01-06-2013, 07:43 PM
#5386 | |
Oddometer: 40
And a pic just because.
01-07-2013, 02:40 AM
#5387 | |
in need of a ride
Oddometer: 229
i asked the same spring rate question a few weeks ago and was directed to thumpertalk Hope this helps. I need some .48's as mine dives quicker than a lesbian at Liquorland
1962 Vespa VBB bali special 1975 BMW R75/6 resto job - collecting dust couple of mountain bikes, 20 or so surfboards, not enough time........ curlysurfer screwed with this post 01-07-2013 at 03:52 AM |
01-07-2013, 05:34 AM
#5388 | |
Torque Junkie
Oddometer: 3,538
There's a method to count the coils, measure the wire size and distance between coils to come up with the rate, unfortunately I've seen it referred to but never looked up a chart or exact procedure, sorry. I was considering a USD upgrade prior to this mod and scoured TT, 4strokes.com and here for XR400 fork information, from what I've read the the vast majority of riders felt the stock forks can be made to work as well as USDs on the 400. They're just setup wrong out of the crate, specifically too much compression dampening and too low of a springrate for most riders (unless your about 140lbs). Aside from incorrect springrate, the excessive compression dampening causes the bike to standup in corners (I've noticed that) When compared to my 300xcw the XR doesn't want to turn. This is supposed to cure that, I'll see. It def feels much more compliant. |
01-07-2013, 11:17 AM
#5389 | |
GPoET&P
Oddometer: 3,748
IMO, if you mostly ride at: Sand dunes (Xmas valley, coast dunes) leave the compression alone. Sandy desert (China hat, Millican) do the mod halfway- leave in 8 shims give or take, depending on your weight. Everywhere else in OR: do the mod all the way, leaving 6 shims installed. No matter where you ride, getting the right springs will help a lot. |
01-07-2013, 11:55 AM
#5390 | |
Oddometer: 431
Sorry I didn't see this sooner. Pull cable usually starts with 17910, push cable usually stars with 17920.
01-07-2013, 01:45 PM
#5391 | ||
Mad Scientist
Oddometer: 3,158
![]() Quote:
01-07-2013, 02:42 PM
#5392 |
Oddometer: 1,050
01-07-2013, 02:51 PM
#5393 |
Oddometer: 1,050
As an XR400 owner with a lust for an electric start, I did some looking for a NEW 400 ATV crank and came up with a tidbit that there is a hot rod cranks place that makes stroked cranks (4 or 6mm...can't remember) with big bore pistons that will make a 460+ displacement XR4 engine......holy crap...imagine a monster displacement XR400 with e-start if one has deep enough pockets! monster torque....holy cow....has anyone looked into this in any depth?
01-08-2013, 08:11 AM
#5394 | |
Oddometer: 227
"Endeavor to persevere." |
01-08-2013, 08:51 AM
#5395 |
Oddometer: 1,050
I subscribed to DB since the 70's. Discontinued it a couple years back....don't recall that. Got a clue of what issue? Would like to have it for reference.
01-08-2013, 09:09 AM
#5396 |
Oddometer: 16
hey!
i am loosing oil! cannot find a leak anywhere and in my opinion its not running rich. WTF is happening? any of you guys have a similar problem?
01-08-2013, 09:39 AM
#5397 |
Rift- Raft, SCooter Trash
Oddometer: 800
I have
e start on mine with the trx400 left cover and a mikuni pumper carb. Works well, clearance no problem, the e start is nice but not necessary. I use it when I ride the 400, but not at all necessary if you had other uses for the money. I ride an xr250r and a xr600 as well, so kicking is no big deal, second nature. Only places I remember glad I had it was when I get hung up on a rock and stall. Only happened twice.Bike starts as easy as any modern bike.
Cbig |
01-08-2013, 09:40 AM
#5398 |
Oddometer: 23,773
01-08-2013, 09:43 AM
#5399 |
Oddometer: 16
this was about 800ml to a liter in an hour long ride. cannot be normal surely? i have just done an oil change this afternoon and will keep an eye on it...
01-08-2013, 11:09 AM
#5400 |
Oddometer: 809
