Old 11-08-2012, 10:10 AM   #5161
Luke
GPoET&P
Luke's Avatar
Oddometer: 3,749
Originally Posted by PCK_4xCustoms View Post
Those with some major rise to their bars, what did you do about too short clutch cable length?
Mainly what length do I need?
Maybe, who raised how?
I went a little over +3 on the bars, with stock cables.
Rotate the throttle tube down, and re-route the clutch cable so it goes behind the triple clamp, not in front. That's barely visible in the picture under the tank vent hose and to the left of the left riser.
Later, I swapped out the whole clutch + decomp perch and cables with ones from a KTM LC4. I had to do a bit of bracket fabbing but the pull is much smoother and it gets rid of the separate decomp perch on the bars.
Luke is offline   Reply With Quote
Old 11-08-2012, 10:18 AM   #5162
PCK_4xCustoms
lost
PCK_4xCustoms's Avatar
Oddometer: 228
looks good, ill give it a go when i get home if i can.
iirc the throttles were ok, but the clutch and decomp were getting close to max. cant remember if i routed behind the triple though
'97 XR400r (plated) / '01 Triumph Tiger 955i
'95 XT350 (plated) SOLD
(2.5) '73 XL250's SOLD
PCK_4xCustoms screwed with this post 11-08-2012 at 10:20 AM Reason: smart phone? my ass..
PCK_4xCustoms is offline   Reply With Quote
Old 11-08-2012, 10:44 AM   #5163
Wallrat
Wallrat's Avatar
Oddometer: 292
@Ed
In stock form that tank bag isn't so hot. Got it here: http://www.rockymountainatvmc.com/p/...Tank-Bag-Black
The tank side is cordura nylon, which I figured would scuff up the tank. Since I'm a tad OCD about keeping my bike as clean as possible I sewed a microfiber cloth to the underside. Still has the problem of no straps going under the tank so that's the current project. It's okay if there's fairly heavy stuff in the bags but if they're too light they flip up onto my legs while I ride. Its incredibly annoying. Here's another shot:
07 450EXC
Wallrat is offline   Reply With Quote
Old 11-09-2012, 08:51 AM   #5164
Ed@Ford
Oddometer: 1,050
Originally Posted by Wallrat View Post
@Ed
Yup...exactly the issue I encountered....I ended up sewing a couple of "D" rings on the lower inner front corners of the bag, and lash it with some small diameter bungie stretch cord from the boat store
not wonderful...just functional...and being OCD is OK too
Ed@Ford is online now   Reply With Quote
Old 11-09-2012, 09:00 AM   #5165
Ed@Ford
Oddometer: 1,050
Originally Posted by Ed@Ford View Post
Yesterday got the swing arm bolt drilled out in far enough that the engine and swing arm is "free" from the frame. Cheap step drills from Harbor freight and some turned down shank 9/16 allowed me to drill out each end of the SA bolt. Today I stripped off everything that connects to the engine and the swing arm. A couple bounces and what was left of the tissue paper thick SA bolt just ripped and it's free. Gonna strap the frame my platform ATV jack and see how much the engine will move up and forward and tilt to the side to weasel the engine+swing arm out of the frame. If it does, I'll consider it an act of God. I think the sawzall will have to come to the rescue and "shorten" the swing arm. Fortunately I bought a used one. That's followed by the treat of getting the SA bolt out of the ass end of the crankcase. No pix though
I was able to weasel the engine with the swing arm attached out the right hand side of the frame. Had to cut up the swing arm though...and the alloy in the cast part of the swing arm must have loads of silicon....ate 3 sawzall blades and slashed it up like Doc did
Followed most of Dr. Lewall's guidelines after that....to get the last bit of bolt out of the rear of the crankcase required HEAT...especially on the steel bushing in the rear of the crankcase on the sprocket side....serious rust...once it moved a tad, I soaked it with aerokroil, then polished the part of the bolt that gets exposed when pounding it back and forth....back and forth, juice it up...pound some more...and it was out and done in 15 minutes or so
Talk about relieved. Thanks Doc L for documenting his repair process.
Old 11-09-2012, 03:59 PM   #5166
DrLewall
DrLewall's Avatar
Oddometer: 23,819
TADA!! Glad you got it out..now, plan on servicing that booger at least once a year! and if you sell it, tell the new owner to do the same, or not
DrLewall is offline   Reply With Quote
Old 11-09-2012, 04:31 PM   #5167
Ed@Ford
Oddometer: 1,050
Yup...that sucker is gonna get plenty-o-lube, and the whole bike will get cleaned up and given a once over.
