Old 01-20-2008, 07:10 AM   #1
AJ.. OP
AJ..'s Avatar
Oddometer: 1,585
Bandit 400/GSF400
Anyone still rides them?care to share some infos and photos?
just got one again for as cheap as SGD$600 for a 10yr old bike with unlimited milege..currently i am the 3rd owner.the 2nd used it for 4yrs.
anyways...my first cleanup on the bike..some photos to see...
just incase if happen i wont be keeping it...
originally
the bike have this clanky sound as you move..so check and replaced the front sprocket...the original ones already beaten badly
so after change the sprocket..thought can smile...but the sound still there...next change is the chain and rear sprocket
after 4hrs.
HONDA XRV750-02,(woot-woot)BMW R1100GS-'98()BMW F650GS-01
Suzuki XF650Freewind-01
Husqvarna TE510centennial Rallye-04
KTM640ADV,KTM620DUKE projected()[COLOR=red]VF750C-96(project tracker)
http://www.facebook.com/pages/AJs-friends/158711187491373?v=wall[/URL]
AJ.. is offline   Reply With Quote
Old 01-20-2008, 07:13 AM   #2
AJ.. OP
AJ..'s Avatar
Oddometer: 1,585
well,...it dont just stop there..
changed the handlebar to afam dirtbike handlebar,handgrips,cut a few inch both ends..replaced signals to DRZ SM clear signals..and jacked up the rear..removed the no plate light,and shift the no plate upwards
will do the fork,conebearings,chain and rear sprocket up next.
the butt end after the linkage mod.
Old 01-20-2008, 09:39 AM   #3
Uncle Ernie
Uncle Ernie's Avatar
Oddometer: 3,978
I had one for about a month. I had heard good things, and they are a gorgeous bike.
I found it very difficult to modulate the throttle, though. About mid-turn, the thing would shoot off like a rocket when it hit the power range. Maybe I wasn't keeping the revs up high enough, but it got on my nerves. That little bike was a stick of dynomite! Hella fast.
Why do you want to get the back up higher?
LOOK OUT IT'S COMING THIS WAY!
Uncle Ernie is offline   Reply With Quote
Old 01-23-2008, 02:28 AM   #4
AJ.. OP
AJ..'s Avatar
Oddometer: 1,585
well...
anyways..
back on it right the very weekend.clean the airfilter.
and a little paintwork on the plastics.
and the very next day to it...got the headlights changed.
and some decals job.
Old 01-23-2008, 02:32 AM   #5
AJ.. OP
AJ..'s Avatar
Oddometer: 1,585
anyways..i did the fork oil changed,fork seal,dust cover,engine oil change,grease the conebearings,mod belly pan and a little windscreen on the headlite..
dust cover and fork seal..SGD40bux total
clean up the entire fork
and bellypan installed
and a tiny little screen
and well...how do i look on the bandit?
more to come.
Old 01-23-2008, 07:31 AM   #6
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
Very nice. Good job!
JamesG is offline   Reply With Quote
Old 01-23-2008, 07:42 AM   #7
AJ.. OP
AJ..'s Avatar
Oddometer: 1,585
thanks dude..
well..next is to paint the belly pan and the headlite fairings.
and here is the bike i had just done respraying the head cowling and the bellypan..
AJ.. screwed with this post 01-23-2008 at 07:48 AM
Old 01-23-2008, 07:46 AM   #8
AJ.. OP
AJ..'s Avatar
Oddometer: 1,585
and my 1st coffee session with the few local Banditos.
picture was bad using my camera phone..at night,even worst.
Old 01-23-2008, 09:21 AM   #9
Tinks
Imp of Satan
Tinks's Avatar
Oddometer: 20,485
I like the Bandit 400. It is a popular bike amongst the inseam challenged. It is nice, sporty and they can touch the ground comfortably without having to lower it. If you plan to sell, I'll have to think for a quick second, but I thought I knew two people in the Little Rock area looking a while back...never mind if you are in Singapore...saw that a second too late!
Ride, Wreck, Ride
(Mr. Disaster) Preston Drew Haun June 17, 1981- August 15, 2010
Tinks is offline   Reply With Quote
Old 01-24-2008, 12:05 AM   #10
AJ.. OP
AJ..'s Avatar
Oddometer: 1,585
Little Rock?where is that?
Old 01-24-2008, 12:19 AM   #11
AJ.. OP
AJ..'s Avatar
Oddometer: 1,585
here's the latest upgrades...till today,i am still hunting for the gsxr front end in local garage sales..
added Tag T2 handlebar and clamps.
now with this bar setup,i felt the riding posture just right for me.
here's my ASV lever upgrade..removed the clutch sensor switch.removed the ERP bracket and relocate the ERP unit.
and took her on a little spin on the highway.
a 12yr old bike with milege that could reach the moon,able to hit 160km/hr.maybe i should change the rear sprocket from 47 to 43.and add one tooth to the front.
really had lots of fun on the bandit that day.
Old 01-24-2008, 08:59 AM   #12
lateral
Oddometer: 141
more to come.
Nicely done... $600 is quite a find. Nice to see pictures of Singapore too. Much better weather than here!
What bike are the screen and bellypan off of?
'06 Triumph Sprint ST
'07 Triumph Bonneville (wife's)
'06 Ducati Multistrada
'88 NX250
lateral is offline   Reply With Quote
Old 01-24-2008, 10:42 AM   #13
AJ.. OP
AJ..'s Avatar
Oddometer: 1,585
Hey dude..the only pictures of Singapore you see above are mostly under the void deck or carpark...so nothing so great about it.
The highways,the bikeshop doing the maintaince,modification,and the petrol station are across the borders...its Malaysia.
The weather here at this very month is somewhat temperamental.its normally so hot about 32-35 deg,and sometimes,it just rain like crazy and temperature about 28 deg.this month however alot of unexpected rain.so doin the trails on my XR would only mean mudsplashing...
since you like to see some nice shots of Singapore,will do tomoro..
AJ.. screwed with this post 01-24-2008 at 10:57 AM
Old 01-24-2008, 10:56 AM   #14
AJ.. OP
AJ..'s Avatar
Oddometer: 1,585
Ooops...sorry..the question.
well...the headlight comes from this bike.Honda Sonic125cc..its made in Thailand.SGD$30.
i did use the same headlens on my XR too.but with a little fibreglass work.
and the bellypan...its from this bike.
Its suzuki FXR150.only available in Malaysia.not in Singapore.
I got this idea 6yrs back when i spotted one malaysian biker and stopped him to ask him where can i buy them...well...i did it on my 1st bandit back then and it looks good to me.most important,its way cheap.50RM.its about SGD$23.
sounds good rite.
Old 01-24-2008, 04:33 PM   #15
jeepinbanditrider
Dunkin Donuts Crasher
jeepinbanditrider's Avatar
Oddometer: 1,235
Sweet I had it's big brother the 1200 Bandit. One of the guys I ride with has a 400cc Bandit. He can ride the piss out of that thing. Pretty quick bike. This guys looks funny on it also.
Like a monkey F'in a football. He's like 6 foot 7 in tall.
Here's the bike
Here's the guy that owns it. One of the best guys you'll ever meet. He had a bad motorcycle accident a few years ago. He's pretty good now.
2004 Suzuki DL650 Weestrom
1978 GS 1000
"Those who would trade security for a little temporary safety deserve neither liberty nor safety."
jeepinbanditrider is offline   Reply With Quote
Times are GMT -7.   It's 02:10 PM.
