03-02-2008, 04:59 PM
#31 | |
Such a drag...
Oddometer: 1,310
03-02-2008, 05:29 PM
#32 | |
Dirty Old Mudder
Oddometer: 3,928
We spend our lives chipping away at our ignorance :wisdom by Dakez Friendship is like peeing your pants, everyone can see it, but only you can feel the true warmth.: wisdom by ?? Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet 06 Husky TE510 |
03-02-2008, 05:33 PM
#33 | |
Oddometer: 1,702
The dry weight is much less. Edit: mcnews.com listed the wet weight of the R1200GS as 530#. Vibr8r screwed with this post 03-02-2008 at 05:53 PM |
03-02-2008, 05:53 PM
#34 |
Rift- Raft, SCooter Trash
Oddometer: 800
Some time ago
I weighed my 07 TE610 with dirt bags (empty) and a gallon of gas and it came up to 308 using the bathroom scale at the front + back method. My drz400s was if I remember 306 in the same trim. I'll have to check that again.
Cbig |
03-02-2008, 06:49 PM
#35 | |
Cheese and Rice!
Oddometer: 4,608
03-02-2008, 10:43 PM
#36 |
Oddometer: 1,135
VR, I applaud your efforts here but....
I really like your work here (and on the gear spread chart as well), but...... I don't understand the logic of listing and as a result ordering the bikes with a full tank of fuel!!!!!
Given most bike will travel more or less about the same distance on a gallon of gas, why allow gas capacity to enter into the ranking or ordinal? Filling a tank to full capacity is a choice the owner makes. For many, generous fuel capacity is an attribute but the standard you have chosen turns this feature into a liability! Your chart doesn't list fuel capacity making it difficult to back the weight of the fuel out for those wanting to level the playing field. Wouldn't a wet, ready to ride weight with out fuel paint a more accurate picture? Even though I don't agree with it's current form this is a very useful collection of data. MCNut P.S. I own two 04 KTM EXCs. One with a stock 2.2gal tank and the other with an aftermarket 6.6gal tank. How should these otherwise identical bikes be charted and why? Empty the bikes weight difference is less than 1%, full the difference is over 12%. I believe the 6.6gal bike should only be penalize the additional 1-2lbs of the over-sized tank itself. mcnut screwed with this post 03-02-2008 at 10:52 PM |
03-03-2008, 05:15 AM
#37 | |
Legend in his own mind
Oddometer: 1,626
Unfortunately, weight with a full tank is the only number I can find that is comparable. Various magazines over the years have listed weight three different ways: tank empty, tank full, or weight with half a tank of fuel. Obviously the latter measurement is subjective and lends itself to inconsistent results. The first would be the most fair way to compare, but it is the most rare. Since my purpose here is to list weights in one place that can be compared, I am stuck with weight with a full tank. I appreciate all the contributions done with bathroom scales, truck scales, etc., and please keep them coming. However, I won't be adding them to the list, since I need to limit that to comparable weights. Same thing with the weights from Motorcycle Consumer News. It is indeed a helpful resource to have all those weights listed together, but the MCN numbers are consistently lighter than the weights from other sources, and I suspect they are using the half tank of fuel method for determining wet weight. One of the frustrating things about this project is the reminder that the magazines don't take dual sports very seriously. For example, the KLX250S is one of the more significant additions to the dual sport world in the last few years, yet Cycle World treated it with a one page glossover and no spec sheet at all. The TE610 has been featured in several articles, including comparisons of sorts, but never with an all up weight. I'm hoping that will change as the new models hit the floor this spring. But it's not like the good old days when Art Friedman was editor of Motorcyclist and dual sports were part of every third issue. Mcnut, I like your idea of listing the fuel capacity. Since dual sports typically hold between 2 and 2.5 gallons, I'll note those that are carrying 3 gallons or more, and readers can do the math if they want to see where a bike might rank with less gasoline.
Often wrong, but never in doubt. |
03-03-2008, 06:04 AM
#38 |
who... me?
