Old 04-02-2010, 11:00 AM   #301
tragerbon
tragerbon's Avatar
Oddometer: 131
Nice !!!!! N
Bike free : (
tragerbon is offline   Reply With Quote
Old 04-02-2010, 12:48 PM   #302
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Tony,
What's the eye to eye length on the Elka?
Old 04-02-2010, 01:02 PM   #303
tonymorr OP
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,511
Originally Posted by sanjoh
Tony,
11.926" center to center
The 10mm height adjustment is set in the middle so you can lengthen or shorten it about .197"
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is offline   Reply With Quote
Old 04-02-2010, 01:06 PM   #304
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
That should work great on the ninja. The cbr shock I'm using is 12" eye 2 eye.
Any idea how much travel? Let us know how it works (and soon)
Old 04-02-2010, 01:16 PM   #305
tonymorr OP
tonymorr's Avatar
Oddometer: 2,511
Oh it will be soon. I'm chomping at the bit right now to leave work and go put it on. It should give the same travel as Kawasaki specs for the Versys 5.7" as opposed to the Ninja 4.9"
Old 04-06-2010, 05:20 PM   #306
tragerbon
tragerbon's Avatar
Oddometer: 131
My new Shinko 705`s are on, I think I am starting to see the light at the end of the tunnel : )
http://www.advrider.com/forums/showp...postcount=1150
Bike free : (
Old 04-08-2010, 07:54 AM   #307
Ridin'nFishin
Oddometer: 496
Lower links on ebay for versys
I just found these on ebay, do you think these could be turn around and used to raise the Ninja 650R?
http://cgi.ebay.com/ebaymotors/lower...item3efea41217
Riding a Motorcycle is like flying like a Eagle without ever leaving the ground.
Ridin'nFishin is offline   Reply With Quote
Old 04-08-2010, 10:31 AM   #308
tonymorr OP
tonymorr's Avatar
Oddometer: 2,511
Not sure that would work in the opposite direction but perhaps.
Mine is plenty tall enough right now. I actually shortened the new Elka shock to it's shortest length after trying it out. It came in the middle of the 10mm adjustment. The new shock is a bit on the stiff side. With no preload I only have about 1 3/8" sag and 1/4" static (if that). I'm going to mess around with the damping some more but I think I'm going to end up requesting a sligthtly softer spring. It definitly works better than stock but it's not the plush feel that I was hoping for.
Old 04-08-2010, 12:05 PM   #309
Ridin'nFishin
Oddometer: 496
Pegs
Tonymorr,
How does the peg location feel in stock? Do you have an idea to move them forward?
Old 04-08-2010, 12:13 PM   #310
tonymorr OP
tonymorr's Avatar
Oddometer: 2,511
Tonymorr,
Peg location feels like a comfortable sportbike. Not the best for this type of bike. I do have an idea to move them. Hard to explain what I have in mind. The part I don't have figured out is the shifter. If I just move the peg and shorten the shifter it will have a very short throw. Need to figure out something better.
Old 04-08-2010, 12:18 PM   #311
Ridin'nFishin
Oddometer: 496
I am on my way to look at a 650R now.
Old 04-08-2010, 02:03 PM   #312
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
You've just described the CBR shock I'm using
I can't measure static sag as the swingarm is bottomed out on the muffler. Soon to be replaced muffler as my local Meineke will make a midpipe for a can/slipon.
Old 04-09-2010, 08:10 AM   #313
Kawidad
Kawidad's Avatar
Oddometer: 4,901
Dude, that is one tasty looking bike you got going there. I like it!
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 04-09-2010, 08:13 AM   #314
ride2little
MoveAlongNothingHere
ride2little's Avatar
Oddometer: 1,960
Update......current pic:
Looks pretty cool, except for that nut-busting tank. Well done, btw.
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
ride2little is offline   Reply With Quote
Old 04-09-2010, 12:41 PM   #315
jdrocks
Gravel Runner
Oddometer: 4,497
tony, why so little adjustment? 10mm doesn't seem significant, especially if the goal is to level out the bike with a fork/wheel change.
jdrocks is offline   Reply With Quote
Times are GMT -7.   It's 12:11 AM.
