Old 09-29-2009, 07:31 PM   #211
jdrocks
Gravel Runner
Oddometer: 4,586
i don't know what the guy did to fit those husky forks. i meant that if he fit them on a versys that they would also work on the 650R. the versys and 650r use the same frame, stem, races, bearings, etc.
jdrocks is online now   Reply With Quote
Old 09-29-2009, 07:42 PM   #212
BeeDub
Havagoowan
BeeDub's Avatar
Oddometer: 2,022
Okay, gotcha. I guess I'll just look into it more down the road when I can either afford two projects, or finish the one I have...
BeeDub is offline   Reply With Quote
Old 10-12-2009, 02:51 AM   #213
jdrocks
Gravel Runner
Oddometer: 4,586
winter season coming around and it's time for a new build.
plus i need to get out of tony's thread.
new victim here...plus the ride report on my 13,500 trip on a dual sported 650R.
http://www.kawasakiversys.com/forums...ead.php?t=5480
jdrocks screwed with this post 10-24-2009 at 07:22 PM
Old 10-12-2009, 05:37 AM   #214
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,782
new victim here...
i read your post - did you mean to say that you are keeping the stock frontend? why?
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 10-12-2009, 05:41 AM   #215
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,782
Originally Posted by tonymorr
Ahh, that's where we were disconnecting. I was thinking the XRR chassis with the Ninja motor! That's what the "shoehorn" comment was all about. Crazy I know.
you might want to take measurements on a DR vs. XRR. I had both simultaneously [sold the converted XRR and kept two drs] and it looks to me like the DR may have a little more room there for possible conversion to parallel twin. Or give me the dimensions necessary and I'll take some metrics in the garage.
Is the 650 kawa really larger than the 500?
Zapp
Old 10-12-2009, 05:51 AM   #216
jdrocks
Gravel Runner
Oddometer: 4,586
i'm removing the 650R suspension and replacing it with the versys suspension. the versys has the bigger shock, beefier USD forks, and stronger trees. this suspension works for what i want to do with the bike.
i have a guy that's bugging me to buy the 650r forks, and if i sell them that would put the starting point under $1500, but i might keep them. haven't decided yet.
Old 10-12-2009, 07:34 AM   #217
tonymorr OP
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,543
After riding the bike for awhile (and having a blast) I have figured out some things that are lacking. Here's my list of things I want to improve.....
1) Seat to peg distance. Get the pegs further forward for stand up riding.
2) Better suspension front and rear.
3) Engine protection.
4) I have Stormcase's, gotta get them on there.
As soon as the riding season is trully over I'm going to bring the bike in, strip it down and take a good long look at it. I was thinking of putting the engine in a different frame but looking at it more it's hard to believe I could save much weight. The Ninja frame is steel and maybe heavy, but it's minimal because it uses the engine as a stressed member. I've studied some bikes lately that use the engine as a stressed member (like the Ninja) and noticed that they use the bottom of the engine for mounting things (such as skid plates). I think I'm going to machine a new oil pan with bosses for mounting a plate. Doing this will also eliminate the low/delicate oil drain plug.
Not sure yet if I will move the exhaust. The reasons that Kawasaki put the exhaust down undernieth are valid ones. Low CofG. It's a very solid muffler that seems like it could take quite a beating. If it does get damaged they are a dime a dozen online. It's nice and quiet as well. The price to pay for sturdy and quiet however is that it weighs about 13 lbs (if I remember correctly).
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is offline   Reply With Quote
Old 10-13-2009, 04:48 PM   #218
jdrocks
Gravel Runner
Oddometer: 4,586
ride report for that 13,500 mile trip on the 650R/Versys is here-
http://www.advrider.com/forums/showthread.php?t=515446
Old 10-13-2009, 04:53 PM   #219
tonymorr OP
tonymorr's Avatar
Oddometer: 2,543
Hey JD;
After checking out some of your posts it's clear you spend alot of time off the beaten path. What are your thoughts on spokes vs. cast wheels? For me, tubeless plugable tires are a huge plus.
Old 10-13-2009, 05:31 PM   #220
jdrocks
Gravel Runner
Oddometer: 4,586
i was on gravel roads, although some were in very rough shape, and not single track or terrain of that kind.
i've had about 100 people tell me that i'm going to break those cast wheels, but for where i'm riding i just don't see it. bend an edge, yes, but that goes with the use. i see more dinged up spoke wheels.
the other aspect is the muddy sloppy road conditions up north or other places. many times the bike and everything else is covered with a layer of mud. plugging a tubeless in those conditions is one thing, but patching a tube is a whole different deal.
i thought about setting up some spoke wheels for the ER6 build, but i didn't think i could do it and stay within my budget. then there were all those photos of muddy roads....
so to answer the question, i'm staying cast. it works best for where that bike is going.
Old 10-14-2009, 05:36 PM   #221
Dorzok
Dorzok's Avatar
Oddometer: 2,010
Hey hey I'm a...
...Monkee
Dorzok is offline   Reply With Quote
Old 10-19-2009, 04:36 AM   #222
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,544
Wow!
Originally Posted by tragerbon
nice..
You can't post a picture of a bike like this without more info!!! And more pics!!! And why can't kawi think of something like this?!!!
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 11-02-2009, 03:32 PM   #223
PacificPT
Oddometer: 984
juames,
I agree! More info needed, and yes I would probably buy one if Kawa, or Yama, or honda would put one out. This is the direction the Transalp should have gone.
2000 KLR650
There's roads and there's roads and they call, can't you hear it? Roads of the earth and roads of the spirit. The best roads of all are the ones that aren't certain. One of those is where you'll find me till they drop the big curtain. Bruce Cockburn
PacificPT is offline   Reply With Quote
Old 11-03-2009, 03:10 AM   #224
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 10,030
Originally Posted by PacificPT
juames,
I have no more info, the owner / builder is a friend of a friend that i have no contact for & lives 1000km from me & he is not on the net
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 11-03-2009, 07:59 AM   #225
rlbowers03
rlbowers03's Avatar
Oddometer: 151
THATS NOT RIGHT!!! You cant post a pick like that and not give more information
You're going to have to make a special trip now and find this guy and get all the goods on this awesome beast!
We will be waiting right here
2008 Versys
83,500 miles and counting
rlbowers03 is offline   Reply With Quote
Times are GMT -7.   It's 06:38 AM.
