Old 03-29-2008, 05:57 AM   #46
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 5,561
Originally Posted by azcagiva
The gas cap has a vent in it, so no problems with plugging it. It will make a funny noise when the tank gets hot and the cap vents.
-John
Just a heads up. I am not sure about the Elefant but most bikes one of the differences between the California bike and the 49-state bikes is that the gas tank is not vented for Cal. The idea is instead of venting into the air it vents through a charcoal canister. If you plug the vent the bike will starve for gas because of vapor lock until you open the gas cap and then it will run again.
I would check out the Cali gas cap carefully and make sure it actually vents.
On some bikes we would take the cap out and drill a tiny hole in the ring below the cap opening so it can vent but not leak.
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is online now   Reply With Quote
Old 03-31-2008, 08:01 AM   #47
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,058
My bike is a California bike. I have had it plugged since I bought it and have had no issues so far, 9+ years.
-John
Hey Rich
azcagiva is offline   Reply With Quote
Old 04-01-2008, 08:50 AM   #48
flyben
flyben's Avatar
Oddometer: 68
Yop all ..
I just got a 750cc fant Frame and swingarm ..
with a full blue fairing except the windscreen ..
so the plan would be to build a rally bike with it .
12 liters rear tank
24 litres front
wp 50 front 280mm travel
750 cc kick starter
mikuni (or fcr carbs)
wilbers rear with height adjustement
koso Rs digital board
special exhaust and sumpguard ..
I'll keep you informed !!!
flyben
flyben is offline   Reply With Quote
Old 04-01-2008, 08:57 AM   #49
Nixels
Face fears - live life
Nixels's Avatar
Oddometer: 7,373
Originally Posted by flyben
Yop all ..
flyben
flyben!
Mebbe do a whole thread about it - with lot's of pictures.
Good luck with it!
Coffee first, then all your other mundane bullshit. Benjava
That tofu will kill you, stay away from it. Soy is the devils bean! moe.ron
SmugMug coupon: cwbkgu7KGL2D2/save $5
Nixels is offline   Reply With Quote
Old 04-01-2008, 09:09 AM   #50
flyben
flyben's Avatar
Oddometer: 68
why not a new thread .. do you think I've to put it in beast ?
I'll make some photos and I've to find someone to help me draw my dreams
after that i've got to find money to realize it .. will be the difficult part
Flyben
Old 04-03-2008, 10:17 PM   #51
Durangoman
Yeah its me!
Durangoman's Avatar
Oddometer: 760
I should look using my reading glasses but with the naked eye, I didnt see a tiny hole in the gas cap on my Calif model. Is the vent hole, on the 49state model, obviously noticeable or hidden?
BMW R1200C
Triumph Bonneville T-100
Honda GB500 --- For Sale?
2001 Kawasaki W650
CT110 !?!?!?
Durangoman is offline   Reply With Quote
Old 04-04-2008, 07:11 AM   #52
wazman
Oddometer: 201
E900 spoke help needed
We're respoking my front wheel (rusted seized nipples etc), which is from a twin-disc 900AC inverted front end.
There are lugs on either side of the hub, with two spokes per lug, each running in opposite directions (one 'forward', one 'backward'.
On removal, some of the spokes had a bigger bend at the hub end than others, and some seem to have little or no bend.
It makes sense that they're bent-ended spokes, because the holes are not angled but the spokes need to angle inwards towards the rim.
It also seems to make sense that there are two different bends - the spokes closer to the centre of the hub would require less angle. But on removal they did not all seem to follow this rule.
Does anyone know what the deal is? Should I have two different bends? Has someone just messed it up when assembling the wheel? Any word on what the angle(s) involved are? I am probably going to get new spokes from Hagon.
Thanks in advance,
Wazman
http://www.garagenight.tv
Wazman
Watch, learn, fix your motorcycle
wazman is offline   Reply With Quote
Old 05-07-2008, 06:59 PM   #53
motomikedh OP
motomikedh's Avatar
Oddometer: 228
Bump, there are a few noobs out there missing this thread, thought I would bring it back up to keep all the important tech info in one place. Happy riding to you all, my forks aren't done yet, sorry. Pics as soon as I get the beast back together.
motomikedh is offline   Reply With Quote
Old 05-12-2008, 04:35 PM   #54
fallzboater
Kiss My Shiny Metal Ass
fallzboater's Avatar
Oddometer: 506
Suspension and Fuel Tank Q's
Here's are some semi-tech questions from a soon-to-be owner '94 e900 owner (more to come, I'm sure):
The August '94 MCN (U.S.) e900 vs. 1100GS comparison article says that the spec'd wheel travel is 8.27"/7.5" f/r, but the measured travel was only 4.25"/4.0". How did they come up with that? Anyone else measured the actual travel? How about with an aftermarket rear shock (Ohlins)? This would make a big difference in how much sag I shoot for when setting up the bike. I'm hoping it's not less than 5"; otherwise I might've saved the aggravation and found a used Wee.
What are good f/r spring rates for a 200 lb rider and up to about 50 lb of gear (no pillion)? Are the stock front spring rates and (non-adjustable) preload close? I plan to set up the bike for about 50/50, with decent performance on double-track and very bad paved roads.
There's also some disagreement between various tests about the fuel tank volume and reserve. What are the actual values?
David Mackintosh
DoD #1360
'94 Cagiva e900 Elefant
'01 Aprilia Fuono
'94 Miata CSP
fallzboater is offline   Reply With Quote
Old 05-22-2008, 03:03 PM   #55
christian
Exchange your GPS Track!
christian's Avatar
Oddometer: 2,535
xenon / HID
Anyone installed one of these HID / Xenon kit ?
Yamaha Majesty '08
KTM 690 Enduro '10
KTM 640 Enduro For sale
christian is offline   Reply With Quote
Old 05-22-2008, 05:24 PM   #56
MySUV
VTer
MySUV's Avatar
Oddometer: 87
Speedo Cable 1995 E900
Thanks for pointing me to this thread. I discovered my speedo cable is broken. I ordered a new cable for a supersport. The connections are correct, but it's way too short. Cable suggestions? Thanks for your help.
MySUV is offline   Reply With Quote
Old 05-22-2008, 05:45 PM   #57
azcagiva
new orange flavor
azcagiva's Avatar
Oddometer: 1,058
Where are you, MySUV? Reason I asked is I might have an extra one in my pile of parts somewhere. You also might want to get ahold of Rich Bebe, he is parting out one of his bikes, he is an inmate here. (look at post #46)
-John
Old 05-23-2008, 03:29 AM   #58
MySUV
VTer
MySUV's Avatar
Oddometer: 87
Speedo Cable
-John
I'm in Hinesburg, Vermont. Thanks.
Old 05-25-2008, 02:08 AM   #59
Don't shoot me!!!
Snowflakes are cold...
Don't shoot me!!!'s Avatar
Oddometer: 569
Yop all ..
12 liters rear tank
24 litres front
750 cc kick starter
flyben
Where will you get the rally kit?
Do you plan to make the rear tank your self?
Same with the kickstarter, it's a lot of kickback in that engine...
Don't shoot me!!! is offline   Reply With Quote
Old 05-26-2008, 07:49 AM   #60
flyben
flyben's Avatar
Oddometer: 68
the kickstarter is already on the engine :-)
quite easy to use
the reartank i would like to buy some azzalin one .. too expensive
it's a currently working project ..
I'll make some photos when I'll begin
Times are GMT -7.   It's 05:16 AM.
