Old 06-10-2013, 08:14 PM   #721
JerryH
Oddometer: 5,069
From post #200, 05-24-2009. That is a beautiful old bike. I don't know why they can't build bikes like that today, or at least similar. It even has a kickstarter and a centerstand, two things today's bikes desperately need. You did a great job restoring it. I had my doubts when I saw the first pictures. It's amazing what some skill, knowledge, ans a lot of hard work can do.
JerryH is offline   Reply With Quote
Old 06-10-2013, 09:30 PM   #722
Cowboy OP
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,337
Thanks Jerry! I'm glad my restoration inspired a few people, and mostly I'm glad that this thread has become a popular gathering place for CB160 restorations on the 'net. I benefited a lot from the collective knowledge everyone brought to the thread.
As bad as my bike looked back on page 1, it required mostly just elbow grease to bring it around.
I still love seeing the before/after photos:
Cowboy screwed with this post 06-10-2013 at 09:46 PM
Cowboy is offline   Reply With Quote
Old 06-13-2013, 04:42 AM   #723
champ9597
Oddometer: 14
Question This is for Cowboy
Nice restoration. I am almost ready to start putting my 67 CB/CL160 back together. Have finally got all the parts painted and collected.
What did you do to your engine to make it look almost new? Just a good power washing and a lot of elbow grease? Did you paint your side engine cases or did they just clean up really nice?
Thanks. Hope to have pictures posted soon.
champ9597 is offline   Reply With Quote
Old 06-16-2013, 01:11 PM   #724
Johannes356
Oddometer: 7
Really glad I found this site. Just picked up my first bike, a 1965 CB160. Bike is in pretty good condition but the idle is really high. Reading through this thread is making for a wonderful Saturday.
In other news, I can make a pdf copy of the parts catalog, shop repair manual, and owners manual, but not where I could host something like that. If anyone has any suggestions, please let me know.
And now the good stuff...
Johannes356 is offline   Reply With Quote
Old 06-17-2013, 03:05 PM   #725
gene03079
Oddometer: 15
Great find The bike looks good.
gene03079 is offline   Reply With Quote
Old 06-17-2013, 03:08 PM   #726
gene03079
Oddometer: 15
My little 160 is getting close. A few more things to finish then I can start it up. The motor is all new. I kicked it over about 50 times to see if I could get oil to the top end but no luck. I hope it pumps oil when running.
Old 06-17-2013, 03:10 PM   #727
gene03079
Oddometer: 15
I have some odd gaskets for the mufflers. Anyone know if this is correct? They look kind of odd.
Old 06-23-2013, 09:16 PM   #728
Cowboy OP
Ceteris non Paribus
Cowboy's Avatar
Oddometer: 3,337
Originally Posted by champ9597 View Post
Cowboy,
I did just what you suggested: while the engine was out of the frame, I power washed it, and generally just used elbow grease and a scrub brush with some degreaser on both the fins and the engine covers. They look better in those photos than they do in real life. In real life, the engine is the roughest-looking part of the bike, but I restored it as a daily driver, just as I do my antique cars. Looking like they get used is a point of pride for me, so I don't mind the imperfect engine finishes.
Old 06-24-2013, 02:33 PM   #729
cafepenguin
Oddometer: 17
Side covers
Hey Cowboy....
I started watching this thread about a year ago as I picked up a 160 out of a junkyard and I'm trying to revive it... Kind of like I saw in your thread, I had a period of time there where I kind of stopped working on it... then I saw it again the other day and was like... yeah... okay, time to get back to work on it...
anyway, had a question for you... How did you get your fuel tank side covers cleaned up? Did they have rust pitting you had to deal with? Did you buy new ones, or find a good way to clean them up?
cafepenguin is offline   Reply With Quote
Old 06-26-2013, 12:38 PM   #730
vernon dent
vernon dent's Avatar
Oddometer: 703
got one for sale in the classified section if anyone is interested:
here is a pic of the original 80+ year old i got it from. still on the 1969 title.
I only ride 'em. I don't know what makes 'em work.
Oddball
vernon dent is offline   Reply With Quote
Old 07-01-2013, 09:44 AM   #731
Johannes356
Oddometer: 7
CB160 lean at start up
Looking for some tips to keep the bike from stalling out at start up. Even with the choke engaged it runs really lean at start up. Once warm its great. I have tried adjusting the air and throttle screws, and that is ok while its cold, but once it warms up then it idles too high.
So what is the best procedure to up the cold start idle without causing the idle to scream like a banshee when warm?
Be gentle, just learning carbs after spending my life on cars with electronic or mechanical fuel injection.
Old 07-01-2013, 03:49 PM   #732
Loudo
Pithy
Loudo's Avatar
Oddometer: 188
Have you verified that the carb slides are synched? You need to remove the air cleaner tubes so you can see into the carbs and ensure the slides bottom out evenly and that they begin moving at the same time as you twist the throttle.
Also, air leaks downstream of the carb body can cause no end of misery associated with weird starting problems and overrevving. The O-rings on each side of the manifold piece between the carbs and the head need to be in good condition. Unless those O-rings are new, I would replace them and synch the carb slides before expending effort elsewhere.
Loudo is offline   Reply With Quote
Old 07-25-2013, 12:19 PM   #733
Johannes356
Oddometer: 7
Question Light on Speedometer between 70 and 80
Just noticed a red light on the speedometer between 70 and 80. I can find no mention of it in the owners manual or the shop manual. High beam indicator is the first guess. Havent ruled out blinker fluid warning level indicator or the flux capacitor over charge indicator. Anyone confirm what it is?
Old 07-25-2013, 12:22 PM   #734
IanJ
Criminal Mastermind
IanJ's Avatar
Oddometer: 28
At least on my CL175, I have a high-beam indicator in blue on the headlight shell, a turnsignal indicator as one light in the speedo, and a neutral indicator as the other light in the speedo. None of the lights are red. If I had to guess, I'd say you have an oil pressure warning light.
2006 Ninja 250
2008 SV650 naked
2005 Ninja 250 (the track bike)
IanJ is offline   Reply With Quote
Old 07-25-2013, 07:17 PM   #735
Carnivorous Chicken
Carnivorous Chicken's Avatar
Oddometer: 45
CB160s didn't come with oil pressure indicators, and I don't believe they came stock with turn signals (but they could be ordered as an option or bought aftermarket). Someone feel free to correct me if I am wrong. The green one is your neutral indicator, and the red one is the high beam indicator. Caveat: speaking from experience with my own bike, not claiming to be a universal expert.
Carnivorous Chicken is offline   Reply With Quote
Times are GMT -7.   It's 03:12 PM.