Oddometer: 436
if your tank holds 1 or 10 gallons why NOT include that in the weight? dont most people fuel up prior to heading offroad? so wouldnt my xyz with 10 gallons need to figure that since not only is the bike heavier its TOP heavier?
or do most people head offroad with only enough fuel to complete the trip? that would be like having your post of gear ratios NOT include 6th gear. since most people dont run 6th gear in single track.... why not compare only the gears everyone has. larger tank is MORE range, but its also MORE weight. so it really becomes is the range worth the weight
preaching personal responsibility since 1991 1942 Dodge WC-53 2008 Husky TE610 |
03-03-2008, 09:47 AM
#39 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Oddometer: 1,135
VR, thank you again for your efforts. I attempted this many years ago. Had a commercial electronic load cell scale, built wood ramps to roll the bikes up and maintain level. Hauled the setup to various dealer and weighted bikes I had interest in at the time. Because the the bikes on the showroom floor had varying amounts of gas in them, I was forced to make an adjustment. After much thought I concluded: Wet ready to ride w/o gas was the fairest configuration. I totally agree with not including weights from various unknown sources.
VR, thought you might get a kick out of this, we think allot alike (I own a 74 Rickman powered by a VR). The file was last modified in 2001 and yeah some of the dealers thought I was nuts. And I don't even remember what all the symbols mean any more;
03-03-2008, 09:50 AM
#40 |
Oddometer: 1,135
Sorry about the size and lousy formatting of my prior post!
MCNut mcnut screwed with this post 03-03-2008 at 10:20 AM |
03-03-2008, 10:03 AM
#41 |
Master of None
Oddometer: 5,052
I think the best way would be full of all fluids except gas, due to the differing tank capacities.
The factory weight ratings are dubious I believe at best. I bought a new-from-the-crate Yamaha YFZ450 (atv) recently. Factory weight rating is 350 dry. I took it right to a certified shipping scale, not a drop in the gas tank, and it weighed 372. Two quarts of oil and a quart of anti-freeze is probably not 22 pounds. Pisses me off actually, people who are spending 7 grand on a race atv (or anything else) should be provided truthful specs. |
03-03-2008, 10:12 AM
#42 | ||
Oddometer: 1,135
Sometimes taking an augment to an extreme can cast things in a different light
I choose to almost never completely fill the 6.6gal tank on my 525EXC. Quote:
By most accounts the DR650 and KLR650 fill a very similar roll in the MC world. Should the KLR be penalized for having the capacity to carry 3 more gallons of gas than the DR and should a bed roll be placed on it's standard (optional on the DR) cargo rack? MCNut mcnut screwed with this post 03-03-2008 at 10:37 AM |
03-03-2008, 10:19 AM
#43 |
Registered
Oddometer: 427
Great thread, if only you could print the weights also in kilos, please.
![]() If you are not afraid of German, you could verify the numbers from here: http://www.motorradonline.de/bikes/k..._bik_start.htm German Motorrad magazine lists most models sold in Europe between 2003 and 2007 at the page. At first you have to choose a model year from upper right hand corner “Katalog-Ausgaben”. Then you click the make (Motorräder) in the middle, choose the model from a list, click red text “Technische Daten”, and you get the specs. The measure weight is mentioned under text “Test in MOTORRAD” Leergewicht vollgetankt kg. Claimed weights are mentioned at first, so make sure you read it from the right place (Test in MOTORRAD). However, all the weights may not be comparable, because in some cases they include racks and hard cases.
----------------------------------------- If you are thinking outside the box, it’s better to know the box first. ----------------------------------------- |
03-03-2008, 10:53 AM
#44 | |
Mud Lover
Oddometer: 591
Pull out the calculator Jan! 2.2 lbs per KG. Compliments of Canada.
What I lack in skill, I make up in reckless abandon. |
03-03-2008, 11:16 AM
#45 | |
who... me?
Oddometer: 436
if i want to buy a used 2007 husky te610 and there are two, one with a ims 5 gallon and one with a stock tank... thats alot of difference ABOVE center of gravity. id almost like to ride the two just to see how much. i bet its more significant than most of us think.
