03-01-2008, 05:05 PM
#1 |
Legend in his own mind
Oddometer: 1,651
Did you know the 1976 XL350 weighed 331 lbs? Oink!
There is so much nonsense thrown around about the weight of dual sport motorcycles that I decided it was time to make a list and get some objective, comparable numbers all in one place.
1) All weights are wet, ready to ride, with a full gas tank 2) All weights are from a national motorcycle magazine road test for which they actually weighed the motorcycle -- no manufactuer's numbers here. List moved near the end of the thread.
Often wrong, but never in doubt. montesa_vr screwed with this post 03-08-2008 at 01:41 PM |
03-01-2008, 05:09 PM
#2 |
Bronze Age Fall Guy
Oddometer: 5,227
My Weestrom is so heavy it broke my scale.
My XT225 is exactly what you have. 268lbs advertised is 238! 1986 XL600R is 318lbs. owners manual says 297lbs.
Hate gets you nowhere. |
03-01-2008, 05:21 PM
#3 |
Dirty Old Mudder
Oddometer: 3,942
My 06 TE 510 with oversized gas tank , EE barkbuster & moose hand gaurds, uptite skidplate, dual rim locks, & Buell headlight & windscrean came in at 305 lbs, complete ready to ride with a full tank 3.9 gallons
We spend our lives chipping away at our ignorance :wisdom by Dakez Friendship is like peeing your pants, everyone can see it, but only you can feel the true warmth.: wisdom by ?? Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet 06 Husky TE510 |
03-01-2008, 05:41 PM
#4 |
gooligan
Oddometer: 4,384
My Beta weighs about 160lb.
03-01-2008, 06:02 PM
#5 |
Such a drag...
Oddometer: 1,314
1998 DR650se Weighs in Today at 332 Lbs, Ready to ride with about 3 1/2 gallons of gas. Advertised at 324...
03-01-2008, 06:11 PM
#6 |
Oddometer: 1,260
Thanks for putting this together. I assume this refers to the KLX650C (e-start), not the KLX650R?
Kawasaki KLX650, 379 lbs, Motorcyclist, Nov. 1993 |
03-01-2008, 06:24 PM
#7 |
Oddometer: 3,568
Interesting the the KLR650 would be listed at 401 and 442. Mine weighs full of fuel 415 lbs.
03-01-2008, 06:26 PM
#8 | |
Oddometer: 1,260
03-01-2008, 06:36 PM
#9 |
Target Fixated
Oddometer: 3,879
BMW R1200Gs 581 lbs dry what a pig, its beyond me why they are so popular off road!
03-01-2008, 06:41 PM
#10 |
Redemption.
What would be easier to do, but not as accurate would be to calculate the weight of ~4 gal of gasoline and 3 qt of oil.
Than add that number to the advertised dry weight of any motorcycle. I wonder what the average wet wieght that you have listed minus the advertised dry wieght would be. I'm figuring that these two methods would produce a similar number.
Danger is one thing. But danger plus extreme discomfort for long periods is quite another. |
03-01-2008, 06:47 PM
#11 |
Oddometer: 3,568
Nope. Maybe if you took out the battery and removed the tires and tubes.
03-01-2008, 07:14 PM
#12 |
Oddometer: 1,260
In March 2006, Cycle World weighed the KLX250S at 289lbs with no fuel. Gas weighs 6lbs a gallon, times 1.9, added = 300.4lbs.
03-01-2008, 07:29 PM
#13 | |
You were a n00b too, nub.
Oddometer: 3
As MotoMind said, gasoline weighs about 6 lbs per gallon. Weight spec threads are always helpful. Thanks to all contributors, especially montesa_vr. |
03-01-2008, 07:30 PM
#14 | |
Motorcyclist
OPINION; most GS owners will, if honest, agree that they are great on the highway, and acceptable off road. As most KTM Adventure rides would agree with the opposite!
California, aka Leslie V Leslie. Two roads diverged in a wood, and I took the one less traveled by, and that has made all the difference |
03-01-2008, 08:21 PM
#15 |
Oddometer: 439
I think more manufacturers are moving away from the "lie weights" and listing actual "dry weights". KTM's dry weights are real weights. Husky's advertised weights are accurate too, aren't they?
Kawasaki said the new KLR650 was 50 lb heavier than the old, but the main difference was a more accurate weight spec for new model. The same goes for the new 250 ninja which is 30 lbs "heavier", but I suspect the main difference will be a more truthful spec for the newer model. The folks that are weighing their new Yamaha WR250x bikes are finding them close to the 280lb spec. strongbad screwed with this post 03-01-2008 at 08:26 PM |
