Old 05-06-2009, 10:57 AM   #151
Cowboy OP
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,301
Originally Posted by Minnesota Driver
That's some smoooooth lookin' black!
Ahh, the joys of choosing the camera angle carefully!
At least the horrible looking runs will be hidden under the chrome panels!
Cowboy is offline   Reply With Quote
Old 05-06-2009, 11:00 AM   #152
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,624
I demand more seat pictures.
crazydrummerdude is offline   Reply With Quote
Old 05-06-2009, 01:23 PM   #153
Cowboy OP
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,301
Your wish is my command:
Old 05-06-2009, 03:06 PM   #154
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,665
Very nice work!
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 05-06-2009, 09:51 PM   #155
Cowboy OP
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,301
Originally Posted by EvilClown
Very nice work!
Thanks! Here's a few more pics after some assembly time this evening. Once I had the tank on, I couldn't help myself . . . had to go for a ride. Even without a seat. Or fenders. I have a problem re: instant gratification.
The bike runs sweet as a nut!
Old 05-06-2009, 09:57 PM   #156
Cowboy OP
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,301
By the way, I discovered a slick trick when I was reassembling my headlight/speedometer: if your foam-rubber gasket is sun rotted around the part that is exposed, but looks good down in the area that is protected inside the headlight shell, you can turn it inside-out, and reinstall it upside down. That way the nice-looking part that was protected is now exposed under the chrome rim on the speedo, and it looks like you installed a new gasket (which, of course, is no longer available.)
Old 05-07-2009, 09:15 AM   #157
Minnesota Driver
Head greenskeeper
Minnesota Driver's Avatar
Oddometer: 91
Looking good, Cowboy! I've been spending all my free time polishing aluminum parts. Those wheel hubs will polish up almost like chrome with a little steel wool. Mine had a thick layer of white oxidation, but were like new underneath.
Now i need to figure out how to get at the inside of the hubs, between the spokes...
1970 Honda SL175 K0 Motosport
1966 Honda CB160 cafe
2001 Honda TRX450es
2008 Roketa 50
Minnesota Driver is offline   Reply With Quote
Old 05-07-2009, 09:53 AM   #158
Cowboy OP
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,301
No sense polishing mine much. When it's done, this bike will get used almost exclusively in our pastures and on forest roads. It's going to get abused a bit. (note the trials tires and CL160 skid plate mounted, to keep rocks from breaking the engine case!)
I ordered the silver paint for the side covers and fenders. Hopefully the bike will be finished by next weekend. I still need to get busy sewing up a new seat cover.
Old 05-07-2009, 09:12 PM   #159
stroming it softly
twins forever
Oddometer: 174
Here are some pics of my everyday CB160 and my 175 Sloper that was built for the Bonneville Salt Flats. The 160 is pretty stock, new top end, bored +10, rebuilt carbs but all the paint and stuff is original. The sloper is built for top end, I am trying to break 100mph which has not been done by a 4 stroke in the 175cc class. Burnt up a cam at the 08 meet but will be back in 09 with a reground cam and other secret stuff! I also have several other motors and frames which I will build into a full on cafe later this year using the 175 Bonny motor. It always amazes me that you can touch up the top ends of these engines, build the carbs, start them and take off. I recently picked up a superhawk 305 that was made into a dirt tracker in the 70's, it has a custom frame and many other goodys. It has been sitting since 1981 but still turns over! As soon as I finish this years Bonny bike I will start on this one and will post some pics when I get it together. [IMG][/IMG]
"Speed, it seems to me, provides the one genuinely modern pleasure". Aldous Huxley
stroming it softly screwed with this post 05-08-2009 at 07:22 AM
stroming it softly is offline   Reply With Quote
Old 05-08-2009, 07:44 AM   #160
stroming it softly
twins forever
Oddometer: 174
Here is one of the 175 sloper in it's Bonneville racing form. There are some changes being made for 09, different exhaust, lighter and smaller wheels and tires, small fairing and a smoother back end.
Old 05-08-2009, 08:56 AM   #161
Cowboy OP
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,301
Very cool! I wish I lived closer to a racetrack with a 160/175 racing series. That "Group W" stuff looks like a blast!
Old 05-08-2009, 11:53 PM   #162
pttrac
Oddometer: 1
Sweet bike and great resto thread. I was given a 65 CB160, but I have no idea how to work on them. I noticed the plugs are fouled pretty bad. Is this a common problem with these motors and do you know what I can do to remedy this.
pttrac is offline   Reply With Quote
Old 05-09-2009, 07:59 AM   #163
stroming it softly
twins forever
Oddometer: 174
Change the plugs, change the fluids, make the sure the carb slides are free, put some new gas in and make sure you have gas flowing to the carbs. If the battery is good it should start. These motors are pretty bombproof and if they haven't been abused badly in the past they normally start right up. I am assuming that the engine is free. Good luck.
Old 05-09-2009, 10:49 AM   #164
EvilClown
EvilClown's Avatar
Oddometer: 16,665
More pics please.
~Augustine of Hippo
Old 05-09-2009, 03:09 PM   #165
Minnesota Driver
Head greenskeeper
Oddometer: 91
I checked my plugs after I ran it a few miles and they were black, too. The bike seemed to run fine. Carbs cleaned up like new with a new kit in each. The jets in 'em are 92's. I'd like to lean it up a little bit, get them plugs toasty brown. What size jets do you guys run? Any other suggestions?
2001 Honda TRX450es
2008 Roketa 50
Times are GMT -7.   It's 10:30 AM.
