Old 12-19-2012, 05:12 PM   #5296
XR4EVER
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 1,090
Originally Posted by Tachedoutoffroad View Post
Just kick it! Stay true to the game! There really isn't a modern equivalent of the XR400
if you're bored, buy some new parts/ tank/ plastics
Not bored by any means... Don't get me wrong. The XR is perfect for 75% of the stuff I ride. It's just that some of the trails I ride would just be more well-suited for a smaller, shorter bike with E-start. When you are on a trail that is 6" wide with a sheer drop-off to your left and a steep wall of rock to your right and you had to stop to cut a tree that was in your way, it is life-threatening to try to balance and kick because there is nothing for your left foot to step on. (I know... "Leave it running.") I am on my tip-toes as it is with the XR which isn't an issue most of the time. Just thinking it would be nice to take a smaller, more "replaceable" bike when heading to the goat paths where speed and suspension travel aren't an asset.
I hate bear grass.
XR4EVER is offline   Reply With Quote
Old 12-19-2012, 05:15 PM   #5297
XR4EVER
XR4EVER's Avatar
Oddometer: 1,090
Originally Posted by Rman237 View Post
....I can only imagine the traffic nightmare before the bridge was built.
I was actually thinking the traffic looked way worse in the vid from what I remember!
I hate bear grass.
Old 12-19-2012, 05:39 PM   #5298
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,540
I thought the same thing. I cruised right on through, turned around by the spillway on the AZ side, and came back to NV idling in second. Nary a brake light...
Potato potato potato
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is online now   Reply With Quote
Old 12-19-2012, 10:35 PM   #5299
lesteryeong
Oddometer: 11
My XR400RV
Here is my XR400RV. It has almost everything upgradable. It is running a 440 kit, IMS wide pegs, Pro Comp computer, pro taper mid bend handle bar, Acerbis Multiconcept X-Strong handguards, White Bros Megalloy full exhaust system, Devol frame guards, Devol bash guard, Excel rims and front oversized braking rotor.
lesteryeong is offline   Reply With Quote
Old 12-19-2012, 10:43 PM   #5300
lesteryeong
Oddometer: 11
HID on a XR400
I am going to revisit a thread about installing HID on the XR400. I have a set of 35W H/L HID for motorbike. I wish to have it installed. I have a DC voltage regulator. but a, unsure what I need to do to make the HID work. I have a small 12V battery on hand (3.7Ah), large size capacitor (can't recall what is the rating). I tried wiring it up before to the DC regulator and it would die off at idle as I believe the stator could not handle the voltage spiking. Anyone has got success in similar installation?
Old 12-20-2012, 03:45 PM   #5301
Stretch67
Stretch67's Avatar
Oddometer: 6,540
CRF450 Cam Chain
Just so you know, the late-model CRF450 Cam Chain, Honda Part # 14401-MEN-A31, won't work on an XR400... too short. Ask me how I know.
The correct part number is Honda 14401-MEB-671, having 112 Links, to fit a 2002-2008 CRF450.
So... anybody need a late-model 108-link CRF450 Cam Chain, like new, never installed?
IBA # 33113
Alaska
XR400 Index
Stretch67 screwed with this post 12-20-2012 at 04:13 PM
Old 12-20-2012, 04:17 PM   #5302
Ed@Ford
Oddometer: 1,605
Thanks for the info....I woulda bought the wrong one too!!!
Ed@Ford is offline   Reply With Quote
Old 12-20-2012, 04:30 PM   #5303
Stretch67
Stretch67's Avatar
Oddometer: 6,540
I have the correct one inbound from Ron Ayers. The short one is in ADV's Flea Market for $40 shipped. If no takers, I'll eBay it in a few weeks.
I did research, but it was inadequate. In my Christini readings, I learned that CRF's changed in 2006, but didn't catch that the cam chains changed in 2009. So there are two...
IBA # 33113
Alaska
XR400 Index
Old 12-20-2012, 04:30 PM   #5304
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,338
as was stated correctly here
DrLewall is offline   Reply With Quote
Old 12-20-2012, 04:32 PM   #5305
MartiniUp
Oddometer: 1,902
That guard on the rear caliper does nothing but retain heat which ruins the rear braking. You really should remove it.
MartiniUp is offline   Reply With Quote
Old 12-20-2012, 04:36 PM   #5306
Stretch67
Stretch67's Avatar
Oddometer: 6,540
Wow yeah, a post from only two-and-a-half years ago. How could I have possibly missed that?
I had a fifty - fifty chance.
IBA # 33113
Alaska
XR400 Index
Old 12-20-2012, 04:42 PM   #5307
Ed@Ford
Oddometer: 1,605
Originally Posted by Ed@Ford View Post
It's been a LOONG time since I looked into e-start for the XR....but I recall the crankshaft extension was to eliminate the need for a crankshaft change from the XR400 bike to the ATV crank...then along came the crankshaft extension, which was a double taper cone doodad to somehow allow the XR bike crank to be used....and in fact, this bit was the only totally NON honda part...except of course for the battery box and cables etc...
Am I all wet here...or just an old fart with a bad memory...............????
Just for jollies I went looking at wiseco dot com for an XR400 crankshaft kit. NADA....but they have the ATV crank assemblies (I assume it includes a rod) for $360....that ought be the starting place to build an e-start XR400 engine...rather than a used one that might be in poor condition.....
Old 12-20-2012, 06:01 PM   #5308
Stretch67
Stretch67's Avatar
Oddometer: 6,540
A brief word about sump strainers:
Check and clean them after major engine work. And check them from time to time just because you care.
Link: http://advrider.com/forums/showthread.php?t=850068
IBA # 33113
Alaska
XR400 Index
Old 12-21-2012, 06:06 AM   #5309
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,338
Old 12-21-2012, 08:00 AM   #5310
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,126
HIDs are rated at 35W, that's the run requirment, they require around 50W for a couple of seconds to start up. 35W is well within the stators output provided the RPMs stay above about 2500. Once the bike rpms drop down to idle the HID relies on the battery (if you have one) to keep running. The stator doesn't make enough power to keep a battery up AND run the HID. Stock, the 400s stator just won't run a 35W HID reliabily, it will need a battery and a highoutput stator. The shutting off and starting back up of the HID as it tries to run off the shock output will ruin the ballast rather quickly also.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Times are GMT -7.   It's 04:54 PM.
