Old 03-17-2013, 07:01 AM   #5671
XR4EVER
919 excuses to ride!
XR4EVER's Avatar
Oddometer: 489
Nice sig line, Dr. Lewall! I think I've seen that somewhere before!
He is his own best friend and takes delight in privacy, whereas the man of no virtue or ability is his own worst enemy and is afraid of solitude. -Aristotle
'01 Honda XR400, '04 Honda 919
XR4EVER is offline   Reply With Quote
Old 03-17-2013, 07:04 AM   #5672
DrLewall
DrLewall's Avatar
Oddometer: 24,189
yep..I stole it!
DrLewall is offline   Reply With Quote
Old 03-17-2013, 02:24 PM   #5673
kito
Oddometer: 172
has any one ever tryed to get a XR650R tank to fit there XR400 ??
im thinking one of these
Honda XR650R IMS Fuel Tank (2000-2007) 7.0 Gallon (Natural) Fuel Tank
or
Honda XR650R Acerbis Sahara Gas Tank 6.3Gal - XR Red
I dont mind doing a bit of fab work if it can fit over the frame and cilinder head.
I realy like the way they carry a lot of fuel lower
kito is offline   Reply With Quote
Old 03-17-2013, 03:16 PM   #5674
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,202
For more info on big aftermarket fuel tanks, check out the following Posts right here on the XR400 Thread:
24, 38-41, 68, 401-5, 408-9, 527, 550-52, 554, 690, 694-5, 804-5, 834-47, 1403-04, 1407, 1594-08, 1608, 1631, (2086-2092), 2329, 2335, 2372, 2378, 2391, 3001-03, 3051, 3218-21, 3681-89, 4340, 4369-70, 4586, 4625, 4665, 4676-77, 5048-50
Stretch67 is online now   Reply With Quote
Old 03-17-2013, 08:10 PM   #5675
kito
Oddometer: 172
just read through all them and its just the same few tanks . one guy asked the same question some time back and had a reply about the xr650r tank being design to fit round the rads and that might be a problem . I realy cant see why this would be a problem as im thinking it would give more space than we need. the main fitting issue would be the size/shape of the engine and the shape of the upper frame on the 2 different bikes . Is the anyone out there with a xr400 and a xr650r to compare for me ? if it fits over I can weld up the mounts
thanks kito
Old 03-17-2013, 08:28 PM   #5676
Stretch67
Mad Scientist
Stretch67's Avatar
Oddometer: 3,202
Okay. Try sending a PM to this cat... from his signature he appears to have XR400's, and 650's (R and L).
http://advrider.com/forums/showthread.php?t=871206
Old 03-17-2013, 09:04 PM   #5677
AndyCap
Mineral Oil Anyone?
AndyCap's Avatar
Oddometer: 1,194
First I apologize if this has been asked before in this thread. I did a search, but didn't have much luck.
I have a 2003 XR400R.
I am 230#, and find the rear spring may not be enough to handle me. Where do I go to get a new shock, or heavier spring? Is it even possible?
2000 BMW R1150GS
2008 KTM 950R SE
2001 Honda XR400R
2003 Honda XR100R
Another Proud Small Scale Faker......
AndyCap is online now   Reply With Quote
Old 03-17-2013, 10:50 PM   #5678
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,632
Recommended spring rates:
http://www.4strokes.com/tech/honda/sprngrts.asp
Eibach Springs:
http://performance-suspension.eibach...alog_downloads
Chris
VIDEOS
RideFreak is offline   Reply With Quote
Old 03-18-2013, 01:56 PM   #5679
MartiniUp
Oddometer: 839
Anyone who works on dirt bike susp can get any spring you need. There are hundreds. Any dirt mag will have many advertised or any dirt oriented forums will have info also. CK the XR4 forums in ThumperTalk. Factory Connection in your area is a great source also. Most will also have used springs at a good discount. A spring never goes bad.
MartiniUp is offline   Reply With Quote
Old 03-19-2013, 01:37 PM   #5680
JimmieA
Oddometer: 1,028
XR400 E-Start
I posted earlier about my electric start. I have the bike back now from the mechanic. He says the piece from Switzerland is good, like .002 run-out. He is happy with the part. I wanted his opinion as I was a little worried about it. I bought a 200 watt stator for the bike but the wiring harness is different so I have to sort that out. I have to build a battery bracket and get a starter solenoid and button before I have a magic button! I got a gasket for the XR400 but now I have a 400EX side cover so the gasket is missing the starter bit, my bad! If it leaks I will have to change the gasket. He used a bit of silicone and the old gasket in that area. I'm looking forward to magic button but it has been costly.
JimmieA.
Atlantic Canada.
2008 Honda XL1000V Varadero
2004 Honda XR400R
JimmieA is offline   Reply With Quote
Old 03-19-2013, 04:02 PM   #5681
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,632
A battery box out of a electric start KTM looks like it will fit right where it's mounted on the KTM, top rear of the airbox leaned backwards.
Same loc as this cap. They are plastic and mount through the back of the airbox. Should be able to find one cheap from KTM talk. Add a 1.5 lb LI battery like a turn tech and you're set. The box even has the mounts for the solenoid.
Chris
VIDEOS
Old 03-19-2013, 11:06 PM   #5682
JimmieA
Oddometer: 1,028
[QUOTE=RideFreak;20986800]A battery box out of a electric start KTM looks like it will fit right where it's mounted on the KTM, top rear of the airbox leaned backwards.
I ordered one of their batteries, give it a go. Thanks for the tip. Cost me $140 with shipping though!
JimmieA.
Atlantic Canada.
2004 Honda XR400R
Old 03-20-2013, 04:08 AM   #5683
PCK_4xCustoms
lost
PCK_4xCustoms's Avatar
Oddometer: 240
Ride freak, thanks for posting that photo again. I was trying to find it but couldn't remember where I saw it.
What size cap is it that you run? My battery pack is very dead from the PO.
Sent from my XT907 using Tapatalk 2
'97 XR400r (plated) / '01 Triumph Tiger 955i
'95 XT350 (plated) SOLD
(2.5) '73 XL250's SOLD
PCK_4xCustoms is offline   Reply With Quote
Old 03-20-2013, 05:04 AM   #5684
kdennan
Stinky Pinky
kdennan's Avatar
Oddometer: 395
Just my two cents,
I had a 98' 400 (only bike I regret selling) and did the following mods for ultimate performance on the cheap.
Removed exhaust pipe end cap and replaced with a 96'. Larger opening to let the bike breath. Sounded better too
Uni-filter and steel, high flow cage. Tossed stock air filter.
160 main and 60 pilot jets. This is based on sea level to 3,500' elevation.
Progressive fork springs, IMS stainless steel footpegs, Moose folding shift lever, Works Connection billet clutch and decompression lever, Renthal bars, ODI bolt on grips, Pirelli MT 16 rear (120) and MT16 front tires and the necessary guards.
Loved that bike!
I also had an XR600 and it was the one other bike I miss.
Someday I'll look out for either used and in mint condition.
It's better to sweat the petty than to pet the sweaty
kdennan is offline   Reply With Quote
Old 03-20-2013, 03:22 PM   #5685
RideFreak
Torque Junkie
RideFreak's Avatar
Oddometer: 3,632
YW, it's a 4400uf/50V, don't expect much output at idle, all it does is allow you to run DC w/o a battery.
Chris
VIDEOS
Times are GMT -7.   It's 08:26 PM.
