Old 02-20-2013, 08:32 PM   #391
velocityjunky
velocityjunky's Avatar
Oddometer: 221
Originally Posted by MartiniUp View Post
If buying again would you still pick the 350 over the 450 you rode, suspension being equal? Thanks.
My intended riding is 99% dirt 1% street and i like trails that are tight and fast, I want manageable power that I can ride hard, instead of the bike riding me.
So yes, I have yet to take it on any of my normal trails since it is still winter. however I think the 350 is the perfect size for a 4 stroke, has plenty of bottom and revs really nice. There are times where i wish it had more power in the open stuff (im also at elevation), but in the tighter stuff it is a gem. Ill give up topend to have something that i can get aggressive with in the tighter stuff. the 450 was ridden about a year ago so its hard for me to compare, but the 350 feels very nimble and steers very well, my guess is the tighter it gets the better the 350 would work over the 450.
Last weekend I rode it back to back with a ktm 350xcf (not w), and the ktm has quite a bit more in the power department, but is very vibey, by comparison, and wants to shudder and stall constantly in the tight stuff.
The beta is super smooth and is way more tractable on the bottom. the ktm still wins the chassis/suspension wars and works better the faster you go......but you could not get me to trade because the beta makes stuff easy and fun while still very fast, the ktm just feels like more work and less fun.
Motorcycles- The best way to turn money into smoke and noise.
velocityjunky screwed with this post 02-20-2013 at 08:43 PM
velocityjunky is offline   Reply With Quote
Old 02-21-2013, 08:46 PM   #392
jcshew
Oddometer: 33
New 520rs!
Hello all:
I just bought a new, left over CA model 2012-520RS. I got a great deal (I think). Asking price was $9,399. They let it go for $8,200, to make room for the 2013s coming in. They also had a brand new 09-525RR for $6,300! Thought about it for a few minutes, but I really wanted the dual sport.
Now I have some extra cash to personalize it…… Let the modifications begin!
These are the mods I’m planning right away:
3.8 Gallon Tank
Gutz Soft Seat Foam
Rekluse Auto Clutch
JD Jetting Kit
48t Rear Sprocket
Scotts Steering Damper
Double Take Mirrors
Replace the Pirelli MT21s
Hand Guards (of course)
**Maybe an FMF Q Pipe? Do you need it to get all the benefits from the JD kit?
I’m going to ride it for a while before making any decision on suspension mods. Is there anything else that I should do right away? Any other bugs to take care of that's missing from my list?
I look forward to any advice you may offer.
jcshew screwed with this post 02-21-2013 at 08:55 PM
jcshew is offline   Reply With Quote
Old 02-21-2013, 09:33 PM   #393
offworlder
Oddometer: 256
Picked up my 2012 450RR today !
As its just left the crate it shipped in from Italy, I've pulled the carb stop, and the AIS (emission) filter.
I do want to check every nut and bolt, but the manual doesnt have the torque values ! Any one know where to find these ? I'm thinking I should grease the linkage, check the steering head and wheel bearings (for adequate grease), anything else ?
Thoughts on run in ? The manual states:
RUNNING-IN:
The running-in period lasts approximately 15 hours, during which it is advisable to: 1 During the first 3 hours of operation the engine should only be used to approxi- mately 50 percent of its power. In addition, the engine speed should not exceed
7,000 rpm. 2 For the next 12 hours of operation the engine should only be used to about 75
percent of its power. 3 Use the vehicle after properly warming up the engine. 4 Avoid travelling at constant speed (changing the speed causes the different com-
ponents to bed in evenly and more quickly). This procedure should be followed each time piston, piston rings, cylinder, crankshaft or crankshaft bearings are replaced.
WARNING After the first 3 hours or 20 litres of petrol change the engine and gear oil.
PS: I may consider pulling the cat out at some point, but want to try it stock.
Thanks.
offworlder is offline   Reply With Quote
Old 02-22-2013, 04:21 AM   #394
SCExpat
Ex-expat
SCExpat's Avatar
Oddometer: 634
Originally Posted by jcshew View Post
My riding will be 80-90% dirt : 10-20% street. I have a 06 YZ250 2t for 100% off road and enduro racing. I'm probably going to install the Rekluse auto clutch on the 520, and if it works out well, I'll probably use the 520 for everything.
With the 6.9 gallon tank on my XRR, I and can ride a 250+ mile loop without having to stop for gas. I'd like to have a good idea what the mpg is for the 520, so I can plan my rides. I know the mpg depends on speed and terrain, but if anyone can give me an average mpg, Id appreciate it.
I dont understand the manufacturers sell their DS bikes with those itty bitty 2 gallon tanks!
I am thinking that as much as I like the 520RS it is just a bit more dirt oriented that what I'll be doing with it. Looks like I'll stick with the DR650.
Hello all:
I look forward to any advice you may offer.[/COLOR] [/COLOR][/SIZE][/FONT]
Did you get the one in/near Sacramento? I saw that and was really tempted. But.....I'll be doing about 50/50 dirt/street so.....congrats on a great deal on a great bike. I still want one.
RUNNING-IN:
Thanks.
I am a fan of the Motoman method. http://www.mototuneusa.com/break_in_secrets.htm
Maybe a bit controversial but it makes perfect sense to me.
As for the bolt torque....are you really going to go over every nut and bolt with a torque wrench? If you really feel the need to maybe after the first ride or two you could take a wrench and make sure they are still snug. Small bolts get small torque and big bolts get big torque. Don't over torque and don't leave any loose. Have fun.
