Old 12-10-2012, 01:17 PM   #5266
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,158
Yeah, too bad there's no easy way to renew the pivot hole. I once worked on a friend's '82 Yamaha XJ650 Maxim, and its brake pedal pivot had a grease fitting. Handy. Doing so may have cost Yamaha a dollar. Too bad the bean-counters win when it comes to these things nowadays.
I took the rear suspension link and shock loose today (with the exception of that pesky swingarm), greasing everything with Mystik JT-6 Hi-Temp waterproof grease. All the pivot bearings were in remarkably good shape considering this bike's heavy use. Honda must have actually greased those parts on assembly.
My '87 XL250R has factory-installed grease fittings on those pivots, but it appears the bean-counters won when the final design for the XR4 hit the CEO's desk.
I was wanting to install a grease fitting for every pivot, but then realized I'd never be able to drill through the bearing races. The link, shock, dogbone, and associated parts in which the zerk fittings themselves are installed are cast aluminum... no problem. But for the grease to be able to get into the bearings themselves, a hole would have to drilled into the races, which are hardened steel, which would merely laugh at my drill bits. So I simply slathered grease on everything and reassembled. (Sigh)
I do like the XR4's removable subframe. That makes it a lot easier to access things back there. My other trail bikes, XL250 and DR250, don't have removable subframes, and it gets to be quite a puzzle to get things in and out of there.
Stretch67 screwed with this post 12-11-2012 at 03:57 PM
Stretch67 is offline   Reply With Quote
Old 12-12-2012, 06:10 PM   #5267
XR4EVER
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 402
Don't know if anyone is watching, but I figured I'd share some more XR footage from over the summer. Shaky footage, but you get the idea....
He is his own best friend and takes delight in privacy, whereas the man of no virtue or ability is his own worst enemy and is afraid of solitude. -Aristotle
'01 Honda XR400, '04 Honda 919
XR4EVER is offline   Reply With Quote
Old 12-12-2012, 06:40 PM   #5268
Olas
the darkness
Olas's Avatar
Oddometer: 3,583
That trail looks perfect for the XR. Hope I get to ride it sometime. How big is the trail network around that area?
FS: Street Legal American Trail Killer!!
Rebuild threads:
'92 XT600
, '87 XR250R
Lighten up, Francis.
Olas is offline   Reply With Quote
Old 12-12-2012, 06:52 PM   #5269
XR4EVER
XR4EVER's Avatar
Oddometer: 402
PM sent.
Old 12-13-2012, 01:28 PM   #5270
JimmieA
Oddometer: 1,019
electric start?
I know this topic has been around awhile. I have most of the stuff needed to do this. I am missing the one way bearing and the crank shaft extension. I have to drill a new bolt hole in the tranny for the starter, there is a tab there for this. The one way bearing can be purchased new from Honda. I may need a different shifter or bend it out a ton. I need to build something to mount the battery. Does anyone sell the extension for the crank seperate?
I wonder if people who have done this could contact me using e mail
stillrn at gmail dot com to tell me the ups and downs of this, their experience. The biggest issue I have is the bike is a bitch to start, maybe I should just purchase the Edelbrock carb and be happy!
Thanks people. Love my XR400R but it doesn't get much use.
JimmieA.
Atlantic Canada.
2008 Honda XL1000V Varadero
2004 Honda XR400R
JimmieA is offline   Reply With Quote
Old 12-13-2012, 01:52 PM   #5271
Ed@Ford
Oddometer: 1,050
It's been a LOONG time since I looked into e-start for the XR....but I recall the crankshaft extension was to eliminate the need for a crankshaft change from the XR400 bike to the ATV crank...then along came the crankshaft extension, which was a double taper cone doodad to somehow allow the XR bike crank to be used....and in fact, this bit was the only totally NON honda part...except of course for the battery box and cables etc...
Am I all wet here...or just an old fart with a bad memory...............????
Ed@Ford is online now   Reply With Quote
Old 12-13-2012, 02:25 PM   #5272
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 2,566
You are correct, and the company in the UK that makes them has one left in stock. It was priced at about 50% of what I bought my XR for.
tbarstow is offline   Reply With Quote
Old 12-13-2012, 03:30 PM   #5273
DrLewall
DrLewall's Avatar
Oddometer: 23,773
Originally Posted by Stretch67 View Post
C'mon in, m' brother!
Stretch is pretty "industrious"..maybe we can get him to make us some crank extensions!
DrLewall is offline   Reply With Quote
Old 12-14-2012, 02:04 PM   #5274
JimmieA
Oddometer: 1,019
Do you have the link? What is the price?
Does anyone know what material this piece is made of? Does it have to be hardend steel like a crank or can it be softer material? Anyone know a CNC machinest that would make one of these for me? I looked at the transmission casting, I would have to drill a hole in the tab for the second starter bolt, any one know about this, like how deep is too deep?
JimmieA.
Atlantic Canada.
2004 Honda XR400R
Old 12-14-2012, 02:14 PM   #5275
Ed@Ford
Oddometer: 1,050
I'm willing to bet this little devil will be $$$$.....a precision conical taper on one end....the other end a precision INTERNAL conical taper....precision in that it needs to extend the crank that has a flywheel/alternator magnets that spin 10,000 RPM...with NO runout whatsoever
Old 12-15-2012, 02:18 AM   #5276
Wilson9068
Wilson9068's Avatar
Oddometer: 58
I think the supplier you are after was a company called XR Stuff. Last time I looked they had gone out of business. I bit the bullet and bought a starter kit from them about two years ago. I still have the instruction manual somewhere I think. The phone number was 0161 4278887. www.xrstuff.co.uk. The crank adapter really is a piece of work.
Wilson9068 is offline   Reply With Quote
Old 12-15-2012, 07:37 AM   #5277
tbarstow
Two-wheelin' Fool
tbarstow's Avatar
Oddometer: 2,566
If you really want an electric start XR400, go find a TRX400EX motor, like the blown up one in my garage, and rebuild it.
Old 12-15-2012, 04:29 PM   #5278
Luke
GPoET&P
Luke's Avatar
Oddometer: 3,748
It's probably easier to replace the crank than make an adapter. There are a couple of used cranks on ebay now for under $100, and new weisco kits for under $300.
Luke is offline   Reply With Quote
Old 12-15-2012, 04:38 PM   #5279
Ed@Ford
Oddometer: 1,050
All XR & TRX cranks are pressed together...right?...assuming one has a 100% good XR engine, wouldn't it make sense to press off the alternator end of the XR crank, and press on the "long starter end" of the used TRX crank?
But also, aren't there some extra little mods to the XR frame to get the wider "starter motor equipped" engine into it?
I've had an XR since 1997...wanted an e-start on it since 1998....and, as some would say, putting e-start on an XR is like putting a silk dress on a pig....but I still like the idea.
Old 12-15-2012, 04:49 PM   #5280
Ed@Ford
Oddometer: 1,050
ooooh...my aching ass made it thru something like that in 1997 in CO on an XR250....only to end up hitting a pimple in the road, by comparison, and getting a nasty tib-fib fracture near Steamboat springs
Times are GMT -7.   It's 06:50 PM.
