Old 01-05-2013, 04:58 PM   #5371
MartiniUp
Oddometer: 1,982
Originally Posted by Brewster View Post
Sweet !
Very, very nice bike. But I don't see that license plate lasting very long.
MartiniUp is offline   Reply With Quote
Old 01-05-2013, 05:39 PM   #5372
Brewster
Brewster's Avatar
Oddometer: 43
Thanks for the compliment. The bike gets ridden alot and gets equal TLC. The plate has been on for a couple years now and its never even loosened up (LocTite). The plate bracket is from Scotts Performance ..... my buddy has one on his WR450F and his has not been a problem either.
Cheers,
Brewster
Brewster is offline   Reply With Quote
Old 01-06-2013, 04:32 AM   #5373
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,468
Shim Stack Mod
I did the revalve of the XR4's forks yesterday, threw in some .43kg eibach springs and new seals while I was in there. Pretty easy mod, it took about an hour on the first leg and about 30min on the second. I was able to do it w/o any special tools. I did need to use a airwrench to remove the compression stack out of the bottom since I didn't have the special tool to hold the dampening rod, I also made a seal driver out of 1.25" PVC coupler. Cost: about $135 including oil, sure beats the $300~400 that a suspension tuner would charge.
I haven't ridden it yet but they feel good, thanks trailryder42!
Here's the procedure if anyone is interested.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 01-06-2013, 07:32 AM   #5374
Wilson9068
Wilson9068's Avatar
Oddometer: 63
Originally Posted by Rman237 View Post
This guy is currently running in 106th place halfway through day 2. Go Nicolas Boyer
Wilson9068 is offline   Reply With Quote
Old 01-06-2013, 08:05 AM   #5375
MartiniUp
Oddometer: 1,982
Cheers,
The Scotts that has the dampers? Thank you.
Old 01-06-2013, 12:26 PM   #5376
Brewster
Brewster's Avatar
Oddometer: 43
That is correct, if the web-site says they don't have it, I'd call them anyway. I went to buy one for my Son's bike and it was in stock although the web-site said they were out.
Cheers,
Brewster
Old 01-06-2013, 01:09 PM   #5377
Czechsix
Slower than you....
Czechsix's Avatar
Oddometer: 316
Originally Posted by franga View Post
Hey guys,
lovin this forum. ive got a 140/80/18 rear tire and it needs changing. will a 130 90 18 fit?
cheers
Should fit fine, I'm running a 130/90-18 D606 on mine.
FYCYFF (Dakar 2011)
'98 XR400R, Rokon , '81 GL1100, '15 TW200
SDAR, CORVA
Go, Antonio, go!
Czechsix is offline   Reply With Quote
Old 01-06-2013, 01:11 PM   #5378
Czechsix
Slower than you....
Czechsix's Avatar
Oddometer: 316
Go Boyer!
From google translate and the Dakar site:
"bike only costs 3500 euros! '
This time comeback for Nicolas Boyer. He loves the bike in all its forms, and practice since the age of seven years on the tracks cross or enduro, the most prestigious circuits as the Bol d'Or, and of course on the dunes of Dakar, he won in 2001, finishing 35th on the same shores of Lac Rose. Since the Ardèche also tasted the boat races, but returned after a 12 year absence on the gold standard, the Dakar. To spice up the game, Nicolas is not only committed without assistance, but especially straddles an old Honda XR 400 from 1999, a model that will only drive the rally. With one of the smallest budgets of the plateau, the ghost also wants to show that the Dakar can be considered modestly.
"The same year, I had the Dakar and the Bol d'Or, which is not bad for a biker. Since then I've done other things, but every time I meet someone, he asks me when I'm leaving on the Dakar. And this year, I got the call from South America. I have an old bike, but it is a simple and reliable mechanics. There is a sentimental side to jump with a motorcycle in 1999, but it also worked many times. When others leave with a machine 35 000 euros, mine only costs 3500 euros! I have a total budget of 25,000 euros, I do not see how we can do less. I'm trunk-bikes because I think that is where are the true values ​​of Dakar. Moreover, if the objective is simply to reach the end, I'm also tempted by the victory in this category. "
FYCYFF (Dakar 2011)
SDAR, CORVA
Go, Antonio, go!
Old 01-06-2013, 01:16 PM   #5379
Wilson9068
Wilson9068's Avatar
Oddometer: 63
Finished in 107th of 169 riders, under an hour behind Depres!
Old 01-06-2013, 02:11 PM   #5380
Czechsix
Slower than you....
Czechsix's Avatar
Oddometer: 316
%@^@%^&%$& conn rod....
Dammit. I really didn't want to split the case.
Damn.
FYCYFF (Dakar 2011)
SDAR, CORVA
Go, Antonio, go!
Old 01-06-2013, 02:46 PM   #5381
Fishnbait
Fishnbait's Avatar
Oddometer: 43
Throttle cable part #
Broke a throttle cable on my last outing. Can anybody give me the Honda part number for the pull cable. The fiche online are confusing to say the least. Not much love from the Motion Pro cables, would rather use genuine Honda.
Fishnbait is offline   Reply With Quote
Old 01-06-2013, 04:39 PM   #5382
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 6,468
The only way to tell them apart online is to look real close at the picture where the cable connects to the throttle and you'll see one has a square rubber boot and the other a round boot.
Chris
Old 01-06-2013, 05:32 PM   #5383
Fishnbait
Fishnbait's Avatar
Oddometer: 43
Thanks, but the problem is they list two part numbers under the same tag number, and tag #1 and #2 have identical part numbers. Maybe i'm looking in the wrong place. Rocky Mountain and Ron Ayers. By the placement in the photo I believe I need tag #2, rear cable on throttle tube.
EDIT: Screw it. Just counted my change jar and ordered both.
Fishnbait screwed with this post 01-06-2013 at 06:11 PM Reason: Cheapskate
Old 01-06-2013, 06:32 PM   #5384
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,953
Foke Sprangs
Are there any identifying marks on fork springs in regard to their rate?
I'm needing to go into the forks on my '98 and at least ID the springs (hoping for .46's), as well as change the oil and do the Shim Stack Mod, if not already done. There's most likely not a set of .46 kg/mm springs already in there, but I'd like to ID the current residents just to be sure.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 01-06-2013, 07:43 PM   #5385
lamebrain
Oddometer: 38
I'm interested in hearing about the difference this makes. I've been thinking of doing this to mine!
And a pic just because.
lamebrain is offline   Reply With Quote
Times are GMT -7.   It's 02:35 AM.
