Old 04-18-2009, 11:33 AM   #76
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,679
Send a message via MSN to mountain eagle
According to Ramz here on his page about his husky setup....
Regarding his 08' Husky TE610
Originally Posted by ramz
emptied the gas tank and weighed the bike; it weighed 296 pounds. The bike was stone stock with no mods, fluids topped up, and the gas tank was empty. After filling with 3.25 gallons of gas, the TE weighed 317 pounds.
and regarding his 09 TE310
But first I weighed the bike and took measurements. The TE weighed 260 pounds.
Thanks to rick for us huskylusters...... lots of info there.
mountain eagle
08'Husky TE610 = everything a KLR want's to be ,
07'KTM950SE,
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 04-18-2009, 11:55 AM   #77
LukasM
Oddometer: 4,927
Originally Posted by montesa_vr
I realize it is perverse publish weight with a full gas tank, therefore penalizing the manufacturers for providing additional gas capacity to a stock motorcycle. As adventure riders, that's one of the things we are always screaming about. Unfortunately, weight with a full tank is the only number I can find that is comparable. Wet weight with an empty gas tank would be the most fair comparison, but it is hard to find.
+1000.
That is the only relevant weight by which bikes should be compared IMO. Depending on how much range is needed most people will put an aftermarket tank on their bike anyway.
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 04-18-2009, 02:48 PM   #78
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 2,759
weight with 3 gallons. You can always choose not to fill up a big tank. most bikes will fit 3 gallons.
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Old 04-18-2009, 03:40 PM   #79
BikePilot
BikePilot's Avatar
Oddometer: 10,901
Thanks for the informative post! IIRC MCN numbers are ready to ride, no gas, but I could be wrong about that.
As long as its known whether its with full tank, empty tank, 3 gallons or whatever I'm happy, the math isn't hard:)
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 04-18-2009, 04:23 PM   #80
Django Loco
Django Loco's Avatar
Oddometer: 3,785
Mcn
MCN (USA) test weigh bikes Wet. They claim tanks are full.
Here are a couple weights from recent issues that you can squeeze into your list. (nice job by the way! )
Wet Weights:
BMW R1200GS MCN sept. '08 536 lbs.
BMW F800GS MCN Jan. '09 490.5 lbs. (ABS)
BMW F650GS MCN April '09 473.5 lbs. (note: there is a mistake on spec sheet, this is the true wet weight as shown in the text of the article)
Neither bathroom scales nor giant truck scales are not all that accurate for weighing motorcycles. Truck scales are optimized for accuracy around 10,000 to 15,000 lbs. more or less. Weighing front then rear wheel on a common bathroom scale is just not accurate.
Been there, tried it. It under weighs.
The best we've found for weighing bikes is at a near by hospital, back at the laundry loading dock. There is a nice ramp up to the scale, and the scale is drive on. It's used to weigh bins of laundry before they go out on a truck.
This scale is certified and checked annually. It's range is from Zero to 1000 lbs. which is about perfect for accurate measurements on MC's. Very fancy piece. The whole bike fits on it and is perfectly level. It's very accurate in our experience. Many hospitals have these types of scales. We know the chief maintenance guy for the whole hospital .... so have an in
Django Loco is offline   Reply With Quote
Old 04-18-2009, 04:41 PM   #81
LukasM
Oddometer: 4,927
Patrick,
Why do you think that is? If you placed the non-measured wheel at equal height and just supported the bike from falling over to the side, this should work very accurately. Provided that your bathroom scale is accurate, of course. They operate in pretty much the exact range we need for one wheel.
Old 04-18-2009, 04:57 PM   #82
earthroamer
Stuck in Pindadesh
earthroamer's Avatar
Oddometer: 2,045
Originally Posted by LukasM
Patrick,
Eggzakly. Sometimes I wonder if you guys ever took high school physics. The wheels push down the same whether they on the garage floor or a set of scales. The wheels don't know what they are on. As long as the tires are the same elevation and the bathroom scales are accurate in the 2-300 lb range it's simple physics.
Jim
06 F650GS
I wanna ride
earthroamer is offline   Reply With Quote
Old 04-18-2009, 08:34 PM   #83
5050
Oddometer: 45
Operative words - wheels at same elevation. When tipped the cg moves in the direction of the lower wheel thus biasing weight to the lower wheel and decreasing the weight born by the higher wheel. Which end of a washing machine feels heavier going downstairs - the upper or lower? Easier to wheelie going uphill or down?
