01-08-2013, 12:31 PM
#5401 |
Oddometer: 1,049
holy cow....if it's not dripping off the engine and all that much going out the exhaust, you gotta be making clouds of oil smoke!!
01-08-2013, 12:36 PM
#5402 |
Oddometer: 16
i know. and its not smoking at all! its running great. its like someone stole my oil!
by the way went to my local honda dealer (in france) and they said they do not stock my oil and then they tried to sell me road tires!
01-08-2013, 01:14 PM
#5403 |
Oddometer: 23,769
01-08-2013, 01:26 PM
#5404 |
Double Dutchie
Oddometer: 88
Does anybody know if you can replace the top triple clamp (yoke) with one from a africa twin or transalp?
i would like to have the vibration dampers in it for the handlebar.
2012 summer holiday |
01-08-2013, 01:27 PM
#5405 |
Oddometer: 16
yea i will, i should probably do the valves anyway so it might be worth havin a proper look. so strange though. i work on a boat as engineer and ive asked other engineers on the boats next door about it but no can figure out whats going on. we all decided that the oil was stolen in the end. haha! i was kind of hoping that it was a common/easy fix thing.
01-08-2013, 01:58 PM
#5406 | |
GPoET&P
Oddometer: 3,748
Are you checking the oil level correctly? The oil pump pickup is on the right side of the motor so if you let the motor run while the bike is leaning on the sidestand the oil level will appear to be a quart/liter or so low even though it isn't - the oil is in the crankcase instead of the frame. Ride the bike, then shut the motor down when the bike is still upright and check the oil within a few minutes of shutting it down. |
01-08-2013, 02:01 PM
#5407 |
Oddometer: 16
cheers luke, great info! i will check that after the next ride. but when i changed the oil today i only had about a litre come out of the frame. and im sure i turned the bike off before i got off.
franga screwed with this post 01-08-2013 at 02:08 PM |
01-08-2013, 02:46 PM
#5408 | |
Oddometer: 23,769
example: if you screw it in and the oil is just barely on the bottom of the dip stick, then you are CRITICALLY LOW on oil as it would not register on the dip stick if you were to drop it and check it as you should |
01-08-2013, 02:53 PM
#5409 |
Mad Scientist
Oddometer: 3,156
How much did you get out of the engine?
01-08-2013, 04:12 PM
#5410 |
Oddometer: 16
i was under the impression that screwing it in gave you the proper reading... but im newish to working on bikes. i need to get myself a xr400 workshop manual asap.
this was my first oil change since i bought the bike a month or so ago. ive done about 2-2.5 hours on it so far and the oil was fine when i bought it. i got a small amount when i took the filter cover off, about as much as the filter chamber would hold if thats what you mean stretch? is there another plug apart from the frame and the oil filter cover? franga screwed with this post 01-08-2013 at 04:25 PM |
01-08-2013, 04:30 PM
#5411 | |
Mad Scientist
Oddometer: 3,156
Bottom photo:
01-08-2013, 04:39 PM
#5412 |
Oddometer: 16
Awesome! looks like ill be draining it again tomorrow but properly this time.
Cheers heaps! i'll get back to you guys if my missing oil mystery persists... |
01-09-2013, 07:07 AM
#5413 |
Oddometer: 227
I believe it was late 90s early 00s. The thing that peaked my curiosoty was the reverse option along with the e-start. I have seen some EXs go for $15-1600 and have been tempted to do a swap then sell off the unused parts.
"Endeavor to persevere." |
01-09-2013, 08:33 AM
#5414 |
919 excuses to ride!
Oddometer: 402
With the recent talks of fork springs, I thought this would be relevant. It is from the "Mr. Know It All" column in the Jan. '11 issue of Dirt Bike mag.
He is his own best friend and takes delight in privacy, whereas the man of no virtue or ability is his own worst enemy and is afraid of solitude. -Aristotle '01 Honda XR400, '04 Honda 919 |
01-09-2013, 09:08 AM
#5415 | |
Oddometer: 808
