Old 02-26-2013, 05:37 PM   #5596
RideFreak
Green Chile Eater
RideFreak's Avatar
Oddometer: 5,990
Originally Posted by cbig View Post
THanks, I got it. I see I may need the impactor to turn it enough to get the friction to 34 Nm. I can do that easily without the other tool. Might screw with that next time out. Thanks, btw your videos are interesting, especially the Moab stuff. New Mex like that? Might have to put that on my to see list.
Chuck
When I pushed it down and hit it w/ the air wrench, you could feel it turning the dampening assy inside initially, I just compressed it a little more and it snugged right up, you can torque it but I didn't, it was easy to tell that it was tight.
The air gun wasn't very powerfull and I set to low torque.
Chris
"Life's journey is not to arrive at the grave safely in a well preserved body, but to rather skid in sideways, totally worn out, shouting ... Holy Shit, what a ride!"
CL Adventure Ride 2013 /CL Revisited 2014 / 700 Miles of Scenic Utah Backcountry / MY VIDEOS / RIDEFREAK TV
RideFreak is offline   Reply With Quote
Old 02-28-2013, 02:28 PM   #5597
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,296
Originally Posted by DrLewall View Post
With all this talk on clutches and such, here are some pix to help clear up any confusion as to correctly installing the clutch plates.
It is real easy to inspect your clutch, just remove the side cover and look to see if the plates are correctly installed, and if they are not, real easy to loosen up the bolts and pull the inner plate out and move the top plate over one notch.
Correct
WRONG!!
Adding my name to the XR4 riders proclaiming the value of having the outermost clutch plate indexed correctly (staggered).
It drops into gear more smoothly, and it's easier to find Neutral at a dead stop.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 screwed with this post 03-02-2013 at 11:00 AM
Stretch67 is offline   Reply With Quote
Old 02-28-2013, 09:31 PM   #5598
stuckin
Oddometer: 775
you lucky bastid!
Hey Doc when Travis put the new rear spring on my XR he said the bolts for the bring were still nice and oily. He did not try the swing arm one but said those moved so easy he figured the swing arm bolts had to come out nice and easy. Still need to try it but i have some hope.
Doc is the man with the XR's. I am glade he lives in AR.
stuck
stuckin is offline   Reply With Quote
Old 03-01-2013, 12:10 AM   #5599
BogeyMan
BogeyMan's Avatar
Oddometer: 446
For all you XR400R fans, there's an almost mint condition one on consignment in San Rafael, CA. Head over to Mojotown for a look-see (I have no affiliation with the store, apart from being a very satisfied customer).
'06 BMW R1200GS (Street),
'11 Husaberg FE570S (Dirt),
'14 Yamaha R6 (Track)
http://photos.boggis.com
BogeyMan is offline   Reply With Quote
Old 03-01-2013, 12:12 AM   #5600
Clem Kevin
Nude With Boots
Clem Kevin's Avatar
Oddometer: 890
So uhhh, how do you find it?
Clem Kevin is offline   Reply With Quote
Old 03-01-2013, 11:05 AM   #5601
MartiniUp
Oddometer: 1,821
Write down the address and drive over.
MartiniUp is offline   Reply With Quote
Old 03-01-2013, 02:28 PM   #5602
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,261
XR rear rack from Manracks
http://www.advrider.com/forums/showp...&postcount=777
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 03-01-2013, 03:21 PM   #5603
krebsatm02
Oddometer: 20
Help! Anyone have an Edelbrock Pumper Carb with a spare 16 or 17 needle? I love the carb but Edelbrock stopped making them and are running out of parts. All they had left was an 18, and with it all the way lean it still runs way too rich. Thanks - Doug
krebsatm02 is offline   Reply With Quote
Old 03-01-2013, 04:03 PM   #5604
Stretch67
Stretch67's Avatar
Oddometer: 6,296
Originally Posted by eakins View Post
The best-looking XR4 in the whole wide world!
IBA # 33113
Alaska
XR400 Index
Old 03-02-2013, 10:19 AM   #5605
ID XR600
ID XR600's Avatar
Oddometer: 245
Originally Posted by Stretch67 View Post
Adding my name to the XR4 riders proclaiming the value of having the outermost clutch plate indexed correctly. It drops into gear
Thanks I did not know this.
"Endeavor to persevere."
ID XR600 is offline   Reply With Quote
Old 03-03-2013, 08:20 AM   #5606
sbanks
Oddometer: 27
Just found this on my frame, pretty bummed. I thought this was in better shape, should've looked closer before I bought it. Is it repairable?
sbanks is offline   Reply With Quote
Old 03-03-2013, 02:44 PM   #5607
G600
Oddometer: 457
[/IMG]
It is repairable, don't be to bummed. XR4 frames are made of mild steel, easy to weld.
XR4 frame rust in not uncommon, do a search.
G600 is offline   Reply With Quote
Old 03-03-2013, 04:14 PM   #5608
DrLewall
The Human GPS
DrLewall's Avatar
Oddometer: 32,880
easy fix...
DrLewall is offline   Reply With Quote
Old 03-03-2013, 04:35 PM   #5609
sbanks
Oddometer: 27
Haha I've seen, what's the best method? Cut and add tubing or just cut half tubing and add over the bad spot?
Old 03-03-2013, 04:48 PM   #5610
oldenuf
Oddometer: 453
Compression?
Went to look at a 1999 XR400, to buy. Looked good, but went to kick it through and seemed to be down on compression. I could easily push it through with my hand. Started OK, and idled, did not smoke, and had good power. Thought the compression release might be over adjusted and the owner didn't have any wrenches. Hard to imagine that.
Any thoughts on this or pretty normal? As I recall my XR250R did not kick as easy as this.
Art
oldenuf is offline   Reply With Quote
Times are GMT -7.   It's 03:53 AM.
