Old 06-22-2011, 07:52 PM   #3526
Tukata
ADV Demo Rider
Tukata's Avatar
Oddometer: 1,460
Anyone have a Wet weight for an E-START 400 conversion....
Doing some math in my head. Preferably:
Bash plate
Pipe
Bark Busters
Stock tank
Just trying to get close
Yes, I'd love to try
What ever happens to be in the stable at the current time.
H-ADV in fabrication
Tukata is offline   Reply With Quote
Old 06-22-2011, 08:00 PM   #3527
AwfulRider
Rubber side up?
AwfulRider's Avatar
Oddometer: 20
Bash plate
Pipe
Bark Busters
Stock tank
I don't know what mine weighs, but it sure is awesome!
AwfulRider is offline   Reply With Quote
Old 06-22-2011, 08:11 PM   #3528
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,895
a museum piece? Way too clean to be a dirt bike!
DrLewall is offline   Reply With Quote
Old 06-23-2011, 01:17 AM   #3529
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,158
Bash plate
Pipe
Bark Busters
Stock tank
Mine's 290 on a bathroom scale, almost full of gas with some mud on it. Weighty mods are: CRF forks, bash plate, e-start, handguards, Michelin S12 tires.
Gotta show it off:
Yeah, I ain't too light either.
I didn't notice the extra weight of any of the mods. What I did notice was the extra width of the left side engine case. Both foot position and clearance around tight rocks and stumps are degraded.
Luke is offline   Reply With Quote
Old 06-23-2011, 01:27 PM   #3530
birds
birds's Avatar
Oddometer: 249
I recently picked up an old devol racing bash plate. Can someone who has one post some pictures or hints on how to mount it? The back is pretty clear, but I don't get the triangular piece in the front.
birds is offline   Reply With Quote
Old 06-23-2011, 02:18 PM   #3531
farrington300
No wait....What?
farrington300's Avatar
Oddometer: 518
Love the pic Luke. I read your two noobs racing thread. Good Stuff.
Gotta show it off:
TE610
TLR200
farrington300 is offline   Reply With Quote
Old 06-25-2011, 12:42 AM   #3532
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,158
I stuck with a local thread in the Pac Norwet forum to try to get a few people to try racing. It's sort of working.
Just for practice I went out to an MX track the other day (my first time on one), and the XR managed it. For one session I traded for a KTM 200, and found out that I can't blame the bike for being slow. On the upside, it was pretty good treatment for the new bike lust I've been having recently.
Old 06-25-2011, 05:14 PM   #3533
huckleberry
BACK ROAD BOMBER
huckleberry's Avatar
Oddometer: 1,106
well had the xr out for 50 miles of quad trails today, what a fun bike! This has to be the best trail bike ever! My 450exc was more powerful and faster but this is just more fun and i don't seem to mind slowing down a little on it. So to my question, what is every one running for sag riding a lot of rocks, from babyheads to 1 foot steps there is a lot of this type of trail near me so i'm hoping to hear some other views.
“An adventure is misery and discomfort, relived in the safety of reminiscence.” Marco Polo
09 F 650 GS twin
XR 400
Beta Techno
huckleberry is offline   Reply With Quote
Old 06-27-2011, 08:27 AM   #3534
Abominable
Oddometer: 14
First Start After Rebuild
Guys, I've completed (hopefully) my full engine rebuild, and am back together except for brakes and wheels. I'll be trying to start the beast likely some time this week. Any advice for the first startup? Do I need to prime any parts of the oiling system or just fill up the frame? Thanks
Abominable is offline   Reply With Quote
Old 06-27-2011, 09:37 AM   #3535
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,158
I use standard sag settings. I'd suggest checking your weight against a spring chart. You could likely use stiffer fork springs. These help a lot for stepped downhills; they keep the front end from collapsing on bumps. You can also take out a few of the damping shims in the front forks. That'll make the front track better over rocks instead of deflecting to the side, and the ride will be more comfortable. Put the shims back in for riding wide-open desert. Like those big sand dunes near Allentown.
Old 06-27-2011, 09:50 AM   #3536
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,158
I did, and it certainly didn't hurt anything. There are a bunch of oil passages between the oil pumps and the places that get oiled, so I figured that filling them with oil would be good.
Advice from the local machinist, which I also followed: turn the motor over by hand using non-ratchet wrench and socket on the flywheel bolt. While doing this, listen and feel for piston-valve contact. By doing it this way, you won't bend the valves if they touch the piston and you can fix them easily. If you use the kickstarter (or e-start) the valves will bend when they hit the piston.
Once you've confirmed that the valve timing is correct, then use the kickstarter to turn the motor to get the oil where it belongs.
Old 06-27-2011, 11:06 AM   #3537
Abominable
Oddometer: 14
Thanks Luke,
I'm confident that that timing is in the correct phase. And I've rotated the engine over a few times on the kick-starter and all appears well. I'm concerned about the lack of initial lubrication and the delay in the oil pump filling up all the lines, cooler, and filter housing before getting to the vital parts. All the parts were pre-lubed as specified during assembly, but I'm worried that the pump will take a long time to clear the system of air. Thoughts?
Old 06-27-2011, 11:50 AM   #3538
farrington300
No wait....What?
Oddometer: 518
Thanks Luke,
Correct me if im wrong, but wouldnt kicking the bike slowly a bunch of times push oil through the system? Afterall when you turn the engine, the oil pump turns, right?
Thats what I did on my rebuild, bike seems to be running fine.
TE610
TLR200
Old 06-27-2011, 11:56 AM   #3539
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,895
yes..remove the spark plug and maybe kick or pump it abt 30 times should do it...be sure you HAVE OIL IN THE TANK!!!
Old 06-27-2011, 11:57 AM   #3540
Abominable
Oddometer: 14
I think so. So that is what I'm going with. However I'm a bit paranoid about it. I think the pump would have to be running at a fairly high speed to achieve enough pressure to reach the whole system. I'm concerned that the slow action of the kick starter might not do it. I'm glad to hear it worked for you. Did the bike start right up, or did you have any troubles?
Times are GMT -7.   It's 11:06 PM.