Noticed my replacement carb choke plate has 2 very significant sized slotted holes in it....has anyone seen one that is blank or a more appropriate size for a 400 engine?
Old 11-09-2012, 04:40 PM   #5168
DrLewall
DrLewall's Avatar
Oddometer: 23,819
does the choke plate have the backfire plates on it or does the choke plate just have two holes, like the XRsonly choke plate?
here are the backfire plates
so, is yours like any of these posted above?
btw, I have the XRsonly plate in mine..my backfire plates were abt to fall off and I didnt want to suck anything into the jug...knowatimean?
Old 11-09-2012, 04:51 PM   #5169
Ed@Ford
Oddometer: 1,050
Mine is like the red one...I went back over the thread and Laramie C4 said 7/32"...DAMN that's small....but nows the time to deal with it...the carb is laying on my garage floor!!...gotta go out there and check to see if it's steel or not......
Old 11-09-2012, 06:34 PM   #5170
Bullamakanka
Oddometer: 24
The "Red" one is the one you want to use. The other ones have a tendency to snap the metal flap off which then decides to enter the cylinder head causing all sorts of expensive issues. Hence the XR's only red one is a modified version to address this issue.
Bullamakanka is offline   Reply With Quote
Old 11-09-2012, 07:38 PM   #5171
Tachedoutoffroad
Tachedoutoffroad's Avatar
Oddometer: 479
@Ed
Great looking bike
-Is that just high temp paint on motor?
-did you make the front fender smaller? Not the holes, but overall?
-trim the rear fender?
-CRF forks?
I need to paint my wheels black. Mine looks retro as fuk. The purple adds 3hp though
'09 Husky 510 TE/SM
'07 Husky 610SM SOLD
'96 Honda XR250/300R (plated)
'96 Honda XR600R (plated) FOR SALE
Tachedoutoffroad is offline   Reply With Quote
Old 11-09-2012, 08:56 PM   #5172
Wallrat
Wallrat's Avatar
Oddometer: 292
Thanks. Its been a good bike and gets a lot of attention.
Just used Engine Enamel 400° for the engine, 2000° on the pipe: http://www.duplicolor.com/products/enginePaint/
Front fender shown there is an acerbis supermoto:
http://www.rockymountainatvmc.com/p/...Fender-YZ-Blue
I couldn't ever get used to the 17" radius of the fender with a 21" wheel so I ended up swapping it out to a regular CRF450 one which I had to trim a few inches off the back of it to clear the frame.
Rear fender is just the standard XR400 one from Polisport: http://www.rockymountainatvmc.com/p/...6-Honda-XR400R
Yep, 450 forks with the Emig conversion stem: http://www.emigracing.com/CRX46.htm
Can see all the parts I've used listed here: http://2wheelsplz.blogspot.com/2012/...fications.html
07 450EXC
Old 11-10-2012, 10:18 AM   #5173
Tachedoutoffroad
Oddometer: 479
Cool. Thanks.
Showing off my noob dirt riding skills I'll go ahead and blame go pros hill detamer, bald tires, slick Alabama clay, and my wife bitching at me for being gone so long
http://www.youtube.com/watch?v=86M3N...e_gdata_player
http://www.youtube.com/watch?v=w61Rk...e_gdata_player
'09 Husky 510 TE/SM
Old 11-10-2012, 03:24 PM   #5174
tonusmaximus
maximus
tonusmaximus's Avatar
Oddometer: 151
My Xr won't idle down all the way to the set idle speed without a snap of throttle. I replaced the exhaust inset but it was doing it before. Really haven't gotten into the bikes mechanics yet as its a good wild ride since I've had it but this seems to be a problem since it doesn't slow the bike down for lights and big turns. Thanks ahead people.
tonusmaximus is online now   Reply With Quote
Old 11-10-2012, 06:17 PM   #5175
tonusmaximus
maximus
Oddometer: 151
it idles down but just to 1800 rpm or so without snapping it. snap throttle it goes to around 1400 where i want it. it wont go down anymore while pushing down on the wheel where cables meet on carb with screw driver so i believe cables are ok. carb coming off soon to check jetting and cleaning plus choke plate. could this scenario happen with jetting off?
Sent from my SPH-D700 using Tapatalk 2
Times are GMT -7.   It's 05:00 AM.
