12-08-2012, 11:47 AM
#5251 | |
Oddometer: 314
Ok. If the bolt won’t move, try heat before doing anything more drastic. I was once working on a stuck swingarm bolt in a 2004 xr4. It had never been out and was truly stuck. The usual big hammer, socket with long extension shaft and rust penetration oil routine did not work. So I got a oxygen/acetylene (steel) cutting Torch. If you do the same, DO NOT TOUCH THE LEVER as you don’t want to blast any material away. With a strong flame you can heat the swingarm bolt from end to end, you can blast the flame through the hollow bolt. I did heat the bolt until it was just starting to go read (at the torch end) , and then let it cool down. I repeated this maybe ten times, but eventually the bolt moved. |
12-08-2012, 11:59 AM
#5252 |
Mad Scientist
Oddometer: 3,168
Sweet. I have an oxy-acetylene rig. Thanks for the tip.
12-08-2012, 12:06 PM
#5253 |
Oddometer: 23,814
12-08-2012, 12:16 PM
#5254 |
Mad Scientist
Oddometer: 3,168
Yep!
12-08-2012, 01:27 PM
#5255 | |
Oddometer: 1,050
my opinion is the water that rusts it in place comes thru the gap between the SA and the rear of the crankcase It is also my opinion that as long as your swing arm moves smoothly, even though the bolt won't budge....leave it be Ed@Ford screwed with this post 12-08-2012 at 01:36 PM |
12-08-2012, 05:36 PM
#5256 |
Oddometer: 23,814
12-08-2012, 10:24 PM
#5257 |
Oddometer: 479
My 400 got traded in for a plated 250/300 and a plated 600
![]() ..A buddy needs this measurement and I can't help him out... ![]() ![]() Can someone measure the length from the center of the pivot bolt to the rear machined end, like in this pic?
'09 Husky 510 TE/SM ![]() '07 Husky 610SM SOLD ![]() '96 Honda XR250/300R (plated) '96 Honda XR600R (plated) FOR SALE |
12-09-2012, 02:09 AM
#5258 | |
Oddometer: 23,814
22 3/4 DrLewall screwed with this post 12-09-2012 at 02:16 AM |
12-09-2012, 05:47 AM
#5259 |
Oddometer: 479
![]() Think he's trying to put a 400 rear end on a 250 to get the rear shock suspension..... BTW Xr600 is 22 3/4" Xr250 is 21 3/4" Middle of bolt head to end of arm. XR250 Wheelbase:********************* 55.1” Rear Susp Travel************* 10.6” Ground Clearance********** 12.4” Shock Type: ***************** Kayaba Linkage Ratio (est)********** 4.0 > 1 Stock Spring Rate************ 11.0 Spring Dimensions********** 61.0 x 55.5 x 190 mm (OD x ID x Length) Swingarm Length********* Swingarm Bolt***************** 14mm x 213 mm SA bushing length*********** 15 x 20 x 64 *(OE #52141-KCZ-000) Pivot Works#******************** H-PI-032 Upper Shock Bolt************ 10mm x 55mm Lower Shock Bolt************ 10mm x 55mm Upper Rocker Bolt********** 12mm x 90mm Lower Link Bolt (to rkr)* 10mm x 74mm Lower Link Bolt (to SA)* 10mm x 69mm XR400 Wheelbase:*********************** 56.1” Rear Susp Travel************** 11.8” Ground Clearance************* 12.2” Shock Type: ********************** Showa Linkage Ratio (est) Stock Spring Rate**************** 9.50 Spring specs********************** 63.1 x 59.1 x 217 mm (OD x ID x Lengt Swingarm Length************ Swingarm Bolt****** 14mm x 255 mm SA bushing length*********** 15 x 20 x 64* (OE #52141-HN1-000) Pivot Works#******************** H-PI-032 Upper Shock Bolt************ 10mm x 55mm Lower Shock Bolt************ 10mm x 55mm Upper Rocker Bolt********** 12mm x 90mm Lower Link Bolt (to rkr)* 10mm x 74mm Lower Link Bolt (to SA)* 10mm x 69mm
12-09-2012, 02:39 PM
#5260 |
919 excuses to ride!
Oddometer: 414
I finally got time to load one of our rides over the summer onto YouTube. I thought I was geared pretty low until I found this network of trails! Santa is bringing me a bigger rear sprocket!
https://www.youtube.com/watch?v=dBzN...ature=g-crec-u
He is his own best friend and takes delight in privacy, whereas the man of no virtue or ability is his own worst enemy and is afraid of solitude. -Aristotle '01 Honda XR400, '04 Honda 919 |
12-09-2012, 04:36 PM
#5261 | |
Mad Scientist
Oddometer: 3,168
- After removing the pedal from the bike... Ground the weld off the outside surface of the pedal and pressed the worn-out shaft out. - Using a MIG welder, ran beads along the shaft itself to increase the diameter. - Put the shaft in my lathe and turned it down to the proper diameter, then pressed the shaft back into the pedal and re-welded it back in place. That takes care of the pedal. - Drilled out the pedal mounting hole in the frame with a 5/8-inch (.625) bit. Since I was using a hand drill, it wallowed out to .635, but that's okay... - Using the lathe again, machined a steel bushing with an inside diameter to allow a proper fit on the pedal shaft, with outside diameter of .637. - Smeared the outside of the bushing with red Loc-Tite and pressed it into the frame. Tomorrow morning it'll be as good as new. Maybe better... I believe I might seal the ends of the pedal shaft, cross-drill it, and install a grease fitting. ![]() It... is... ALIVE!!! Muuuwaaaa-hahahahahahahaha!!!
Stretch67 screwed with this post 12-09-2012 at 07:43 PM |
12-09-2012, 05:14 PM
#5262 |
Oddometer: 23,814
A man who has SKILLZ and machinery at his finger tips! When can I move in, Dad!
12-09-2012, 07:37 PM
#5263 |
Mad Scientist
Oddometer: 3,168
C'mon in, m' brother!
![]() ![]() ![]() "I love it when a plan comes together!" |
12-10-2012, 04:52 AM
#5264 |
Oddometer: 1,050
Stretch67:
Clever!! |
12-10-2012, 12:20 PM
#5265 |
Oddometer: 314
