Old 03-01-2008, 08:33 PM   #16
Castleman
Guest
Oddometer: n/a
99 LC4e and 04 SMC
99 LC4e 317 lbs ready to ride and the 04 LC4 625 motard was 321 ready to ride.
Old 03-01-2008, 08:53 PM   #17
peterman
cop magnet
peterman's Avatar
Oddometer: 13,788
not the most accurate of scales I suppose, but here we have truck scales that are open or "turned on" whether they are manned or not. I pull on the scale on my '05 12GS with a tank of gas, and consistently weigh in at 780 pounds. I weigh about 220.
On a trip to B.C. with full gear and a pillion passenger we hit a scale in Washington at an even 1000 pounds
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Old 03-01-2008, 10:05 PM   #18
rwamf
Follow me
rwamf's Avatar
Oddometer: 1,354
Originally Posted by mr openroad
GS, its beyond me why they are so popular off road!
Because they are a blast, And I ride mine 75% off road, There is nothing like it, no you don't take it on single track but out west we have dirt roads that are an absolute blast on a GS, roads that would suck or would be just plain boring on smaller dual sports is pure heaven on the GS, It is fun to put in 3 or 4 hundred mile days in the dirt.
"Do not go where the path may lead, go instead where there is no path and leave a trail. ~ RWE
Robert
rwamf homepage
rwamf is offline   Reply With Quote
Old 03-02-2008, 07:29 AM   #19
lightfighter
where does this go?
Oddometer: 2,286
i think it depends completely on how you define "off road". i sold my r1100s to buy a dualsport, and i have ALWAYS wanted an r1200gs, but im short a few grand. i'll have one someday, but it wont go where im taking my dr650, i can promise you that. im seriously considering an f800gs, which im hoping i can pick up used at the onset of the 2010 model year and keep the dr as a more offroad oriented machine, or even replace it with something in the 400 range.
lightfighter is offline   Reply With Quote
Old 03-02-2008, 10:31 AM   #20
BikePilot
BikePilot's Avatar
Oddometer: 11,251
motorcycle consumer news' test bike performance index lists actual wet weights and is a free download from their site:)
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, KX100, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 03-02-2008, 12:24 PM   #21
SMMad
You were a n00b too, nub.
Oddometer: 3
Hmmm...
http://www.mcnews.com/mcn/technical.asp
Winter 05/06 is the latest. Still, good resource.
SMMad is offline   Reply With Quote
Old 03-02-2008, 12:44 PM   #22
wibby
BrotherFromAnotherMother
wibby's Avatar
Oddometer: 10,580
Hey Peterman!
My Wee in commuter mode with Jesse's usually comes in at an even 550 lbs
With me on it, 800 - 850 lbs
I'm thinking the ones I use probably go in 50# increments
Been awhile since I weighed the DR, but I'm thinking around 350
'05 DL650
'92 KDX200
wibby is offline   Reply With Quote
Old 03-02-2008, 02:41 PM   #23
2whlrcr
gooligan
Oddometer: 6,488
Originally Posted by SMMad
Somebody may want to weigh their own oil, and consider the container it is in, but it seems engine oil weighs 2-4 lbs per quart.
Oil weighs 7.5lbs per gallon.
Is the method placing a bathroom scale under each wheel and adding up the total reasonably accurate?
2whlrcr is online now   Reply With Quote
Old 03-02-2008, 02:59 PM   #24
mcinfantry
who... me?
mcinfantry's Avatar
Oddometer: 436
i dont think. what about a board long enough for the wheelbase?
preaching personal responsibility since 1991
1942 Dodge WC-53
2008 Husky TE610
mcinfantry is offline   Reply With Quote
Old 03-02-2008, 03:37 PM   #25
Seikkailu_R
Seikkailu_R's Avatar
Oddometer: 839
Why not?
I once try with one scale.
2000 640a with allmost full tank.
Result was somewhere near 180kg....
Seikkailu_R is offline   Reply With Quote
Old 03-02-2008, 04:01 PM   #26
2whlrcr
gooligan
Oddometer: 6,488
Originally Posted by Seikkailu_R
Why not?
Yes, I was implying one scale and measuring one wheel at a time.
Old 03-02-2008, 04:16 PM   #27
strongbad
Oddometer: 485
If the scale(s) are accurate, and the bike is level, the weight measured with a scale under each wheel then added, or a scale under one wheel at a time then added, is accurate. The key thing is that the bike must be level.
Experimental aircraft builders get weight and balance info this way sometimes.
strongbad is offline   Reply With Quote
Old 03-02-2008, 04:18 PM   #28
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 4,084
I just put a bathroom scale on my el-cheapo hydraulic bike lift & lifted my bike up off the ground under the skidplate easiest method I could think of
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus is offline   Reply With Quote
Old 03-02-2008, 04:46 PM   #29
Fast1
Twisted Throttle
Fast1's Avatar
Oddometer: 1,884
what numbers did you find on the scale?
Fast1 is offline   Reply With Quote
Old 03-02-2008, 04:51 PM   #30
tony_dt
Dang_Hills
Oddometer: 20
I am a die-hard husky fan but their weights aren't that accurate.
KTM does seem to be closer to advertised.
Originally Posted by strongbad
I think more manufacturers are moving away from the "lie weights" and listing actual "dry weights". KTM's dry weights are real weights. Husky's advertised weights are accurate too, aren't they?
Kawasaki said the new KLR650 was 50 lb heavier than the old, but the main difference was a more accurate weight spec for new model. The same goes for the new 250 ninja which is 30 lbs "heavier", but I suspect the main difference will be a more truthful spec for the newer model.
The folks that are weighing their new Yamaha WR250x bikes are finding them close to the 280lb spec.
tony_dt is offline   Reply With Quote
Times are GMT -7.   It's 08:41 AM.
