Old 10-06-2012, 09:42 AM   #46
HighwayChile
greetings from Wa state
HighwayChile's Avatar
Oddometer: 4,404
I have a DRZ400E, street legal , Im the 3rd inmate to own it, bought with low miles and 3K of add ons by original owner, stock except for jetting ( by Burned) 38.7 RW HP via dyno ( what ive read 300 & 350exc puts out about the same, rear wheel no one calls those dogs) suspension has been modded, rez man seat, guards galore, Alum sub frame but with dirtbagz, packs enough gear for RTW, suspension takes major G out fine, tracks straight at speed through rough. dead nuts reliable set up.
for me its near perfect dually mount. I bought it for remote distance fire roading, rough two track is my fav, occasional fast single track. to get to the good stuff, its 1 to 2 hours of 50 mph back roads, I run a 44 tooth rear, spot on for above riding. its a good balance of power, hp/tourque/ and how it delivers it.
most all ktm's are better at single track, hell an xr400 is better ( i have two of those) , in the latter case its due to geometry, guess what, the more relaxed DRZ's geo' mean its mo' betta on open road, FS roads etc. this will do single track not as good as either of the two mentioned but its not bad, and thats not my intended purpose. only very few instances will more power be used, I've had XR650R, KTM's, granted in some cases more power is a hell of a lot of fun but a lot of times its burned up in wheel spin, of course that in itself is a gas.... + more power in shit conditions not an improvement. just how often do you really hold that throttle wide fuckin open? It was a kick on my 650R in oregon dez but it wasnt that often, for my use, DRZ is perfect. sure I'd like a OD 6th but its not a deal killer w/ 44 rear.
I'm not anti ktm, Ive owned em, and spent a day on a 2010 250exc, great bike for that ride, better then my DRZ would of been as it was some nasty stuff. for my purpose that I bought the drz for , its a keeper. I'll probably own a KTM or Husky, Beta at some point though I am thinning the herd, ( down to 10 bikes now)
Ive rode for 44 yrs, used to be you might rib a guy for his ride all in fun, ( "maico-breako" etc) but man, the slamming that goes on because someone rides a particular bike, I just dont get ( maybe they need to get laid or covering for some other short comings... ) I can afford any bike I want, I picked the DRZ as it fits my needs spot on. some on this site seem to think I should be living under a bridge because of my choice in bikes.
as another saying goes, Its not what you ride, Its that you ride.
I would rather wake up in the middle of nowhere than in any city on earth. .....Steve McQueen
HighwayChile is offline   Reply With Quote
Old 10-06-2012, 03:07 PM   #47
bobnoxious67
Baby steps...
bobnoxious67's Avatar
Oddometer: 2,806
So...a KTM RFS is a better dirt bike AND a better road bike than a DRZ...and can be had used for the same amount of money.
Why do people keep insisting DRZ's are a better choice? For ANYTHING?
Field and Forest Recreation Area
'00 640 ADV, '01 Girlie, '09 TE450
bobnoxious67 screwed with this post 10-06-2012 at 04:05 PM
bobnoxious67 is offline   Reply With Quote
Old 10-06-2012, 05:17 PM   #48
HighwayChile
Oddometer: 4,404
I spelled it out for you in the above post.
and same $? not for me but spend as you please
Old 10-06-2012, 08:32 PM   #49
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
The DRZ is only better as a daily rider, as it does have longer maintenance intervals.
It also will hold more luggage.
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 10-06-2012, 10:39 PM   #50
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 11,360
And also this thread was started 4 years ago. KTMs were a bit more expensive, less tested, more mysterious, exotic.
Riders now know the scoop.
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is online now   Reply With Quote
Old 10-07-2012, 06:47 AM   #51
bobnoxious67
Baby steps...
Oddometer: 2,806
I know...I ride Euro
I know how old the thread is...someone chimed/bumped it before me, and I gave a sarcastic rebuttal
The only pro a DRZ has over an RFS is listed oil change intervals. Period. Reliability is the same...unless used in the dirt, where the KTM will likely prove to be more reliable.
Old 10-07-2012, 08:24 AM   #52
HighwayChile
Oddometer: 4,404
Ive rode em both, I stand by my opinion,( read it before you post ) which is correct.
