Old 04-27-2010, 08:11 PM   #181
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,353
Originally Posted by RedMenace
If the handling is improved and you like it, and you don't have all sorts of shimmy, I'd guess it is a good mod for your set up.
Since you know the forks have seen some stress and they are old parts to begin with, keep a close eye on them for signs of failure. Rust lines or cracked paint are often signs of an underlying break.
Replacing the missing brace seems like a good idea, providing your welder know how to do that without weakening the metal or warping the forks.
You might be able to run a bolt and spacer through the unused spindle hole to improvise a brace until you can make a better, more permanent repair.
I have 2 certified welders working with me...also have a wire feed and a conventional welder on my worksite...I am a "birdshit" welder so I'll likely let one of my co-workers take a look at it.....
Any special type of tubing I should use? .....wall thickness?
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 04-27-2010, 08:20 PM   #182
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,263
I think I have to defer to Claude or one of the other more experienced builders here. I tend to make it up as I go along, and this might merit a more careful approach...
" I need to stop talking and start drinking" ...Mom
RedMenace is offline   Reply With Quote
Old 04-27-2010, 08:22 PM   #183
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,353
Not to worry, I'll just hack up an old sign post and weld'er in.....
ABC# 1992
Old 04-30-2010, 10:15 AM   #184
claude
Sidecar Jockey
Oddometer: 3,779
As long as that old sign post is pretty beefy it should work for ya.
The idea is to tie the down tubes together for stability to take the reponsibility off the pivot points. At least 1" diameter tubing with say a .120 wall thickness would be good....larger tubing or maybe two tubes above one another or a single tube with a couple of gussets would be better yet. It ain't just the tubing it is how much actual weld area you can get at the intersections. More weld area means a beter connection. Nothing is ever any stronger than it's weakest point.
Best to save the old sign post for a rack or somehting...or maybe even a sign
Claude
http://freedomsidecars.com/
Old 05-01-2010, 06:52 AM   #185
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,353
Thanks Claude....Snooping around on other sites I've seen numerous other modified BMW Earls missing the center braces. Must be a common activity to remove them for clearance issues and not reinstall them. I'll definately rebrace mine.
ABC# 1992
Old 05-01-2010, 08:14 AM   #186
RedMenace
Adventure Sidecar
RedMenace's Avatar
Oddometer: 5,263
It was very common to remove them. They could interfere with the timing cover when you fit a larger, newer airhead into a /2 frame. Sometimes you could get away with flattening or grinding the back side of the brace. I had conversion project that actually cleared the timing cover with no modification. There seems to have been some variation in production. I have never heard of one failing, but
simply removing the cross member and then stuffing in a heavier motor that made twice the horsepower seems like a reckless modification....
Old 10-13-2010, 07:33 PM   #187
Pezz_gs OP
Cant ride for crap
Pezz_gs's Avatar
Oddometer: 3,786
Well there hasnt been much on here lately, so . . . Bump
Airhead Tragic
I'm not a complete idiot -- Some parts are missing
XR460/4 - http://www.advrider.com/forums/showthread.php?t=497905
Pezz_gs is offline   Reply With Quote
Old 10-26-2010, 03:41 AM   #188
OldDog
Smelly Adventurer type
OldDog's Avatar
Oddometer: 4,652
Indeed, who in their right mind would fit bent forks to a bike!
Seriously though, something i havn't seen is Girder forks, wouldn't they do the same job? Something a bit like this (without the chrome and shit) http://cgi.ebay.com.au/GIRDER-SPRING...item483bb871c3
Your time is limited, so don't waste it living someone else's life. - Steve Jobs
Yesterday afternoon I was planning to ride Dakar, this morning I was planning to throw up in my helmet - Boris Mihailovich
Objects in the rear view mirror.....appear to be losing - Me
OldDog is offline   Reply With Quote
Old 10-26-2010, 06:05 AM   #189
pops
Oddometer: 1,576
A few photos of our new L Link front end on our 1150 gsa .
Still working out the best settings .
Cheers Ian.
pops is offline   Reply With Quote
Old 03-26-2011, 08:32 PM   #190
FUTURE
Left right out
FUTURE's Avatar
Oddometer: 742
Can't remember if I have put this up in this thread before. Bob Martin Leading Link that was fitted to my Virago 1100.
Me WnRn blog.....http://rossmz.blogspot.com/
"el Lobo" 2002 1200 Bandit... For sale
1971 Honda CL450 being brat'ed/cafe raced.
2009 Triumph Speedmaster.
FUTURE is offline   Reply With Quote
Old 03-27-2011, 10:04 AM   #191
claude
Sidecar Jockey
Oddometer: 3,779
Here is one we are just finishing up for a VStrom.
Hope to be doing one on a GS1100 soon.
Claude
Old 03-27-2011, 02:04 PM   #192
Grotmeyer
Grotmeyer's Avatar
Oddometer: 84
Beauty Claude!! Someday I'll have a rig worthy of one of these.... Someday....
Grotmeyer is offline   Reply With Quote
Old 03-27-2011, 07:32 PM   #193
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,957
Hey I would LOVE to have that fork Claude !!,My VEE is blue even..If I find an extra $3,000 laying around I will hit you up for one !!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is online now   Reply With Quote
Old 04-20-2011, 01:21 AM   #194
downunder123
Oddometer: 32
These are mine, in the metal:
and after powder coating:
downunder123 is offline   Reply With Quote
Old 04-20-2011, 12:14 PM   #195
gordonscott
gordonscott's Avatar
Oddometer: 158
leading link
Here is the leading link front end I made for my xs650 outfit. It is 1.375" DOM tube .188 wall thick. Brass bushings with grease fittings and 16 3/4" sandrail shocks. I also cut off the axle plates from a stock swingarm so I can adjust trail
gordonscott is offline   Reply With Quote
Times are GMT -7.   It's 12:42 PM.
