11-07-2010, 09:13 AM
#391 |
Rider of the Lost Empire
Oddometer: 184
Thanks man. As far as I can tell looking at pictures, it should work. Worst case scenario - I will order the tank and racks and post up here if it DOESN'T work!
R100GSPD - R100RS Motorsport - K100RS Motorsport - Ural Gear-Up - Vanagon Westfalia http://www.flickr.com/photos/38874353@N05/ |
12-12-2010, 08:21 AM
#392 |
Cranky Old Fart
Oddometer: 2,404
I'm looking at modifying my KTM racks to gain clear access to the tank for fueling.
Does anybody remember a thread with pics about cutting and relocating the rack back tubes to do that? Something about cutting them off and flipping them left to right side. ![]() I recall there being some issue with the turn signals. ![]() BTW- I did attempt a search in OC. Seems like the search engine has issues since the site upgrade. At least for me.
Tom 2006 950 Adventure "Big Orange", 2009 690R "Ginger", 2003 525 EXC, 2001 400 EXC To Think is to Create! My2Wheels |
12-12-2010, 08:20 PM
#393 |
Oddometer: 53
Tank Install Done, almost satisfied
After seeing the pics of other 2007 990 Adventure's with this mod I had to do it. I am tired of constantly wondering where the next fill up will be. I ordered my tank and the 2 in 1 one pipe from Advtank.com and also install the Remus single can. My order was sent with the wrong instructions and short a couple of important parts, so I got part way through and had to let it sit for a few days. I did get my parts by the end of the next week.
Next, after it was complete, I noticed that the gas cap was going to be hard to get too; actually it would not go on with the KTM racks so I had to cut out the back support, hopefully that won't be a problem in the future. ![]() So here it is after the support was cut out ![]() No harm done, after seeing how other racks are made, I don't think I will miss this, and I can have another support welded in a some point. Today I took it out to see what type of mileage I would get from the tank. The only problem was when I hit the first good rutted out climb and really used the suspension the swingarm hit the mounting bracket. I knew it would be close but under flex (with a full tank) the room I measured was not enough. The tank functioned as promised and I ended up gettin gas at 240 miles, and filled my tanks with 5.11 gallons, and the aux tank with exactly 2 gallons, I think that was about the most I would want to push it. Here are the marks from the swingarm hitting the bracket, I am going to modify this bracket, or the tank is coming off. ![]()
12-13-2010, 05:35 AM
#394 |
Oddometer: 640
Mine was hitting too. I just bent the tank's bracket (by the petcock) out. So far it has seem to clear.
Question about that valve you're using to vent the tank. Have you had the tank in warm weather yet? If so any problems with it?
2011 Victory Cross Country 2006 Suzuki DR 650 |
12-13-2010, 07:02 AM
#395 | |
Cranky Old Fart
Oddometer: 2,404
It is what I'll be doing. ![]() http://www.advrider.com/forums/showthread.php?t=605227
12-13-2010, 08:08 PM
#396 | |
Oddometer: 53
So that's what they were talking about. Oh well. Thanks for finding that. |
12-13-2010, 08:14 PM
#397 | |
Oddometer: 53
BUT, one thing I forgot to mention about the 2 to 1, and I can't be positive since I have just done the install and this was my first ride; with the weather being very warm, and riding through stop and go traffic, some slow going off-road, I noticed that gas/vapor was coming from the right side tank. I am wondering if the 2 to 1 is getting much hotter and heating up the tank back by the frame and the exhaust at the midpipe? Anyone experience this? Could it be an exhaust leak making things hot? Will wrapping with the exhaust wrap I see on race bikes help? Any advice appreciated. |
12-14-2010, 02:23 AM
#398 | |
Muchacho mui loco
Oddometer: 2,303
12-14-2010, 04:15 AM
#399 | |
Oddometer: 640
To help prevent the gas from boiling I placed self adhesive silver heat sheild on back side of tank by the exhaust. I purchased it from Summit Racing. I also have an additional fan mounted on radiator which has made a world of difference with the overall cooling of the bike. Here the thread for the fan: http://www.advrider.com/forums/showthread.php?t=465977
12-14-2010, 11:26 AM
#400 | |
Fiendish Fluoridator
Oddometer: 509
![]() Make this modification ASAP. Jeff
San Francisco to Panama and back... eventually? How I Nearly Killed My Friends In Baja |
12-14-2010, 04:10 PM
#401 |
Mookish Mook
Oddometer: 4,289
Chaps, it takes 2 seconds to give that bracket a good pull out.
If you drop the bike (on either side), check it, give it a pull for good measure. |
12-14-2010, 06:31 PM
#402 | |
Oddometer: 53
12-14-2010, 06:34 PM
#403 |
Oddometer: 53
I think I got lucky, once I realized what the clanking was, I stopped to see the marks, then had to ride like a sissy the rest of the day.
12-15-2010, 02:18 PM
#404 |
Tuareg 2013
Oddometer: 11,356
MookyMoo is correct, this is also stated in the instructions. We didn't have much room to work with in there, but you should have a good half inch of clearance to the swingarm.
For Sale: FJ60, or Defender 90, Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible. Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills. |
12-15-2010, 02:21 PM
#405 |
Tuareg 2013
Oddometer: 11,356
When I started Adventure Tank, it was for a very simple and selfish reason- I wanted more fuel range for my SE, and did not care for the only available option. I took a risk on making a mold for the tank, because I thought that aluminum is the wrong material to make a tank from and you can't make a single plastic tank, and I crossed my fingers and toes that I wasn't going to wind up with the world's most expensive extra 100 miles of fuel.
The project turned out to be much more involved than I first imagined, but also much more fun. Hearing from people about how they loved the tank and 2 into 1, seeing pictures of my creations all over the world, and even coming out ahead on the project were all high points. People started asking for tanks for other models, and I realized that I didn't have the time to get them done. I was at a crossroads, and when my longtime riding friend Scott Bright (FORE! on this site) asked if he could help take the next step, I knew it was time. So, I sold Adventure Tank to Scott, and now I'm excited to see where it goes. I'm helping him with some aspects of developing new products (so that the lessons I learned the hard way don't go to waste!) and in the near future, he'll be announcing a tank for the F800GS, as well as for the 2008-up KTM dirtbikes. No timing yet on either of those, but they are in the works. Scott has been in the motorcycle business for a long time, and I've seen first hand that he knows his stuff and treats people right. I'm really excited to see where the business goes. If you have any questions, you can PM Scott, reach him via email at Scott@advtank.com, or even call him at (888) 403-2170. And above all, thanks for making it a fun ride. Nothing is more rewarding than hearing from folks about the places they've gone with something you made, and that is the part of this I'll miss the most.
