Old 04-20-2013, 10:05 AM   #5791
tonusmaximus
maximus
tonusmaximus's Avatar
Oddometer: 543
Cam chain r & R
anyone know if threads on clutch basket nut are reverse threaded or not? Also the nut holding the crank if that is what it is. The clutch nut is peened on also. I am gonna throw the impact to them but I wanted to make sure I'm not gonna be working against the grain so to speak... Thanks.
tonusmaximus is online now   Reply With Quote
Old 04-20-2013, 02:43 PM   #5792
Stretch67
Bent, But Not Broken
Stretch67's Avatar
Oddometer: 6,860
Regular thread... righty-tighty, leftie-loosey.
IBA # 33113
Alaska
Blue Ridge Parkway & Outer Banks
XR400 Index
Stretch67 is offline   Reply With Quote
Old 04-20-2013, 04:04 PM   #5793
tonusmaximus
maximus
Oddometer: 543
Thanks stretch. Well the crf450 chain went right on and everything is right as rain again. Bike is all buttoned up and purring. Had a ton of noise before and was surprised the guides looked good.
Sent from my SPH-D700 using Tapatalk 2
Old 04-20-2013, 04:26 PM   #5794
BLZBRKR65
Oddometer: 191
CRF USD forks, IMS tank compatibility?
Is anyone running this setup on their XR400? I have an IMS 4.0 gal tank and in the process of putting some Showa USD forks from the CRF. I seemed to remember something about the CRF bottom clamp hitting the tank or something to that effect. Appreciate the input....
'89 TRANSALP
'05 XR650L
'96 XR400R
'00 XR650R
'86 XL600R
'83 XL600R
BLZBRKR65 is offline   Reply With Quote
Old 04-20-2013, 04:53 PM   #5795
Stretch67
Stretch67's Avatar
Oddometer: 6,860
That was my experience as well, one hell of a racket with the old cam chain, a quiet purr with the new one. I also removed the Automatic Decompression stuff from the camshaft while I was in there, silencing the valve train even further.
I bought new cam chain guides, but when I got everything apart, the old ones looked really good. I did put the new ones in though, since I was already elbow-deep in XR4.
And for those readers just now joining us...
The late-model CRF450 Cam Chain, Honda Part # 14401-MEN-A31, won't work on an XR400... too short. Ask me how I know.
The correct part number is Honda 14401-MEB-671, having 112 Links, to fit a 2002-2008 CRF450.
IBA # 33113
Alaska
XR400 Index
Old 04-20-2013, 05:17 PM   #5796
Stretch67
Stretch67's Avatar
Oddometer: 6,860
Hey, dude. I'm not any help regarding the tank, but thanks again for the frame.
IBA # 33113
Alaska
XR400 Index
Old 04-21-2013, 07:43 AM   #5797
Brewster
Brewster's Avatar
Oddometer: 43
I'd guess there would be a clearance problem as its a pretty close fit with the stock forks and the IMS tank.
The larger diameter fork tubes would have to present a clearance problem. You might have to go back with a stock gas tank as the IMS, as you know is a tight fit.
Brewster
Brewster is offline   Reply With Quote
Old 04-21-2013, 12:42 PM   #5798
mvg2
mvg2's Avatar
Oddometer: 173
Wowzers is that clean!!! Nice bike
On a unrelated note, the momentum of getting the bottom and top end back in harmony is picking up. Recieved my new countershaft, crf chain, and a couple of different jets to experiment with.
Machinist said the cylinder bore was out of round and that explains the heavy build up on the piston. Now just to find some time between finals and work...
mvg2 is online now   Reply With Quote
Old 04-21-2013, 02:40 PM   #5799
Stretch67
Stretch67's Avatar
Oddometer: 6,860
Any chance of heating the affected area of the tank with a heat gun, slowly massaging the hot plastic out of the way?
Ove' Gloves are awesome for that, by the way...
http://www.amazon.com/Ove-Glove-Surf.../dp/B001EPR98Q
IBA # 33113
Alaska
XR400 Index
Old 04-21-2013, 05:18 PM   #5800
Brewster
Brewster's Avatar
Oddometer: 43
I'm sure its probably possible, but I'd be afraid of putting a hole in it and destroying an expensive tank.
I think its best to find out exactly how much reshaping would be involved first, and possibly finding a donor tank to experiment with.
Good luck.
Brewster
Old 04-21-2013, 07:01 PM   #5801
Stretch67
Stretch67's Avatar
Oddometer: 6,860
Nah, not a torch, just a heat gun. Mine has variable heat control, and you can vary the distance from the heat gun to the tank. Go slowly and finesse the plastic a fraction of an inch at a time.
Or if you're nervous about using any kind of external heat source, you can fill the empty tank with [very] hot water and work the plastic around once it gets warm and flexible.
IBA # 33113
Alaska
XR400 Index
Old 04-21-2013, 07:24 PM   #5802
Skought
Shadetree Mechanic
Skought's Avatar
Oddometer: 89
One from the top of the hill
took an early morning ride to my local OHV
From XR400
Skought is offline   Reply With Quote
Old 04-22-2013, 08:17 PM   #5803
aki
aki's Avatar
Oddometer: 126
Looks awesome.
Those who intend to visit Malaysia particularly Sarawak state, or Borneo in general.
Feel free to visit my blog
http://aki-sarawakadventure.blogspot.com/
aki is offline   Reply With Quote
Old 04-23-2013, 04:37 AM   #5804
Faceplant
Faceplant's Avatar
Oddometer: 253
Rick stator adapt to Australian wiring
Hi All,
To the electrical wizzards, I have an Aus XR400 bike with wiring loom and have upgraded the lighting to a baja double light setup. Issue is to adapt the ricky stator into this loom as there are a darn site more wires than the US models.
Help, can't seem to attach the wiring diagrams, can someone assist?
"The only function of economic forecasting is to make astrology look respectable." Ezra Solomon
"Capitalism is the exploitation of man by man. Yes? Well socialism is exactly the reverse." Len Deighton
Faceplant is offline   Reply With Quote
Old 04-23-2013, 09:58 AM   #5805
jphphoto
jphphoto
Oddometer: 35
float bowl needle replacement
Hi folks,
Been reading along and learning some new things to look out for on my newly acquired XR400. Got it running Sunday after some fiddling and cleaning the carbs out. Think I need a new sator rewind or Ricky's Stator since we had to resort to pushing to get it going the first time after winter hibernation. Always been a little hard to start since top end rebuild.
My question is, Can I replace the float bowl needle and floats with the carb still on the bike? Would probably require setting float height while on the bike too. Not sure if this is possible. It's a bear to carb off and on but its leaking like a stuck pig when the fuel is on so somethings gotta be done. Flooding may be affecting starting too?
Any advise is appreciated. I'll get some picks up once get this sorted.
Riding Pachaug this Saturday.
Jason
"Up-hils, along with downhills and level ground,
have always been my weakness. " Rick Seimans
jphphoto is offline   Reply With Quote
Times are GMT -7.   It's 02:17 PM.
