03-21-2012, 03:53 PM
#4366 |
Oddometer: 3,248
Sorry had to go look at it again. I was picturing one of my other bikes front end in my head.
When i die bury me upside down so the whole world can kiss my ass. |
03-22-2012, 06:11 AM
#4367 | |
Oddometer: 2,424
03-22-2012, 07:31 AM
#4368 |
Rift- Raft, SCooter Trash
Oddometer: 800
CAn't take it off
Barrel nut will not pass thru the axel.Could remove and mount wheel in vise but effect will be same as taking a pipe wrench :(
Thanks for the suggestions guys. I will attack it tomorrow.
Cbig |
03-22-2012, 08:37 AM
#4369 |
Oddometer: 94
Tank leak
So I just discovered a slow leak in my brand new Clarke tank, almost seepage really. It's just where the petcock joins the plastic of the tank.
Is this a known problem with a known fix? Maybe I'm just being lazy for asking without trying anything...but any suggestions?
'04 Honda XR 400 | '08 Royal Enfield 500 Himalayan Ride Report 1997 | Ladakh again (2012) |
03-22-2012, 09:45 AM
#4370 |
Oddometer: 299
The O-ring is worn on your Clarke. Just remove the petcock via the 8mm bolts and you'll likely find pieces of it falling out. I had a hell of a time finding a thick enough replacement that would be safe in gas. Never did actually so I made my own.
07 450EXC |
03-22-2012, 09:51 AM
#4371 | |
Oddometer: 94
Hey thanks, that was quick. Will give a proper look this weekend and see...
03-24-2012, 02:36 PM
#4372 |
Oddometer: 299
Good news and bad news. Pulled my cylinder head b/c I think my valve guide seals are worn causing my 4-hundy to smoke for the 1st 30 seconds when I start it up. Figured as long as I'm in there I wanna mic everything out and make sure that's the only thing that needs replacing. Turns out my 1996 still has the original bore and piston
It's 0.003" from the service limit so guess it's time. Damn XR's...who gets 16 years out of a piston, seriously? What's a bore job run these days?
07 450EXC |
03-24-2012, 04:23 PM
#4373 | |
Oddometer: 1,051
But I love my 440....would never settle for less....probably cost me $500....but while the head is off...you need guides, valve stem seals and a multi angle valve job...another $200or so....but as long as you can get out the swing arm pivot bolt...repair your '96...run it for 10 more years!! |
03-24-2012, 06:36 PM
#4374 | |
Cavalera Conspirator
Oddometer: 956
03-24-2012, 10:33 PM
#4375 |
Oddometer: 299
My swingarm pivot bolt will come out no problem - when I cut off my swingarm.
Thanks for the offer but no, a stock piston won't work, my cylinder is too far gone. Unfortunately everything is turning out to be right at the wear limits so my quick and cheap rebuild is getting more expensive. Don't have the money to upgrade so probably gonna have to OEM a lot of it. Oh well if OEM lasted this long, do I really need to upgrade?
07 450EXC |
03-25-2012, 06:16 AM
#4376 |
Ride Rural Texas
Oddometer: 426
GoPro vid from yesterday, me and a friend riding gravel roads around Fayetteville, TX.
http://www.youtube.com/watch?v=HUj19w3Gzas
'06 TW200 Mountain Goat '06 XR650L Sumo '98 XR440R trick and plated '98 KDX220 plated '84 RZ350 '83 XR350R '83 XR200R '84 ATC125 |
03-25-2012, 07:32 AM
#4377 | |
Oddometer: 956
03-25-2012, 11:13 AM
#4378 |
Oddometer: 299
Higher compression makes the engine run hotter and is harder on the bottom end, especially the conrod. I'm stuck at stop lights enough that I don't need anything that will increase my running temps.
I've built up a few engines but TBH I'm pretty happy with the power my XR has for what I use it for. It's my putt-putt, go exploring bike. I've never had to turn around because the bike couldn't make it. A 6th gear would be nice though.
07 450EXC Wallrat screwed with this post 03-25-2012 at 11:20 AM |
03-27-2012, 02:49 AM
#4379 |
Oddometer: 60
hello, love the thread, was wondering if anyone has rebuilt the rear shock? Or is it something better left to a shop?
Thanks |
03-27-2012, 11:17 AM
#4380 |
GPoET&P
Oddometer: 3,760
