Old 11-16-2011, 03:59 PM   #3931
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,595
I have me an extra 440 motor sitting in a basket and when I go to rebuild, I too will go 416...much more reliable!! Love my 440, but I think the 416 will do just fine!
DrLewall is offline   Reply With Quote
Old 11-16-2011, 07:10 PM   #3932
wvridgerider
wvridgerider's Avatar
Oddometer: 578
I had my cylinder bored and went the first oversize last year, Weisco piston. The bike starts on one kick and runs great. I believe it is a 11.5:1 piston.
wvridgerider is offline   Reply With Quote
Old 11-16-2011, 09:01 PM   #3933
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Do you have a license plate on the XR of yours? I have been wanting to ride with some WV guys. I moved to NC 4 years ago and am kinda nervous about riding anywhere without a guide due to all of the land postings and closures.
I am trying to gather some contact info for fellow ADVers that are in WV. PM me contact info if that sounds good.
bobbed06 is offline   Reply With Quote
Old 11-17-2011, 01:50 PM   #3934
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,411
finally some good news. i got the valves out and honestly, other than being a little dirty, they look really good. i think i'm going to take a wire wheel to them, clean the combustion chamber, and put it back together. now i just got to order the 416 kit and send off my cylinder.
thanks for the help guys,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 11-17-2011, 01:56 PM   #3935
bobbed06
Oddometer: 1,236
laramie
That will save you 120 bux on valves, but wait until you get new valve seals before you reinstall them in the head. They will come with the gasket set. Surely the old ones have hardened and will cause smoking/oil burning issues.
Old 11-17-2011, 02:02 PM   #3936
wvridgerider
Oddometer: 578
Mine is plated, there are a lot of WV riders on the regional foums, wvdualsport. I ride closer to whee I live, but the gravel roads are everywhere and some roadsthat you would think are just trails. A lot ride at Campbells Creek and the trails are endless from what i here. If you are in the area, near Charleston I would gladly show you around Putnam, Mason Counties.
Old 11-17-2011, 04:47 PM   #3937
huckleberry
BACK ROAD BOMBER
huckleberry's Avatar
Oddometer: 1,106
Ride in W Va. check this out tons of fun for everyone http://www.trailsheaven.com/default.aspx
“An adventure is misery and discomfort, relived in the safety of reminiscence.” Marco Polo
09 F 650 GS twin
XR 400
Beta Techno
huckleberry is offline   Reply With Quote
Old 11-17-2011, 10:00 PM   #3938
bobbed06
Oddometer: 1,236
PM sent, I will catch up with you as soon as my DRZ is done. I am only a headlight and dashboard away from completion. That is definitely the area I am interested in riding since I am originally from the Morgantown area a few hours North. I rarely ever rode on the Southern part of the state mainly because I didnt know anybody there. I appreciate the hospitality.
Old 11-17-2011, 10:01 PM   #3939
bobbed06
Oddometer: 1,236
Bookmarked ! Thanks Huckleberry.
Old 11-18-2011, 05:42 AM   #3940
dazkarieh
Oddometer: 13
XR fRUSTRATING
At any time does your xr 400 goes off when you ride a little with your clutch handle pressed? Imagine, your riding and you just let it slow down, pressing the clutch without reving the engine and the engine goes off?
My bike does that. Everyone says that is not a bike for going slow. that you have to go all the time with locked throtle. In that mode she's awesome. But when i come to a intersection and i stop, if i give a twist of the throtle fast the rev goes up, then down til it turns off imediattealy.. Carburator, filter, spark plug, everything is working and clean and revisioned. Im selling the bike.. ;/
dazkarieh is offline   Reply With Quote
Old 11-18-2011, 07:02 AM   #3941
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,181
Going fast or slow, it shouldn't cut off like that. Sounds like the carb.
Look at the second half of this video, the 400 is going slow, zero problems.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 11-18-2011, 08:50 AM   #3942
birds
birds's Avatar
Oddometer: 249
Yeah. My bike did that when I had carb issues (air leaks in my case)
Sent from my C771 using Tapatalk
birds is online now   Reply With Quote
Old 11-18-2011, 09:54 AM   #3943
Switchblade315
Switchblade315's Avatar
Oddometer: 5,700
defently sounds like it had a air leak.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 11-18-2011, 11:16 AM   #3944
dazkarieh
Oddometer: 13
It is not the carb. The carb has been dissassembled, cleaned, even some springs replaced because the throtle didnt come back to his original position when twisted on. it slowly comes back.. not now. now its fast. The carb is also in great shape and its the original stock one. :/
Old 11-18-2011, 03:07 PM   #3945
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,181
You can check for a tight valve but aside from that possability you're back to a fuel/air (carb, air leak, etc...) situation. Airleak is an easy check, I use an unlit propane torch pointed at the carb and manifold junctions. If it revs a little there's a leak.
As you probably know, 3 things are required, compression, fuel and ignition. The ignition isn't going to cause the symptoms you described and still kickstart, compression is basically there or it isn't and if it was that bad to cause stalling at low RPM the bike would be very hard to start too. That leaves fuel. You say the carb is correct, if it isn't the symptoms you describe are easily possible.
Did the bike sit a long time, I've never seen a return spring wear out and I've worked on quite a few? You're saying the carb is correct, that means the float level, jetting are verified correct, that the o-ring/spring/washer isn't missing on the fuel mixture screw and it's set correctly and all passages have been verified to be clean? If that's been done correctly then I agree your carb is probably good but that symptoms still sound like fuel air problem.
Chris
Times are GMT -7.   It's 02:23 PM.
