02-06-2008, 02:55 PM
#16 |
Ok Human Let's Ride!
Oddometer: 6,392
Pezz, good thread, I'll post some pics tonight, I've got a few in the collection
K7 Strom with Chair 84 Kwaka GT750 Cafe Project 84 Kawaka GT750 Outfit Project |
02-06-2008, 07:21 PM
#17 |
Tripod
Oddometer: 4,580
Wow! Stunning pictures... They are artwork in their right!
I used to be an adventurer like you, until I took a Hyundai to the knee... |
02-06-2008, 08:35 PM
#18 | |
Oddometer: 3,978
Just double checking- this is a DRZ400?!
LOOK OUT IT'S COMING THIS WAY! |
02-06-2008, 09:07 PM
#19 |
Scott Whitney
Oddometer: 2,231
Here's a better view of my frontend as it was a couple of years ago. Since then I've pushed the axle forward 2.5cm, and removed the extra fender mount that pivots at the swingarm pivot point. Now the fender is completely supported by a bracket off the back loop on the swingarm. Notice the two mounting positions for the swingarm pivot. For racing the pivot can be moved to the rear position for better handling in deep sand conditions.
02-06-2008, 09:35 PM
#20 | |
Cant ride for crap
Oddometer: 3,390
Pezz :) Scrapheap Adventure Ride 2013 - Back 'O Bourke www.scrapheapadventureride.com.au I'm not a complete idiot -- Some parts are missing |
02-06-2008, 09:40 PM
#21 |
Cant ride for crap
Oddometer: 3,390
02-06-2008, 09:58 PM
#22 |
Left right out
Oddometer: 738
Pezz we might have known each other. Were you in the Sydney Sidecar Owners club?
Here is my LL. Bob Martin made... ![]()
Me WnRn blog.....http://rossmz.blogspot.com/ "el Lobo" 2002 1200 Bandit... For sale 1971 Honda CL450 being brat'ed/cafe raced. 2009 Triumph Speedmaster. |
02-06-2008, 10:47 PM
#23 |
Newfie Rocketeer
Oddometer: 84
I put the leading link front end together for my Bandit 1200 during the winter of 2004-2005. I started off with a bare 15" EZS front wheel assembly and fender imported from the UK and Charnwood Restorations.
Keep in mind, i had minimal power tools/equipment to do the job - a hacksaw, hole-saws, drill-press, hand-drill, lots of files, and a bench and hand-grinder were about it. Surprisingly little was farmed out to a machine shop to complete. I'm a social worker, not a machinist, but i had a whole winter to do my research and do the project correctly - essential with such a safety related component to do right the first time. ![]() My design was going to incorporate floating calipers. These brackets were cut by hacksaw, and finished with lots of hand-filing. These as pictured were at about the 50% stage. ![]() The start of the swingarm. The axle bosses are machined billet roundstock, and slipped into the ID of the pipe. The pipe used on the project was .188 wall 1-3/4" DOM tubing. due to the size of this tubing, i elected to build a 3 piece swingarm fork, welded up. Why? It suited the design to come, of the adjustable bearing block shoes mounted to the swingarm for the downtubes. The tubing is in a homebrew welding table to keep things lined up and square during welding. ![]() The wheel assembly/swingarm of the leading link coming together. The brake calipers are fully floating at this stage. The adjustable bearing block shoes for the leading link downtube pivot point have been machined also. The 6 pot Tokico calipers were way overkill for the front end, and weren't used in the final setup - i elected to use my 4 pot Nissin calipers in the final build. ![]() The next steps of fabrication moved rapidly. The 1-3/4" (44.5 mm) DOM tubing was lathed down to 43mm at one end of each, to slip through the bandits stock front fork trees. The downtubes were then cut, bent to desired angle, and welded with substantial gussetting at stress and vibration points. brackets were welded to the end of the downtubes to mate with the bearing block shoes on the swingarm. Tubework was fun. ![]() The completed front end back from the powder coaters, and fully installed on the Bandit. ![]() Some have commented that my front end has an industrial, somewhat overbuilt appearance - I live by the motto of "when in doubt, build it stout".. I had a whole lot of doubts in entering this project, so it was overbuilt to the point that any doubts about it's strengths were removed from my mind.
'99 Suzuki Bandit 1200 / '88 Hannigan Comet sidecar '81 and '82 Honda C70 Passports '76 Lif-Honda CT140 MiniTrail http://www.chairintheair.ca Bandit Bill screwed with this post 02-06-2008 at 10:57 PM |
02-07-2008, 02:08 AM
#24 |
Cant ride for crap
Oddometer: 3,390
Here is a pic of my old Z1300 I built in 1994. !983 Carby Model with a HRD Grand Rally Double. The links were made by Terry Gunter in Wollongong. Talk about Transforming the bike. 100mph 1 hand on the bars. sweet!
02-07-2008, 04:25 AM
#25 |
I used to be SCRay
Oddometer: 3,900
G'day Pezz.
I saw a set on a BM on the road out from the TTT one year. Snapped off at the lower triple clamp. They were made by some bloke in the 'gong who 'knew what he was doing'. ![]() Wrote off the BM engine. The rider nearly got skittled by the front end flapping around beside the bike as it ground the sump off coming to a stop![]() ![]() ![]() The legs had been turned down from some sort of pipe so that they would fit into the triple clamps ![]() ![]() ![]() ![]() ![]() ![]() ![]() and ![]() If you like, I could quiz Leigh Hollamby about materials, or you might find his adv in a mid '07 copy of Aust Road Rider. Not that you'll be having a set made but, he's not taking on too many outfit jobs any more - got other things to do. And for those others that would like to see his handy work. The DRz400. My Triumph Tiger and these trailers...sorry, I'm still not certain how to link directly to my smugmug account, so this may just be a link, ranther than the photo. http://SCRay.smugmug.com/photos/251837822-L.jpg
rayb I taught Wall St how to crash Australian RD/RZ Owners Register http://tripodtiger.smugmug.com/ |
02-07-2008, 04:36 AM
#26 |
I used to be SCRay
Oddometer: 3,900
http://scray.smugmug.com/photos/251837822-S.jpg
OT -Am I doing something wrong here??? Gimme a break, I'm a middle aged Learner! Those links that Bob Martin built - there is certainly no style to them, eh?
02-07-2008, 05:21 AM
#27 |
Sidecar Jockey
[QUOTE=sidecar_ray]G'day Pezz.
I saw a set on a BM on the road out from the TTT one year. Snapped off at the lower triple clamp. They were made by some bloke in the 'gong who 'knew what he was doing'............snip >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Dunno but that sounds similar to what is pictured below. Pretty scary !!!!!!! Material too thin? Welding issues? Bracing in wrong spot? All of the above? Yikes!
Claude Founder: Internet Sidecar Owners Klub at SCT http://autos.groups.yahoo.com/group/SCT/ President: C Stanley Motorsports Inc. http://autos.groups.yahoo.com/group/...rsandTrailers/ http://freedomsidecars.com/ |
02-07-2008, 01:22 PM
#28 | |
Africatwinarama
Oddometer: 9,761
1990 RD04 Africa twin 750 350,000km and still going strong |
02-07-2008, 02:05 PM
#29 | |
Cant ride for crap
Oddometer: 3,390
02-07-2008, 02:15 PM
#30 |
Cant ride for crap
Oddometer: 3,390
How much Travel does everyone have on their Leading Link Suspension ?
I have been looking at the Ikon (koni) shock specs and working backwards to establish swingarm length. Probably going to look at 200mm (8") as a starting point
