05-28-2012, 04:43 AM
#511 |
Garage gadget
Oddometer: 64
HID headlight kits
Hi all- Paul from Australia, i have a 1990 900ie elefant and was wondering if there's a HID headlight kit that will fit this bike that someone out there would recomend?
Yep the ol' "fit 65wt bulbs and the battery goes flat after extended running trick!!" Can i fit a generic Chinese HID kit and hope for the best? Thanks in advance Paul |
05-28-2012, 01:27 PM
#512 | |
Oddometer: 58
It'd be a "hope for the best" with the Chinese HID kits. Some focus better that others I hear. Heat might be an issue in the Elefant's buckets also. If you haven't already upgraded the headlamp wiring that's worth at least 20 extra watts also. That and fresh bulbs is all I've done to mine and they're plenty bright.
'95 Elefant '84 XL600R '81 900 SD Darmah |
07-02-2012, 08:10 AM
#513 |
Rugby whore
Oddometer: 250
dual throttle cable?
Ok, so recently I purchased two 1994 Elefants... I just noticed a difference between the two. One is more stock than the other, and has two cables from the throttle. The other apparently used to have two cables, but now only has one. Both bikes seem to perform identically - I twist the grip and the trees move faster.
Without having to pull the fairings off and puzzle over a few things, can anyone tell me why the twin cable setup? Thanks, Cade |
07-02-2012, 12:18 PM
#514 |
The main throttle cable pulls against the spring tension and is always tensioned in the pull direction.
The "push" cable only pulls if the throttle hangs up. It "pushes" or "floats" its entire life.... unless the slide hangs up. I've seen many more problems with the "push" cable on modern 4 strokes than with the "pull" cable. here is an interesting discussion bout twin cables http://www.thumpertalk.com/topic/481...tle-cable-why/http://www.thumpertalk.com/topic/481...tle-cable-why/
Enjoy life ... eat out more often Wyvern screwed with this post 07-02-2012 at 12:25 PM |
07-02-2012, 01:25 PM
#515 | |
Oddometer: 86
Agreed! Kurt
Def. of man: We spend 9 months trying to get out, and the rest of our lives trying to get back in. http://s1085.photobucket.com/albums/...900%20elefant/ |
07-02-2012, 01:54 PM
#516 |
Rugby whore
Oddometer: 250
Well, I'll be darned. thanks.
07-03-2012, 09:08 AM
#517 | |
Oddometer: 104
Ben |
07-04-2012, 08:47 AM
#518 |
The ele is a double cable to an actuating rod . (not a cable for each one)
A twin cable set up is just that, a cable for each carb. The Fant is a push pull (I have even had to temp ride with just the pull). A push pull to a single carb or a mechanism that operates 1 (or more) are all the same
Enjoy life ... eat out more often |
07-04-2012, 01:46 PM
#519 |
Ancient Adventurer
the con rod on the early modles always failed at speed.george at up/tite will be able to help you with this.
ancient adventurer |
07-04-2012, 03:00 PM
#520 | |
new orange flavor
Oddometer: 1,058
I told Malcom Smith that I was thinking of running my 510 but built the 350 instead he said that 510 would have blown up. His bike did but they were able to put a new top end on it on the side of the road. The husky would have been cool but I think the 350 turned out to be a good choice. -John
An Elefant never forgets. 2012 Baja 1000 www.Raceforthewounded.com Help us race the 1000, and double the value of your KLR by buying a t- shirt |
07-05-2012, 05:13 PM
#521 |
Ancient Adventurer
so
so tell us,how did it go????????
07-05-2012, 08:05 PM
#522 |
new orange flavor
Oddometer: 1,058
Well, the first day we were doing really well, 5th overall out of 23. On the second day we had some mechanical issues which cost us 4 hours. We finished 2nd in our class (of 2)
and 11th overall. Only four vintage bikes the rest were modern.Great time got to meet some cool people. Here is the thread A tale of two twins I think, bajaburro you will like our team logo. -John
An Elefant never forgets. 2012 Baja 1000 www.Raceforthewounded.com Help us race the 1000, and double the value of your KLR by buying a t- shirt azcagiva screwed with this post 07-05-2012 at 08:27 PM |
07-09-2012, 02:45 PM
#523 |
Ancient Adventurer
good
good to have finished after all that drama.i'm sure you will cherish that finisher pin.
07-09-2012, 05:52 PM
#524 |
new orange flavor
Oddometer: 1,058
The trophy is really cool.
Here it is on the back of the bike ![]() The mexican 1000 would be a great rally to ride an elefant. There were a few tough sections but any good rider would have no problem on a fant. I am considering it myself. -John
07-10-2012, 02:58 PM
#525 |
Elefant-Tamer
Oddometer: 28
hi
all ...
finally back in the forum. appended a short pic-story of modifications during this times removal and overhaul of the engine![]() remounting ![]() cockpit conversion to rallye-version ignition modification to ignitech ![]() somewhere in Switzerland on a test-ride to Marseille three weeks ago. no pix available from today completed extension of the headlights. just for pleasure best |
