Old 06-11-2010, 09:36 PM   #76
DRjoe
DRjoe's Avatar
Oddometer: 5,142
This is very impressive stuff.
How much travel have you managed to get out of the suspension?
Also I have done a small amount of alterations to my engine and frame on my dr and I ran into a few brick walls when I went to find out about registration. How are you going to register it?
Old 06-12-2010, 05:57 AM   #77
Pilbara OP
In the flow...
Pilbara's Avatar
Oddometer: 1,579
swingarm
Originally Posted by DRjoe
How much travel have you managed to get out of the suspension? 200mm +
[/COLOR]
Cheers
Pilbara
Pilbara is offline   Reply With Quote
Old 06-12-2010, 02:03 PM   #78
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,515
Gonna leave the drive shaft exposed?
marchyman is offline   Reply With Quote
Old 06-12-2010, 07:01 PM   #79
JeffinTD
JeffinTD's Avatar
Oddometer: 1,399
Thumb
Here's an interesting link about braze welding, if anyone is interested.
http://www.brazing.com/products/braz...0of%20join.htm
It looks like a good way to get a strong joint in 4130, as long as it isn't exposed to high temps that would weaken the filler, and in this application that shouldn't be a problem.
If I were attempting this I'd have to make some test joints and test them in the shop press and/or have them fatigue tested, but that's because I don't have the previous experience that the OP has.
Here, when someone says bronze welding, they are talking about joining pieces where the base metal is bronze.
Normalized 4130 tubing can be torch welded, or tig welded, but preheating may be required. A professional welder who is an expert in these steels would be a must have IMHO. One stray arc could cause a future crack. E70S2 would be a good choice, as opposed to 4130 rod. Heat treated 4130 would likely require heat treating the entire frame after welding.
Anyway, super-cool project. I can't wait to see how it turns out.
09 R1200GSA
JeffinTD is offline   Reply With Quote
Old 06-12-2010, 07:56 PM   #80
Richard M
Doesntplaywellwithothers
Richard M's Avatar
Oddometer: 564
Weld's not the issue!
Anyone that knows pilbra will know that the loose nut behind the handle bars is the issue not the strength of the welds
I'm sure his first ride out will test the weld strength, wont be a matter of if he crashes more the fact asto what speed ???????
Well done K
There isn't alot lot of Room on the Edge when you get up There.
Richard M is offline   Reply With Quote
Old 06-12-2010, 09:36 PM   #81
Pilbara OP
In the flow...
Pilbara's Avatar
Oddometer: 1,579
Exposed
Hello marchyman, not really thought about it, so it probably will remain exposed. Well see what happens...I can't see any problem with it being xposed and possibly better to keep an eye on the cush drive.
Cheers
Pilbara
Old 06-12-2010, 11:52 PM   #82
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,944
I think Pilbara's treatise on design is spot on.
Some day the motorcycle design and even the seating position will be changed, it's a throw back to riding horses after all.
Maybe when some suspension patents run out things will change?
On another note: if I had a pair of wheels like those I'd take them to bed with me!
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 06-18-2010, 09:28 PM   #83
Pilbara OP
In the flow...
Pilbara's Avatar
Oddometer: 1,579
Its on the floor...
Old 06-19-2010, 08:32 AM   #84
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,944
Looking at it, and in my humble opinion, I THINK THE FRAME WILL BE STRONG ENOUGH
Old 06-19-2010, 09:00 AM   #85
slartidbartfast
Love those blue pipes
slartidbartfast's Avatar
Location: Southern Louisiana or Southern England or ...
Oddometer: 4,886
I would suspect the rider will be the weak point in this design
MSF Ridercoach IBA: 35353 95 R1100GSA, 93 GTS1000, 85 R80RT, 93 DR350/435, 99 RX125, 78 DT100
January 2010 New Zealand South Island ride
Summer 2009 UK to Alps ride
Summer 2008 UK End-to-End ride
slartidbartfast is offline   Reply With Quote
Old 06-21-2010, 06:35 AM   #86
Mago
Growing Wiser..
Mago's Avatar
Oddometer: 273
Originally Posted by Pilbara
Is this the same bike you designed back in 2005?
Mago is offline   Reply With Quote
Old 07-06-2010, 04:06 AM   #87
cashelvale
Oddometer: 136
From now on.............
From now on you will be known to me as Bert Munro..........will there be a large bus parked in your front drive ???????
cashelvale is offline   Reply With Quote
Old 07-11-2010, 01:42 PM   #88
Pilbara OP
In the flow...
Pilbara's Avatar
Oddometer: 1,579
Hugh...
...amazing the power of the internet universe eh, thanks for the negative vibrations, the fibula has turned out to be a weak point and has now slowed progress on the project somewhat.
Still the anniversary model can now get a bit more attention to cosmetic detail. The pressure was on to have it ready for the Australasian Safari in September. Looks like I have as quoted become the weak point in that plan too.
The bike got wheeled around the other day (moving sheds) and the front suspension feels fantastic. Cant wait to try it for real.
Cheers
Pilbara
Old 07-11-2010, 01:51 PM   #89
slartidbartfast
Oddometer: 4,886
Sorry for the bad vibes - I meant, of course, to compliment the apparent strength of the frame Hope you heal fast.
Old 07-11-2010, 02:50 PM   #90
DRjoe
DRjoe's Avatar
Oddometer: 5,142
Harden the f*^k up and stop crying about broken bones.
Are you going to be able to replicate this frame after you've finished I'm sure Paul Rooney would be very interested in your design.
Times are GMT -7.   It's 02:52 PM.
