Old 06-28-2012, 10:14 AM   #4681
G600
Oddometer: 462
Originally Posted by SuperTimmy View Post
Hello everyone!
First time posting on here. I have been reading this thread for about a two months-about as long as I have had my XR. Lots of great information on here! It's a 2001 XR400R. This bike is a blast! I live in Eastern NC, so if anyone is near Wilmington, let's get together!
Here is a photo of my bike:
Does anyone know where I can get an acerbis front disc guard and fork guards in white? I currently have black on there that came with the bike. I've been looking for a good bit now! I appreciate any leads!
Happy Riding.
~SuperTimmy
Hi and welcome. Nice looking bike. Like the rack, did you make it?
G600 is offline   Reply With Quote
Old 06-28-2012, 10:54 AM   #4682
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,228
Originally Posted by KilLeR Kawasaki View Post
I understand the basics of a four stroke engine. I was thinking that if the head cover is off, the rocker arms and timing would all be taken out the equation.
Is there an XR400 - head rebuild - guru in the Denver area?
Tthe rockers come off with the head cover, so the valves don't move and you can't do a regular compression test. There's no way to pull air in on the intake stroke to compress. It's a good way to do a leakdown test, though.
Luke is offline   Reply With Quote
Old 06-28-2012, 03:41 PM   #4683
SuperTimmy
On A Mission
Oddometer: 28
Thanks! The rack is a Moose Racing rack. I ordered it for $149 through revzilla. I have a surfboard rack that attaches to it. It's a nice rack! I highly recommend it to anyone looking for a rack for their XR400!
SuperTimmy is offline   Reply With Quote
Old 06-29-2012, 07:23 PM   #4684
creedyflyr
creedyflyr's Avatar
Oddometer: 237
New Facelift after destroying a rear Hub near the end of a 500KM ride.The Brake disk side bearing failed & it cracked the Hub in 2.
Got hold of some cheap SM Pro wheels of an XR650R & converted the rear to suit the 400. Front was a sraight swap.
I'm retiring the XR from Adventure duties & getting a new KTM 690 Enduro for that sort of riding. I'll keep the XR for the tight stuff.
Creedy.
creedyflyr is offline   Reply With Quote
Old 06-30-2012, 03:03 AM   #4685
G600
Oddometer: 462
Creedy.
What did you have to do to make the rear wheel fit? Spacers only? Is the hub the same on both bikes, or just the brake disk to sprocket space?
Old 06-30-2012, 04:23 PM   #4686
creedyflyr
creedyflyr's Avatar
Oddometer: 237
The 650R uses a thicker rear Axle so some different bearings & seals are needed.
Here is a list of parts I used:
1 x 91205-950-003 OIL SEAL 25X42X7 (From a Honda Fourtrax 4x4 Steering Stem)
1 x 91253-033-003 OIL SEAL,25X47X6.5 (Standard XR400 rear wheel seal)
1 x 91003-KRM-841 BRG,BALL RADIAL (from Honda CRF150F Transmission)
1 x 6303 ball bearing. (Generic size bearing)
4 x 90113-MAC-780 ( These Bolts along with 4 washers are needed to fit the XR400 Rotor on the XR650 Hub)
Creedy.
Old 07-01-2012, 04:45 AM   #4687
G600
Oddometer: 462
Creedy.
Thanks Great info..
Old 07-03-2012, 06:10 PM   #4688
PCK_4xCustoms
lost
PCK_4xCustoms's Avatar
Oddometer: 263
I'm intending to drop my rear sprocket from the stock 45 to 42 or maybe lower for road riding so I can drop my RPM's at 50-60.
BUT, I cant seem to find a source for any lower than 45/stock. Then again my searches have been specific to the xr4.
sooooo, what else works for this bike? looking for steel and cheap
'97 XR400r (plated) / '01 Triumph Tiger 955i
'95 XT350 (plated) SOLD
(2.5) '73 XL250's SOLD
PCK_4xCustoms is offline   Reply With Quote
Old 07-03-2012, 06:35 PM   #4689
Dexter2811
Dexter2811's Avatar
Oddometer: 298
Supersprox has a 42t sprocket for XR400
and this http://www.ebay.com/itm/JT-Rear-Stee...d2959c&vxp=mtr is my first search for "Sprocket XR400" on ebay
2010 NX4 Falcon, 440cc Wiseco Big Bore, Stage II Hotcams, XR400R clutch, XR600 40mm Mikuni carb, MX handlebar (Wirtz), Custom exhaust.
Dexter2811 is offline   Reply With Quote
Old 07-03-2012, 06:59 PM   #4690
Ed@Ford
Oddometer: 1,662
I use a 16 front countershaft sprocket with the stock 45 rear...no need to lengthen chain....but you loose the little crankcase protector....I think it was a premium renthal sprocket
Ed@Ford is offline   Reply With Quote
Old 07-03-2012, 07:36 PM   #4691
PCK_4xCustoms
lost
Oddometer: 263
yeah i run a 16/45 right now but I odnt like the buzzing whine of the high R's at 50-60
seems a bit high at that point
Old 07-03-2012, 08:17 PM   #4692
KilLeR Kawasaki
Marky A
KilLeR Kawasaki's Avatar
Oddometer: 967
Posted at Thumpertalk
Thought I'd cross post here in case anyone can answer any question authoritatively. Wondering about the Cam Shaft Plunger and whether that may have been missing all alone and causing the low compression issues. The link goes to Thumper Talk.
2008 Kawasaki KLR650
2001 Honda XR400R
2007 Suzuki Bandit 1250
Colorado Dual Sport Riders
KilLeR Kawasaki is offline   Reply With Quote
Old 07-03-2012, 08:35 PM   #4693
mookybird
Gramps
mookybird's Avatar
Oddometer: 213
I bought my Sunstar steel 39 tooth sprocket from Motosport, service was great. Part # SS-SR-3559-39
I don't have a tach and can't provide numbers but it cruises nicely at 60 with the 16 on front and is still workable for easy trail riding by swapping to the 13 tooth.
mookybird is offline   Reply With Quote
Old 07-03-2012, 10:50 PM   #4694
Czechsix
Slower than you....
Czechsix's Avatar
Oddometer: 316
I'll verify when I get home, but I think I found my steel 42 at rocky mountain atv.
FYCYFF (Dakar 2011)
'98 XR400R, Rokon , '81 GL1100, '15 TW200
SDAR, CORVA
Go, Antonio, go!
Czechsix is offline   Reply With Quote
Old 07-04-2012, 12:23 AM   #4695
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,228
The plunger is supposed to catch on the thing on the cam that prevents kickback and keep it in a particular position. Since the anti-kickback mechanism works by releasing the compression, that plunger is pretty suspect.
Times are GMT -7.   It's 03:12 AM.
