10-19-2012, 07:30 AM
#5041 | |
Ride Rural Texas
Oddometer: 423
35-40ish MPG, the Mikuni pumper isn't known for great gas mileage but it truly shines in all other aspects. Actually my 650L gets better gas mileage than the 440, go figure. ![]() Of about 50 total riders for the 3 day event 6 of us attempted the whole thing in one day. Due to mechanical issues only 3 of us made it. 2 of the 3 were on Hondas.
'06 TW200 Mountain Goat '06 XR650L Sumo '98 XR440R trick and plated '98 KDX220 plated '84 RZ350 '83 XR350R '83 XR200R '84 ATC125 |
10-19-2012, 03:01 PM
#5042 |
Oddometer: 141
Hey guys have a question on the FMF Powerbomb header
I'm replacing my existing header (unknown brand) and noticed that on the powerbomb, the left tube is a decent bit longer than right tube. My old header doesn't have this, and is pretty equal length. What are your thoughts on this? I know equal length headers work better. I also noticed the part where the two tubes join is kind of pressed together into a slightly smaller opening and then enlarges I know it might be only 1% difference, but since I'm spending 300 dollars to _upgrade_, I want to make sure I'm getting something that's an upgrade, otherwise I might as well keep the current header (maybe needs a recoat, but tube might be a good setup) Thoughts and experiences / comparisons welcome! Thanks!!
http://www.stuckatwork.com |
10-19-2012, 03:52 PM
#5043 | |
Oddometer: 323
10-19-2012, 03:56 PM
#5044 |
Oddometer: 141
negative, aftermarket. xr's only maybe? unsure of brand
10-20-2012, 02:51 AM
#5045 |
Oddometer: 123
Acerbis, IMS, or Clarke Tank?
Hi Inmates,
I'm considering upgrading the stock tank to one that will carry a bit more fuel while out in the boonies Are there any preferences as to manufacturer,Acerbis, IMS, or Clarke and if so why, size, shape etc. I don't need something with enough capacity to cross deserts. just a gallon or two more, plus something that won't be in the way should the bike take a tumble. Thanks Mark. |
10-20-2012, 04:25 AM
#5046 |
Oddometer: 16
Xr400
G'day guys, I'm now the proud owner of a XR400!
![]() starts easy as pie and sounds great. Just wondering how good those Baja dual sport kits are? And also what should I be checking out? Any common problems to look out for? I am about to embark on the mighty 300+ page read to see whats been happening with these great bikes. Cheers all and I look forward to learning a lot in the coming months Ohh and when i figure out how to post pics i will She is a 2002 model and all stock. 2300 euros delivered |
10-20-2012, 04:47 AM
#5047 | ||
Oddometer: 23,773
Over all, |
10-20-2012, 07:46 AM
#5048 | |
Oddometer: 28
Clarke is 3.8 gallons Ims is 4 gallons Acerbis is 5.8 gallons Clarke tank because of shape clears most all front end changes... Other than stock top triple, Usd fork conversion, etc Ims tank is longer and sits a hair lower but hits w/ most if not all top triples other than stock, and some front blinker locations. Acerbis tank is really an ADV tank. I have not tried one with other than oem front goodies...? Tho it is crazy big, if filled only to desired 3-4 gallons, weight sits much lower than other two tanks. This is not to be over looked cause adding a oversize tank is gonna change handling on your xr... Besides the obvious added weight to front end Clarke and Ims sit higher than stock which makes them feel even heavier than the added 8lbs adayinthedirt screwed with this post 10-21-2012 at 08:16 AM |
10-20-2012, 09:47 AM
#5049 |
Oddometer: 287
I can confirm that the Clarke tank does not interfere with a USD conversion. Plenty of clearance actually.
07 450EXC |
10-20-2012, 11:10 AM
#5050 |
Ride Rural Texas
Oddometer: 423
I've had the IMS 4.0 installed for 6 yrs, no probs. Recently, anticipating some rides where the range could potentially exceed 150 miles between gas stops, instead of spending $$ on an even larger tank I bolted a Kolpin 1.5 aux tank to the Cyclerack giving me an additional 60 or so miles. I can conveniently remove it at anytime and install it on different bikes as well.
![]() View from the rear... ![]() Same tank installed on the KDX..
10-20-2012, 12:10 PM
#5051 |
Oddometer: 23,773
you might wanna rethink the fender bag in front of the oil cooler..I had to
10-20-2012, 01:44 PM
#5052 |
Oddometer: 323
I still have a 2000 for sale with a clean WV title. PM me if interested, I will deliver up to 100 miles. I live near Charleston WV.
10-20-2012, 03:49 PM
#5053 | |||
Oddometer: 123
10-21-2012, 09:12 AM
#5054 |
Oddometer: 58
Exhaust Manifold
Hi all, just doing some maintenance to my 98 XR. Took the exhaust headers off to give them a good clean and replace the gaskets. Removing the headers revealed that the previous owner has perhaps had some trouble with the studs in the past. Only two studs remain of the four. The other two have been replaced by bolts, one of which it looks like has stripped the thread inside the head. I plan on using helicoil to repair the thread but before I do I am just seeing if anyone has any horror stories with this kind of work/method before I set about doing it.
On another note, does anyone know if you can still buy acerbis upper fork guards? If so a link would be greatly appreaciated. Many thanks. |
10-21-2012, 11:18 AM
#5055 | |
Slower than you....
Oddometer: 280
FYCYFF (Dakar 2011) '98 XR400R, Rokon Trailbreaker CORVA, SDORC, SDADV Neduro to Dakar 2012 TEAM F5 2012 WHAT A GREAT RIDE! |