SCExpat is offline   Reply With Quote
Old 02-22-2013, 07:53 AM   #395
jcshew
Oddometer: 33
New 2012 520RS
Yes, that's the place. I was surprised find one there. I do 80-90% dirt / 10-20% street, so I think it will work out well for me. From my first impression, I think I can even do enduros with it, although, my 06 YZ250 is perfect for those.
I noticed the literature for the 2013 says the frame has been Updated with a lower cross brace and larger diameter lower cradle tubes. I wonder if that will make much of a difference in the handling compared to the 2012?
Old 02-23-2013, 04:55 AM   #396
SCExpat
Ex-expat
SCExpat's Avatar
Oddometer: 634
I think you have the perfect bike for what you want to do. A good deal too.....thanks for removing that temptation......I think.
Just got a DR650 but I still want a 520RS.......it never ends.
Old 02-23-2013, 06:01 PM   #397
offworlder
Oddometer: 256
2012 450RR starting issues ???
The maiden voyage of my 2012 450RR was somewhat scarred today by starting issues.
After zipping along happily, she would bog and then just die mysteriously. e-start wouldnt light her up - repeated attempts just kept draining the battery - kick start didnt seem to help either. Sounded as if she wasnt getting fuel.
- I'm wondering if this is a battery issue (ie: not enough charge to turn her over) ? After assembly (pour included acid pack into cells) I did charge the new battery, and according to the charger its healthy. Am going to charge it again, and check the voltage (manual states: "check that the voltage is greater than 12.6 V", and "...until the voltage between the terminals stabilizes at ~14.5 V")
- or could this instead be carb related ? What have other's done re the carbs ? ie: Have you left things stock (after removing the limiter), or found that the carb needs adjustment ?
- or could this be a starter relay issue ?
Thanks.
Old 02-23-2013, 07:46 PM   #398
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 215
First thing that comes to my mind to check would be the fuel tank vent hose might be pinched/blocked.
Interested in hearing what you find was the problem.
Dave
Thanks.
Husqvarna FE250...Street Legal
Rider1 is offline   Reply With Quote
Old 02-23-2013, 11:26 PM   #399
offworlder
Oddometer: 256
Dave
I did find the one way valve wasnt breathing (in either direction), just gonna pull it and leave the hose.
Scuse my daftness, but how can this cause the (described) problem ?
I'd like to know what other Beta owners have for a battery, and what voltage is present.
The battery that came with the bike is a YTX5L-BS, and the voltage after (fully) charging is 13.2V.
Old 02-24-2013, 06:25 AM   #400
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 215
The breather allows air in to the gas tank as fuel is used by the engine. If it didn't work....as it sounds like yours wasn't....as the gasoline was used and NOT replaced with air a vacuum would result and fuel won't gravity flow to the engine from the tank.
By removing your one way valve did that fix the problem ?
I replaced the stock battery as you indicated above with a Turntech 5.0 amp lithium ion battery. It allowed me to start my Beta while in gear....once bike is up to operating temp. When it is fully charged it shows 13.4 volts but it's probably a whole different ball game than lead acid type batteries . I don't know.
Dave
Old 02-24-2013, 10:35 AM   #401
offworlder
Oddometer: 256
Dave
Thanks much for that description R1 !
That would jive with the bike sounding like it was starved of fuel, and explain why 5-10 mins later it would start (air leaking in ?) Will confirm the issue resolved as soon as I can/next ride.
Re the battery, I've heard of the Lithium Ion batteries, but also heard that were not that great for cold starts (in Canachuk, so we do get lower temps). Did you have issues with your stock (YTX5L-BS) battery ?
Old 02-24-2013, 11:28 AM   #402
Rider1
Ridin' Dave
Rider1's Avatar
Oddometer: 215
The only "issue" I had with the stock battery was it didn't have enough oomph to crank/start the bike when it was in gear after warmed up to operating temp.
Yes, Lithium Ion batteries need a little "wake up" draw before they perform well in colder temps. Don't have cold temps where I ride :)
Dave
Old 02-25-2013, 06:48 PM   #403
WallyWhirled
WallyWhirled's Avatar
Oddometer: 854
Thanks.
You can probably solve the bogging and engine stalling problem by looking under your skid plate for a hose coming off your bike that has a plug and a clip on it. Remove that plug. Nobody seems to know what it does other than cause bikes to stall. I think the plug is supposed to prevent fuel leakage during shipping or something.
Regarding voltage, there is a fix that eliminates the AC/DC voltage switching it to DC only. The stator and regulator are replaced. I had Dave Turner at Get Dirty Dirt Bikes do this for my bike. He has since developed a plug and play version. I've gone through a whole lot of batteries and recommend using a battery tender. I've tried lead acid batteries, stock and aftermarket. Have had 3 different versions of Lithium Ion batteries. Right now I'm using the EarthX battery and like that one the best. Now if I can just ride enough or keep the battery on the battery tender......
KTM 950 Super Enduro, KTM 950 Adventure,
Beta 520 RS, Rickman Cafe Racer
WallyWhirled is offline   Reply With Quote
Old 02-27-2013, 09:06 AM   #404
astur
Oddometer: 15
Hello from Spain, I just bought a 2006 400 RFS beta (ktm engine), and I'm very happy, had a drz before, and this feels more Thin. As I put some pictures nice bag ... salu2.:
astur screwed with this post 02-27-2013 at 09:13 AM
astur is offline   Reply With Quote
Old 02-27-2013, 04:17 PM   #405
alphaBETAdog
alphaBETAdog's Avatar
Oddometer: 305
Nice photo Astur! Great bike and mountain scene. Thanks for sharing.
'13 Suzuki Vstrom 650
'08 Beta 450 RS
'12 Kymco Gti300, '03 Aprilia Scarabeo 150
alphaBETAdog is offline   Reply With Quote
Times are GMT -7.   It's 09:37 AM.
