Old 12-31-2012, 09:52 AM   #5356
Rman237
Ride Rural Texas
Rman237's Avatar
Oddometer: 801
Originally Posted by Stretch67 View Post
I've PM'd the link to Thumpers Forum Mod GB for his perusal, asking him to consider the Index to be stickied at the top of the Thumpers Forum with the other bike-specific indexes. To be considered for Stickiness, he requires that the thread be maintained and updated, and I have assured him I will do so.
Wish us luck!
Luck wished. Seems a no-brainer to me , very useful info.
'06 TW200 Mountain Goat '06 XR650L Sumo
'98 XR440R trick and plated '98 KDX220 plated '84 RZ350 '83 XR350R '83 XR200R
'84 ATC125 '71 CL175
Rman237 is offline   Reply With Quote
Old 12-31-2012, 12:19 PM   #5357
MartiniUp
Oddometer: 1,928
WOW! Thank you.
MartiniUp is offline   Reply With Quote
Old 12-31-2012, 08:35 PM   #5358
Fishnbait
Fishnbait's Avatar
Oddometer: 42
Me and the boy went for a ride today looking for some snow. Doesn't happen to much here in the desert. Area is known as Four Peaks. Didn't make it to the top. Turned around at last picture.
Fishnbait is offline   Reply With Quote
Old 01-01-2013, 05:41 AM   #5359
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,590
DrLewall is online now   Reply With Quote
Old 01-01-2013, 11:16 AM   #5360
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,654
We're Stickied!
http://www.advrider.com/forums/showthread.php?t=366046
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 01-04-2013, 02:08 PM   #5361
Stretch67
Stretch67's Avatar
Oddometer: 6,654
I performed a pretty thorough once-over on mine since bringing it home earlier last month. It had started and run just fine, with no smoke, but the clutch was kind of grabby, and there was a hell of a racket coming from the valve cover. The valves were in spec, and the engine had great compression against the kick-starter, so I was pretty confident I had a good foundation to work with. It had started on the first kick, so I knew she liked me and wanted me to take her home. So I did.
And...
  • New wheel bearings (double-sealed bearings, re-packed with waterproof grease and re-sealed. I would seriously recommend this. New bearings frequently have a ridiculously small amount of grease in them from the factory).
  • New chain & sprockets
  • Re-machined & shimmed brake pedal, described earlier here.
  • Re-welded cracked shift lever
  • New brake pads, cleaned / polished pins
  • Cleaned & lubed odometer drive
  • Flushed & replaced brake fluid, Dot 4
  • Waterproof grease on all rear suspension pivots & links and reassemble.
  • Soaked carb in Pine-Sol for a couple days, then careful cleaning & reassembly. 60 / 158 jetting, fuel screw 2 turns out.
  • Home-built extended idle screw.
  • Clutch basket fingers filed smooth, new cable.
  • Cleaned both oil strainers. Photo of sump strainer posted here earlier.
  • 2002 CRF450 cam chain, tensioner plunger OK.
  • Removed non-functioning auto-decomp assembly from cam, welded those two oil holes shut in cam.
  • New rockers, adjusted valves.
  • Removed & cleaned airbox & drains
  • Gordon's Mods (Uni filter, no snorkel, ground header welds). Stock muffler though. I like quiet bikes.
  • Wrapped header & sealed w/ high-temp paint.
  • Threads of all removed bolts were cleaned on buffer w/ wire wheel...
  • Every bolt going into steel was greased
  • Every bolt going into aluminum or high-temp application was Never-Siezed.
  • New grips & handguards
  • New footpegs ($20 eBay big 'uns)
  • Clean & flush tank
  • New fuel line & inline filter
  • Denso Iridium plug
  • Plug cap resistor replaced with copper rod
  • New fenders (red Acerbis)
  • Straightened bent subframe. Item had already been reinforced at the usual break point.
  • Rotella T6 5W/40
  • Fresh 93 octane
And...
IT... IS... ALIVE!!!
Baby started on the FIRST KICK!
Nice and smooth, with no racket at all coming from the valve cover... just a nice sexy whir.
A ride around the neighborhood (in the dark, lights work) revealed no nasty surprises. Clutch friction was good at low speed top-gear roll-on, no slipping. Great low-end torque, smooth power delivery with no obvious off-idle dead spot.
SO HAPPEE!
IBA # 33113
Alaska
XR400 Index
Stretch67 screwed with this post 01-04-2013 at 02:35 PM
Old 01-04-2013, 03:27 PM   #5362
G600
Oddometer: 461
SO HAPPEE!
Nice Congrats. Quite a lot of work....
G600 is offline   Reply With Quote
Old 01-05-2013, 11:52 AM   #5363
franga
Oddometer: 16
tire sizes
Hey guys,
lovin this forum. ive got a 140/80/18 rear tire and it needs changing. will a 130 90 18 fit?
cheers
franga is offline   Reply With Quote
Old 01-05-2013, 12:50 PM   #5364
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,590
Originally Posted by franga View Post
Hey guys,
cheers
nope..too wide 120 90 will fit tho..at least on a 96 model that is
Old 01-05-2013, 01:02 PM   #5365
franga
Oddometer: 16
cheers for the quicky.
what sort tires do you guys recommen? 70% dirt riding 30% pavement.
i wanted to put d606 on the rear and d908 on front but apparently the 606 wont fit...
front 90 90 21
rear 140 80 18
Old 01-05-2013, 02:31 PM   #5366
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 33,590
front 90 90 21
rear 140 80 18
you are talking abt the XR400, correct? mine is a 96 XR4 and I run the D606, 120 90 18 and I can squeeze abt 3000 miles out of it before mounting a new one..wonder why a D606 won't fit on your bike?
Old 01-05-2013, 02:47 PM   #5367
Brewster
Brewster's Avatar
Oddometer: 43
Photo Test ..........
Sweet !
Brewster
Brewster is offline   Reply With Quote
Old 01-05-2013, 04:28 PM   #5368
stteve
Oddometer: 371
There is An XR400 in this years Dakar, no 127
Now-1977 YAMAHA XT500 - 1996 HONDA XR400R - 1991 YAMAHA XTZ660
Sold-1983 XT250/1991 TT350/1996 TT600E/1985 XT350/1999 TT600R/2002 TT600R
stteve is offline   Reply With Quote
Old 01-05-2013, 04:33 PM   #5369
Rman237
Ride Rural Texas
Rman237's Avatar
Oddometer: 801
i wanted to put d606 on the rear but apparently the 606 wont fit...
Says who?? Got a 130/90-18 606 on mine with room to spare.
Old 01-05-2013, 04:47 PM   #5370
Rman237
Ride Rural Texas
Rman237's Avatar
Oddometer: 801
http://www.dakar.com/dakar/2013/us/rider/127.html
Times are GMT -7.   It's 02:23 AM.
