Old 02-11-2008, 10:04 AM   #1
the white rabbit OP
Vicarious
the white rabbit's Avatar
Oddometer: 3,051
Beta RR /RS 4T enduro thread
If I may be so bold I think a thread for Beta related info might be a good idea as a few of us have or are thinking about them. Perhaps then some resource may build. There's short threads here, on TT and elsewhere but the info is patchy.
I don't actually know what I am talking about when it comes to thumpers so I am hoping for incoming faq and ideas although perhaps collecting info here I find out as well as what others know may be a help generally.
A Beta sign in thread if you may
Some resources:
The official website for Betamotor and for the RR 4T.
The Beta RR 4T Enduro information source, tech, how-to, cross referencing...very useful. Looked after by Scud.
American Beta the US importer.
Beta UK , Lampkins UK importer (mostly trials bikes but enduro too).
Thumpertalk, Exotics section a few threads.
Of course the engines are KTM and so far it looks like they are a straight bolt in so no Beta specific issues at least in the motor department. So KTM info directly relevant.
What is this thread about? These, in 400, 450 and 525 cc
The RR above. The RS is the same but has road kit on installed.
'These are the hardest conditions I have made a basket like this in' Ray Mears
the white rabbit screwed with this post 03-10-2008 at 01:03 PM
the white rabbit is offline   Reply With Quote
Old 02-11-2008, 10:12 AM   #2
the white rabbit OP
Vicarious
Oddometer: 3,051
My 07 400RR
Old 02-13-2008, 02:54 AM   #3
the white rabbit OP
Vicarious
Oddometer: 3,051
First post about oil
This is the 400 RFS engine in mine and my dealer is recommending Motrex Cross Power 4T 10W50 fully synth.
The manual is contradictory in places and recommended Motrex Cobra 15W40 for one, which does not seem to be available any more, so I am going with the 10W50.
I know oil is one of those emotive things
the white rabbit screwed with this post 02-13-2008 at 06:24 AM
Old 02-13-2008, 08:23 AM   #4
kenaroo
I am because i ride
kenaroo's Avatar
Oddometer: 831
Remember it's a KTM motor. tons of experience with those over at KTM talk.
I'd stick to 10 w 50 as well if I were you
what does your garage look like
http://www.garage-interiors.com
kenaroo is offline   Reply With Quote
Old 02-13-2008, 01:34 PM   #5
the white rabbit OP
Vicarious
Oddometer: 3,051
Ok, so just starting to ahve a fiddle about with the 400 now.
Just swapped over from the Beta handguards to Acerbis Rallypro wrap arounds.
I took a chance on the Renthal fatbar kit, and it does fit on the black Betamotor branded bars made by Reikon on the 07. Unsure what bars are on the pre-07 models. Trim to end of throttle tube required and bit of padding against abrasion of clutch line on guard metalwork seems a good idea as this needed rerouting slightly.
Also while in that region worth checking the wiring to the starter, mine had chaffed where it had been slipped under the bolt attaching the starter unit.
the white rabbit screwed with this post 04-13-2008 at 02:44 AM
Old 02-13-2008, 01:36 PM   #6
the white rabbit OP
Vicarious
Oddometer: 3,051
Old 02-19-2008, 11:27 AM   #7
the white rabbit OP
Vicarious
Oddometer: 3,051
The clutch lever on the 07 is an AJP long lever old type and the brake a Nissin compatible, short from stock I think.
The long clutch is a bit of a nuisance with wrap-around guards. I am sure many types fit but these aftermarket ones for the Beta trials bikes certainly do. Adjuster screws are slightly better on the stock levers but swap over.
http://www.trialcast.co.uk/betalevers.htm
I guess the news is that something pretty bog-standard swaps on ok. Probably a complete unrevelation to most
the white rabbit screwed with this post 02-22-2008 at 12:42 AM
Old 02-21-2008, 04:45 PM   #8
PozoRider
Just Ride
PozoRider's Avatar
Oddometer: 209
08 525 rs
Here are a few fotos of my 08 525 rs.
IMS Tank:
Enduro Engineering Hand Guards:
GPR Under Bar Mount:
Rich Reyes
2011 Beta 520 RR
2009 KTM 690 Enduro R
Dick's Desert Dash
American Beta
PozoRider is offline   Reply With Quote
Old 02-22-2008, 12:41 AM   #9
the white rabbit OP
Vicarious
Oddometer: 3,051
Neat. You are right the EE handguards do seem to fit on there very well.
Old 03-10-2008, 01:43 AM   #10
the white rabbit OP
Vicarious
Oddometer: 3,051
Clutch / case savers
I found the KTM 400 RFS clutch saver bolts right on but there are issues (which Pozorider pointed out). More about this add-on a bit later.
I was surprised to find no chain bar though.
the white rabbit screwed with this post 03-15-2008 at 03:03 AM
Old 03-10-2008, 10:07 AM   #11
CrankyCoyote
scud no more
CrankyCoyote's Avatar
Oddometer: 100
I've got Cycra Pro-Bends on mine; get the KTM parts and everything "just works".
I use Rotella-T Synthetic 5w-40 as the engine oil. None of the nasty car friction modifiers to mess up your clutch, full synthetic, seems to work pretty well, and it's less than $10/qt.
You guys mind if I add your bike pictures to the gallery at http://www.betamotorcycles.net? Credited however you want, of course.
CrankyCoyote is offline   Reply With Quote
Old 03-10-2008, 11:15 AM   #12
the white rabbit OP
Vicarious
Oddometer: 3,051
Good to see you here on this thread Scud, and use my pic certainly. I will get some more up as soon as I can actually get out on the thing.
You have email as well
Old 03-10-2008, 10:19 PM   #13
mcnut
Oddometer: 1,365
Beta has really stepped it up for 08. The bikes look to be more refined, a new hard parts catalog and more dealers.
MCNut
mcnut is offline   Reply With Quote
Old 03-15-2008, 03:02 AM   #14
the white rabbit OP
Vicarious
Oddometer: 3,051
I have been after a specific clutch saver but no luck over here. For the US STR are producing them, American Beta (Pozorider, thanks) tell me.
So I have used the appropriate KTM one, for me for the 400 RFS and Scud tells me he used the 525 one which also fits. None of this unexpected as they are KTM lumps.
However, the Beta's do not have a chain bar, and so a few washers are required to pack out the gap where the chain bar would be on the top right mount point. Seems fine. The sprocket cover will fit right back on, although it does protrude a mm or two more than without the cover. I guess it could be trimmed a little to fit round the saver but I havent worried as yet as it refuses to bend back in tight as I obviously deofrmed it a little slipping the cover in behind it rather than taking it off.
Only snag is it is orange
I may consider making a chain bar, unless anyone knows if the KTM one bolts right one, unlikely I think due to frame differences.
Edit..I have noticed that there has been some contact between the chain and the cover, they are quite close. Anyway I guess the chain will soon wear the soft ally if it is that close. After some use it seems fine.
Edit 2, the plastic sproket cover is actually very thick where the chain bar would be on the equivalent KTM, so may not need one really.
the white rabbit screwed with this post 05-27-2008 at 03:14 PM
Old 04-13-2008, 02:46 AM   #15
the white rabbit OP
Vicarious
Oddometer: 3,051
Some pics as of yesterday (before I mullered the front rim trying to change the tyre )
Times are GMT -7.   It's 11:30 PM.
