is offline   Reply With Quote
Old 05-31-2011, 08:13 PM   #3484
grub
Requires Supervision
grub's Avatar
Oddometer: 2,214
Hey guys, I'm still looking for a stock tank. If anybody has a decent take-off sitting in the garage please PM me.
'05 KTM 300 EXC - 1996 BMW R1100GS
grub is offline   Reply With Quote
Old 05-31-2011, 08:59 PM   #3485
J. Quest
Oddometer: 25
Craigslist
Check the Denver, Boulder, or Ft. Collins Craigslist.
I'm pretty sure I seen one on there today.
Edit: Here's the link: http://denver.craigslist.org/mcy/2412552503.html
2004 XR400R
J. Quest screwed with this post 05-31-2011 at 09:02 PM Reason: Add Link
J. Quest is offline   Reply With Quote
Old 06-01-2011, 04:47 PM   #3486
Brewster
Brewster's Avatar
Oddometer: 43
There is a nice White one over on TT right now.
Brewster
Brewster is offline   Reply With Quote
Old 06-01-2011, 08:30 PM   #3487
grub
grub's Avatar
Oddometer: 2,214
Thanks, for the help. Found just what I was looking for.
Old 06-02-2011, 06:15 PM   #3488
grub
grub's Avatar
Oddometer: 2,214
Installed the revloc dynaring last friday night, played with the adjustment on Saturday for a couple of hours and rode 40 miles of trails on Sunday.
I think autoclutch is the wrong way to describe it, for you old schoolers like me think of it like a torque converter - so much nicer and smoother in the rocks. If you don't ride trails you don't need it but boy does it shine in the tight, steep and nasty.
Old 06-05-2011, 09:53 AM   #3489
Davidjohnson
Oddometer: 78
Jetting for Colorado
Still need some help from the Colorado'ans
What main and what pilot is a good all around Colorado set-up? Ride primarily Taylor Park, CB area. The bike is a '98 which is the year the factory set-up was 142 and 52. It currently has a 145 main in it. Not sure about the pilot since I have not pulled the bowl off yet. Bike is currently jetted for sea-level. Only modifications the previous owner was aware of is removed snorkel, added uni filter, and he said it has an XR250 spark arrestor (the chrome insert). He said the XR250 insert (not sure which year) had a larger opening than the '98 and later 400s and that was a common mod. You guys ever heard of that? Anyway, the bike is basically stock.
The mtc book gives a correction of.92 for 6500 ft and 85 degrees F., that would make for a 133 main. The book says turn in the pilot 1/4 turn for corrections greater than .95. What do ya'll think? What's the best recipe
for this '98 model?
David Johnson
Davidjohnson is offline   Reply With Quote
Old 06-06-2011, 07:26 AM   #3490
KrAzyOSUcOwBoY
kRaZy
Oddometer: 126
DJ, the go to jetting for a stock carbed XR4 @ sea level is 160/60, although mine has been Mikuni'd for a long time, I would suggest 150/55 as a starting point for that alt, fuel screw as needed, prob around 1.5 to 2 turns out. Others with Co/NM experience will probably chime in. Good luck.
KrAzyOSUcOwBoY is offline   Reply With Quote
Old 06-06-2011, 10:02 AM   #3491
nw scout
Oddometer: 758
Just picked up a 02 XR400R, plated with a baja kit and big tank
Problem is, it is running a bit rough and idle's kinda weird.
Any XR gurus out there have a few minutes to talk and give me a few hints at troubleshooting?
Thanks in advance
Dave
503-706-4487
nw scout is offline   Reply With Quote
Old 06-06-2011, 11:16 AM   #3492
Davidjohnson
Oddometer: 78
jetting
"DJ, the go to jetting for a stock carbed XR4 @ sea level is 160/60, although mine has been Mikuni'd for a long time, I would suggest 150/55 as a starting point for that alt, fuel screw as needed, prob around 1.5 to 2 turns out. Others with Co/NM experience will probably chime in. Good luck."
Can someone help me with why the 97 and earlier bikes had larger jets than the post 97? My 98 came from the factory with a 142 main and I believe the 97 came from the factory with a 155 ?. My 98 is currently jetted with a 145 and seems spot on for sea level; thats a far cry from a 160. Sorry for the rant, I'm just trying to understand the baseline differences.
David
David Johnson
Old 06-06-2011, 11:30 AM   #3493
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,184
David
I suspect is was emissions: both noise and smog. Semi-educated guess: '98 was the first year that CA had smog rules for dirt bikes. There may have been some federal things too. The stock 97 jetting was 162/62, which was a tiny bit rich. This was done (according to the manual) so that the owner would get the best power after pulling the exhaust baffle and intake snorkel without rejetting. For '98+, the exhaust baffle was fixed, so smaller jets would be appropriate. The unbaffled '97 exhaust wouldn't pass sound check in CA so they made the baffle non-removeable ( I don't know about the national rules at the time, but it won't pass current USFS levels)
Luke is offline   Reply With Quote
Old 06-09-2011, 11:19 AM   #3494
yosso
yosso's Avatar
Oddometer: 975
Price check on aisle 4...
1998 XR400R - Clean, already tagged in Arkansas. Seat is intact, but the tank was painted black and is peeling. Also needs a rear tire and a mirror.
Needs some work on the headlight wiring, but all the parts and pieces are in place, except for a mirror.
He's asking $1800.00. Good price?
http://fayar.craigslist.org/mcd/2427868949.html
Thanks.
Mike
Honda ST1300/2000 Suzuki DRZ400E/Ducati 750 Monster re-work Blog
yosso is offline   Reply With Quote
Old 06-09-2011, 03:38 PM   #3495
Trailryder42
Trailryder42's Avatar
Oddometer: 1,061
for this '98 model?
If you jet it for 6500 ft. you're still going to be rich for Taylor Park. I would be jetting it for at least 9-10k.
Yes, what you heard about the XR250 exhaust insert is true.
If the main jet is currently a 145, with all the airbox, air filter and exhaust mods, it IS NOT jetted for sea level. If it was jetted properly for sea level it would have closer to a 160.
For the elevations of Taylor Park and Crested Butte, given the intake and exhaust mods, drop in a 150/50 combo, drop the needle to 2nd clip position from top.
'00 XR440
'04 KLR650
'09 Wee Strom
COHVCO
USA-ALL
BRC
Trailryder42 is offline   Reply With Quote
Times are GMT -7.   It's 02:53 AM.
