Old 02-05-2008, 10:36 PM   #1
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Leading Link Designs - Post Pics
Well this should create some responses . . . .
I am in the process of designing a set of Leading Links for a R series frame.
I have so many pics which I have collected for inspiration.
Lots of Different solutions to the problems that can arise.
Name:  DRz 400 LH leading link.jpg
I like this design from an offroad DRZ400 from South Australia.
Things to consider is what type of tube to use.
Seamless Steam Pipe or Crome Moly?
Then tube dimensions and wall thickness.
The leading swingarm can be either straight or bent as above?
I will keep posting images and if you have any please post and details and thoughts.
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Old 02-05-2008, 10:37 PM   #2
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Name:  3wheeler-links (Medium).JPG
Airhead Tragic
Old 02-05-2008, 10:39 PM   #3
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Laverda.
Airhead Tragic
Old 02-05-2008, 10:40 PM   #4
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Airhead Tragic
Old 02-05-2008, 10:41 PM   #5
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Airhead Tragic
Old 02-05-2008, 10:43 PM   #6
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Airhead Tragic
Old 02-05-2008, 10:44 PM   #7
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Airhead Tragic
Old 02-05-2008, 10:46 PM   #8
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Airhead Tragic
Old 02-05-2008, 10:48 PM   #9
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Cant forget HogWilds front end
Airhead Tragic
Old 02-05-2008, 10:49 PM   #10
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Airhead Tragic
Old 02-06-2008, 01:03 AM   #11
claude
Sidecar Jockey
Oddometer: 3,715
Reply:
Heavy wall moly
Reply:
Bent swingarm allows use of a longer shock while maintaining the relationship between axle height and swingarm pivot point to be what you want.
Other things to consider:
Do you want floating calipers or not?
How much trail do you desire?
Do you want the trail to be adjustable?
What to use for pivot bearings?
Which method to mount shocks on fork tubes?
At what point on swingarm to provide pivot?
Claude
http://freedomsidecars.com/
Old 02-06-2008, 07:47 AM   #12
Uncle Ernie
Uncle Ernie's Avatar
Oddometer: 3,978
What is that top bike up there, please?
LOOK OUT IT'S COMING THIS WAY!
Uncle Ernie is offline   Reply With Quote
Old 02-06-2008, 07:54 AM   #13
Uncle Ernie
Oddometer: 3,978
OT, but how do thises sub-titled sobriquets appear under our names?
I never thought of myself as the adventerous type. Gnarly perhaps ~
And Mr Pez can't ride?
Just curious
Old 02-06-2008, 03:06 PM   #14
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Ernie
Its from a DRZ400 outfit in South Australia
Name:  DRz400 road trial outfit.jpg
Airhead Tragic
Old 02-06-2008, 03:31 PM   #15
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,772
Originally Posted by claude
Pezz wrote:
Reply:
Heavy wall moly
Looking at the Racetech Catalogue 38.1mm X 6.35mm (1 1/2" x .250") Racetech 650. Should be sufficient.
Floating - My plan is to run Monobloc R1 Callipers. 2 on the 1 disc
40mm +/- 2mm
Hadnt really thought about adjustable Trail? Do you have any Pics?
Havent decided as yet? Suggestions??
Welded Brackets, with the weld on the outside of the tube, even If I have to make a larger top mount to accomodate.
Picture below from Tony Foale's 'Motorcycle Handling and Chassis Design'
Name:  Welding (Medium).JPG
At what point on swingarm to provide pivot? This is interesting question. and this is where I would like to hear any advice. I have seen many different variations. Anywhere from behind the tyre to close to the axel. With shock mounted in as many various locations in between, I have seen one that was in front of the axle and a linkiage type that was behind the swingarm pivot.
Also to be considered is how much travel is required, and can that be adjustable. We have some great roads in the outback and I want to travel them as well. This will dictate what shocks to use and where to locate the bottom mount
Airhead Tragic
Times are GMT -7.   It's 05:24 PM.
