Old 08-15-2012, 10:30 PM   #4816
hughrk
hughrk's Avatar
Oddometer: 73
Originally Posted by mr bones View Post
A little info, or a lot would be better.
This bike has no lights, Blinkers or even switches but it seems the wiring harness is still intact. The on-off button works "I've tested, won't start with it unplugged?
The only spare plugs are these two?
Can somebody tell me what they are for?
Thanks mr B
The horn, it mounts on that bracket on the down tube with the bolt in it.
hughrk is offline   Reply With Quote
Old 08-15-2012, 11:39 PM   #4817
mr bones
Oddometer: 97
Brilliant thanks mate. My cousin is over for a beer. He's a sparky & tested it all for me. "She's got power" just need switch blocks, Blinkers & horn.
mr bones is offline   Reply With Quote
Old 08-19-2012, 06:06 PM   #4818
PCK_4xCustoms
lost
PCK_4xCustoms's Avatar
Oddometer: 263
Soooo hows the tensioner plunger spring supposed to look?
Cause I think mines broke.
'97 XR400r (plated) / '01 Triumph Tiger 955i
'95 XT350 (plated) SOLD
(2.5) '73 XL250's SOLD
PCK_4xCustoms is offline   Reply With Quote
Old 08-20-2012, 02:54 AM   #4819
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,571
uh..it's suppose to look "unbroke"?
got a pic of what yours looks like? The plunger should extend out away from the housing. It is very difficult to push it in with out the use of a small screwdriver. If you can push it in with little effort, then it's broke
DrLewall is online now   Reply With Quote
Old 08-20-2012, 06:47 PM   #4820
birds
birds's Avatar
Oddometer: 249
A little top-heavy
getting home
Today I "changed" my oil and let my last 2 quarts flow right back out of the drain hole that I forgot to close.
birds is offline   Reply With Quote
Old 08-20-2012, 07:10 PM   #4821
PCK_4xCustoms
lost
Oddometer: 263
The spring i believe is broke. theres a bit wrapped around the shaft inside then more on the OD of the bowl, but not connected
Old 08-20-2012, 07:31 PM   #4822
bobbed06
Cavalera Conspirator
Oddometer: 1,236
Out for a short commute ride around town and I suddenly hear a horrible horrible noise coming from my motor.
Haven't pulled it yet but I'm thinking its cam chain or valve train. I used to have a link to the online clymers but cant find it.
The noise seems to come from the very top by the camshafts.
There was no change in performance, ie. no power loss, popping or the like. Just awful noise.
Any thoughts before I go tearing it apart?
Do yourself a favor and install a 2002 CRF450 timing chain and new tensioner shoes while you are at it. If cash isnt an issue a Hotcam stage 1 and a high comp Wiseco 11:1 piston never hurt anything either.
bobbed06 is offline   Reply With Quote
Old 08-20-2012, 08:08 PM   #4823
Wallrat
Wallrat's Avatar
Oddometer: 742
Except engine longevity...
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Wallrat is offline   Reply With Quote
Old 08-20-2012, 08:13 PM   #4824
bobbed06
Oddometer: 1,236
I ran a high comp 426 setup for 2 years solid absolutely no issues whatsoever, but if thats what you wanna beleive than thats fine.
Old 08-20-2012, 08:38 PM   #4825
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,756
I finished up my DC conversion and lighting and have some left overs you guys maybe interested in...
http://advrider.com/forums/showthread.php?t=817961
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
KTMSER is offline   Reply With Quote
Old 08-20-2012, 09:05 PM   #4826
Dexter2811
Dexter2811's Avatar
Oddometer: 298
I'm running a 440cc 10:1 comp with Stage II cams since last year and 25000 Kms on it. Using Regular gas (95 RON) and not a single issue.
2010 NX4 Falcon, 440cc Wiseco Big Bore, Stage II Hotcams, XR400R clutch, XR600 40mm Mikuni carb, MX handlebar (Wirtz), Custom exhaust.
Dexter2811 is offline   Reply With Quote
Old 08-21-2012, 05:25 AM   #4827
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,571
it does happen..I was abt 40 miles from home when mine went..super easy fix, as long as you can get the tensioner...my last one lasted abt 10 yrs tho, so that is good!
Old 08-21-2012, 06:07 AM   #4828
curlysurfer
in need of a ride
curlysurfer's Avatar
Oddometer: 423
So your on a limited budget ie one that can't support thousands going out the door each week, what's your order of importance for making the old XR better. for enduro to dual sport type.
In no particular order, but I think I'd rather have the bike handle right before I make it go like stink
USD Forks or brace, and spring/revalve stock fork
rear shock rebuild and setup for my fat arse
pumper carb
cams
stroker crank
stator
headlight
crf450
lets hear what you think
1962 Vespa VBB bali special 1975 BMW R75/6 resto job - collecting dust
couple of mountain bikes, 20 or so surfboards, not enough time........
curlysurfer is offline   Reply With Quote
Old 08-21-2012, 07:25 PM   #4829
PCK_4xCustoms
lost
Oddometer: 263
Yeah, ordered one from bike bandit, managed to fat-finger the order and got the '' cam chain tensioner'' and not the ''plunger tensioner'' which is what I need.... nearly $30 in shipping later..... I have the right item on the way. I was considering the manual adjuster, but figured OEM in this case was the best bet.
Old 08-21-2012, 10:36 PM   #4830
Wallrat
Wallrat's Avatar
Oddometer: 742
Any reputable builder will agree that raising the compression is the best way to shorten the life expectancy of the engine. I'm not saying your engine will blow within ____ years, I'm just saying that the XR400 is renowned for its reliability. That's its major selling point! Sure you can build the crap out of it, trash the reliability, but in the end you'll have an engine with power comparable to a stock CRF450. Better IMO to play to the natural strengths and weaknesses of a given machine, and stop trying to figure out how to turn a pickup truck into an indy car.
07 565EXC
09 F800GS
03 Beta 270
12 Kuberg Start
13 Kuberg Cross
Times are GMT -7.   It's 05:36 AM.