5050 is offline   Reply With Quote
Old 04-18-2009, 08:48 PM   #84
30Bones
30Bones's Avatar
Oddometer: 4,561
Originally Posted by swjohnsey
Interesting the the KLR650 would be listed at 401 and 442. Mine weighs full of fuel 415 lbs.
Originally Posted by Castleman
99 LC4e 317 lbs ready to ride and the 04 LC4 625 motard
was 321 ready to ride.
As a former KLR owner and now a 640e owner, That right there is such a HUGE difference it's unreal. Even if the weights are +/-20#. Not to mention the motor output is far greater.
Today is the tomorrow you worried about yesterday
30Bones is offline   Reply With Quote
Old 04-18-2009, 08:50 PM   #85
montesa_vr OP
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,626
In theory, I believe it is possible to get an accurate weight one wheel at a time. In practice, the numbers are so variable that they are useless. Besides the problem that 5050 points out of the scale changing height with weight on it, there's the quality of the scales. I have never seen a bathroom scale, digital or analog, that I can't get to show varying weights depending on how I stand. Furthermore, my weight varies as much as 15 pounds from one bathroom scale to another.
I've said it before, and I'll repeat it here. I only use weights from a few magazines because I know they weigh the bikes the same way on the same scale with a full tank of gas. Maybe the weights I have listed aren't absolutely correct, or accurate, but they are consistent. And since they are consisent, they are absolutely usefull for comparison. So I don't care if your DR650 only weighs 347 pounds on your certified meat scale. For all I know, your scale is more accurate than the one at Cycle World. But I can't weigh all these bikes on your certified meat scale. And what I'm really interested in is relative weight -- how much heavier a DR650 is than a WR250R, for example. And I like to be able to look at the list and have some confidence that the difference is 66 pounds.
Often wrong, but never in doubt.
montesa_vr is offline   Reply With Quote
Old 04-18-2009, 11:18 PM   #86
Django Loco
Oddometer: 3,785
This is it exactly. If the bike is not level then this method may not be accurate.
Also, how do you determine front to rear bias? How much do you count from each wheel? Just simply add the two weights together? Or work a percentage based on manufacturers listed front to rear bias?
Doesn't sound right to me but I never took Physics!
Sorry, I'm old school, prefer a real scale. I did measure the weight of a motor once. I got on the bathroom scale, noted the amount then held the motor close to me and held still. Just the slightest movement of the motor changed the scale ready by 15 to 20 lbs. on a 100 lb. motor.
Old 04-19-2009, 10:13 PM   #87
bmwktmbill
Traveler
Oddometer: 4,014
'02 KTM Adventure 640a, OEM trim, KTM Competition pipe and pre muffler replacement pipe, Touratech pannier mounts(no panniers), 1.5 gallons of fuel....
400 lbs.
http://www.google.com/imgres?imgurl=...QEwAQ&dur=7031
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 10-25-2012 at 08:40 AM
bmwktmbill is offline   Reply With Quote
Old 04-20-2009, 03:52 AM   #88
mikegreen
Oddometer: 1
What is this "pounds" you guys talk about. Where's the kilo's
mikegreen is offline   Reply With Quote
Old 04-20-2009, 06:04 AM   #89
montesa_vr OP
montesa_vr's Avatar
Oddometer: 1,626
In the U.S., the school system has been teaching the metric system since the 1970's, but the polticians are afraid to make it our standard of measurement, so we still rely on feet, pounds, pecks, pints, rods, and other antiquated measures. If Obama really wants to be the science president he could push for us to advance in this area, but I haven't heard a proposal.
Old 04-20-2009, 09:13 AM   #90
dgrs2
Where'd I leave my knee??
dgrs2's Avatar
Oddometer: 1,595
I weighed my 2004 KTM 950 Adventure on a friends race car scale. Full wet, crash bars, heppco, becker hard cases, KTM top case. 525 lbs. With myself on it with bags full of camping gear, 8 man tent, back pack filled, extra doodads for fixin, 855 lbs. Have to weigh my 03 KTM 625 SXC. I'll let you know.
05.5 KTM 950 Adv
Smokin Hole Rally creator
http://advrider.com/forums/showthread.php?t=767567
dgrs2 is offline   Reply With Quote
Times are GMT -7.   It's 05:34 PM.