A modded E as I described is a total diff' bike then a stock S, but hey you dont want to hear that either
Old 10-07-2012, 08:41 AM   #53
Shooter1
Shooter1's Avatar
Oddometer: 469
DRZ or EXC
I've owned two DRZ "S" models, (modified) and three EXC450's all tagged and still have the '07. I've found them all to be comperable in reliability. The EXC is quite a bit better on single track simply because it quite a bit lighter. I kept going back the the KTM since I have good local dealer support, and I have a couple off road riding areas close that I can easliy ride the bike to, ride, and then ride home. Both the "S's" I had were good bikes. If I could only own one bike and wanted it to be a 400/450cc class dual sport, and I intended to ride it alot on the street, I may have stuck with the DRZ. I never found the EXC's to be more maintenance, but, I'm not putting big street miles on mine either. If Suzuki could take 15 to 20# off the DRZ, and add a 6th gear, -OR- just space out 4th and 5th gear a bit, that would help a bunch. Both are very good bikes for their intended market.
-Harvey
#1017
'00 FXDX SG Sport, '06 300XCW,
'07 EXC450, '01 640 Lc4E
Shooter1 is offline   Reply With Quote
Old 10-07-2012, 10:34 AM   #54
bobnoxious67
Baby steps...
Oddometer: 2,806
I didn't see where you stated anything. The RFS is better in the woods, as you stated...and the RFS has a better gear spread and more power, with plenty of baggage options for a small dual sport being used as a local commuter, making it better on the street...and they're the same money and reliability...what exactly is your point?
If you just come out and say "I just like DRZ's better, and don't really have a good reason for it", I could at least respect that...but it has no merit as an opinion in this thread
Originally Posted by 955616846 View Post
FFS! Ride whatever gives you wood!
See above
Old 10-07-2012, 06:59 PM   #55
HighwayChile
Oddometer: 4,404
bob I see why you have your online name, you've earned it.
my post describing differences may just be too many words for you to comprehend, like the part "the more relaxed DRZ's geo' mean its mo' betta on open road, FS roads etc." I've spent considerable time on both, have you ridden a modded E ?
did u read where I say the ktm's are better? that the DRZ modded E is the shit for what I do with it?
on second thought, never mind, doesnt matter what I write, you have to be right, have the last word, huh?
I'm done, fire away. you are wasting my time.
Old 10-07-2012, 11:13 PM   #56
DR650SEDDY
ride2discover
DR650SEDDY's Avatar
Oddometer: 4,026
That said it all. For the $$$ u spend u get more out of DRZ-e. Ktm are more dirt oriented where DRZ ( E version) are more like the Transformers
DR-Z440E 00 - DR650SE 02.
Je ne suis Jamais a l'aise que lorsque je termine mon parcours, parlant d'Enduro bien sure. "DR650sEDDY".
DR650SEDDY is offline   Reply With Quote
Old 10-07-2012, 11:30 PM   #57
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,704
a shiny child's toy?
none of us is as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 10-08-2012, 05:47 AM   #58
bobnoxious67
Baby steps...
Oddometer: 2,806
Ahh...the classic name calling and whining of someone who can't come up with a valid and well spoken rebuttal. Well done.
"Relaxed ergos"? Really? Because none of that shit is adjustable?
Another blanket opinion based statement with no basis in facts, or proof to back it up...from where I'm sitting, the KTM is way more versatile than the DRZ. But that's not the point of this thread...the thread is about reliability between the 2.
bobnoxious67 screwed with this post 10-08-2012 at 05:53 AM
Old 10-08-2012, 09:48 PM   #59
nova2666
nova2666's Avatar
Oddometer: 12
Originally Posted by Off the grid View Post
The KTM and DRZ are similar in reliability but the KTM BLOWS the DRZ away in every conceivable category....power, suspension, brakes, parts, weight, gearbox, etc etc etc.
How is this even a question?
People buy DRZs because they don't know enough about KTMs or are scared because they listen to people that don't know what they are talking about.
A 04-07 KTM EXC will be similar in price as well.
Not true. I own a DRZ400E and a KTM 640 Adv. It is frustrating as hell trying to get parts for the KTM. It is very nerve racking wondering if it will be fixable on the road and being able to get parts. Would I own another KTM? Not quite yet. Maybe one but never two at the same time without a Suzuki or a Honda as a back up.
nova2666 is offline   Reply With Quote
Old 10-08-2012, 10:18 PM   #60
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,837
It must suck to live where you are then.
I have never had a problem getting any parts for any of my KTMs, yet the Jap bikes I have to wait weeks for.
There a lot of interchangeable parts in the different KTMs, but the Jap bikes have bugger all interchangeable parts and a lot of model specific parts.
Not that it matters considering my KTMs have needed much fewer parts than any other bikes I have owned.
But as I said before, it is a moot point because this thread is redundant...
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Times are GMT -7.   It's 12:34 PM.
