Go Back   ADVrider > Bikes > Beasts > Moto Bellissima: All Other Dualsports
Old 09-16-2011, 02:51 AM   #466
Tony T
Oddometer: 1,437
Fuel Range E750
Apologies if this has been covered before. I did a search but didn't find anything.
I'm about to take delivery of a '95 E750 and was wondering what sort of fuel range I could expect on reasonable dirt roads?
For a trip I'm contemplating, I would need 500kms.
I know I'm jumping the gun as I haven't even got the bike yet, but if I need to get rear tanks made, I might need some time to save up the money.
Also, does anyone make rear tanks to fit?
Thanks in advance.
Tony T is offline   Reply With Quote
Old 09-17-2011, 02:12 AM   #467
Samruay
ADV for ADV sake
Samruay's Avatar
Oddometer: 109
500 KM without refilling: mission impossible..?
Hi there,
I'm a lucky driver of the same ELEFANT model you're looking for
I would therefore say to get a fuel autonomy around 500KM (312 Miles) with this bike .. is not an easy job
you should update/change the original tank (5 gallons), since even adding the rear ones (hard to find) you'll probably do not meet your requirement...
In stock configuration, this bike permits you to safely ride approximately the half of the expected range
good luck
Samruay is offline   Reply With Quote
Old 09-20-2011, 03:38 AM   #468
Tony T
Oddometer: 1,437
Mmmm...... I might have some work to do then.
I didn't realise the fuel range was quite as bad as that.
Thanks a lot for the info.
Old 11-12-2011, 09:29 AM   #469
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 957
Does anybody know the front brake disk's minimum thickness. 750LE single disk.
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 11-13-2011, 03:26 AM   #470
Tony T
Oddometer: 1,437
My manual for my E750 states that the minimum thickness for both front and rear discs is 3.5mm.
I guess LE would be the same?
Old 11-13-2011, 04:30 AM   #471
Bill the Bong
Supern00ba
Oddometer: 957
Thanks Tony
Appreciate the info. I'm at 3.35mm. Shit
Old 11-15-2011, 02:07 AM   #472
Tony T
Oddometer: 1,437
Hey Bill,
These guys do replacements.
http://www.ebay.com.au/itm/METALGEAR...item2310610bf9
I guess there would be something closer to home for you though.
Happy to help if you need me to look up any other info.
Old 11-16-2011, 07:38 AM   #473
Samruay
ADV for ADV sake
Samruay's Avatar
Oddometer: 109
Originally Posted by Bill the Bong View Post
Thanks Tony
Hi there,
you could also consider the possibility to upgrade the front braking power substituting the original disk with a wave one (see picture below).
http://j-mart.biz/j-parts/images/Daytona/67117.jpg
Make:BRAKING
Model: HO23FID
Outer dia.: 296mm
Inside dia.: 144.5mm
Thickness: 5.0mm
BTW, I've upgraded the brake hose as well.
Cheers,
SAM
Old 12-16-2011, 05:01 AM   #474
decafe
decafe's Avatar
Oddometer: 291
lucky explorer fairing
does anyone know if the instument cluster for a alazzurra will fit in a fiberglass lucky explorer fairing with square headlight will post pic when i can
decafe is offline   Reply With Quote
Old 12-16-2011, 02:49 PM   #475
bwallca
Oddometer: 132
I doubt it but try posting on the Elefant list http://groups.google.com/group/elefa...urebikes?hl=en
Lots of knowledge there
Ben
bwallca is offline   Reply With Quote
Old 12-22-2011, 05:45 AM   #476
decafe
decafe's Avatar
Oddometer: 291
spares
alright i am planning on doing the mexican 1000 on my 87 elephant 650 looking for ideas for spares list on what could go wrong on 1000 mile runn and please dont say another bike . i am also looking on any way to shed weight and tire selection any info would be apreciated and when i figure out how to post pictures i will thanks andrew
Old 12-22-2011, 07:23 AM   #477
Donkey Hotey
De Jo Momma
Donkey Hotey's Avatar
Oddometer: 11,703
Another bike...and probably a chase truck. You DO know that the transmissions in the 650 are a weak spot, right? I can't remember what book i read it in but, they described it as being made of glass. You'll ruin the bike and parts aren't available for that transmission.
Not a bike I would risk taking on any real offroad excursions unless it was going to be a slow and easy pace. That means putt-putt and taking lots of pictures, not any kind of rally.
Donkey Hotey is offline   Reply With Quote
Old 12-22-2011, 01:53 PM   #478
bwallca
Oddometer: 132
Really! They did quite well in the Dakar back in the day and my 98,000km Alazzurra (same engine/tranny) is still going strong. The only weak spot I know off is the voltage regulator unless it's been upgraded/rewired.
Good luck, Ben
Old 12-22-2011, 06:41 PM   #479
Donkey Hotey
De Jo Momma
Oddometer: 11,703
Dakar bikes were specially prepared and I thought the factory completely swapped the engine for the larger 900 to use in the rally.
He asked and that's what I read in the book (probably the Ian Falloon book). The transmission parts are supposedly NOT the same as similar bikes of that era. It's got the dry clutch but, the 5 speed transmission. It's part Paso, part Alazzura, etc.
I absolutely love my '87 but, I wouldn't begin to consider taking it on such an excursion. Almost any failure will result in the bike being unrepairable. Just about everything on it needs to be custom made or fitted from something else to repair it.
For all the money invested in just getting to and completing such a ride, I would not use such an old and unrepairable bike.
Old 12-23-2011, 11:44 AM   #480
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,152
Speaking of using an old unrepairable bike... this is what I will be running in the upcoming Mexican 1000.
-John
An Elefant never forgets.
www.Raceforthewounded.com
azcagiva is offline   Reply With Quote
Times are GMT -7.   It's 09:30 PM.
