Old 03-13-2008, 01:36 PM   #31
intheways
intheways's Avatar
Oddometer: 419
Originally Posted by tonymorr
I'm going to pull up a chair and stair at it tonight. Maybe a beer or two will help get the creative juices flowing.
That's the way to work!
intheways is offline   Reply With Quote
Old 03-17-2008, 07:21 PM   #32
tonymorr OP
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,530
Not much progress......
Not much progress this weekend or today. I was sick . I made a rack to hold the bike while I work on it. I took a bunch of measurements so I can make some calculations. I need to figure out how much I'm going to raise the rear, the front, and what offset triple clamp I will need to get good rake/trail numbers.
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is offline   Reply With Quote
Old 03-17-2008, 08:25 PM   #33
duckrider
duckrider's Avatar
Oddometer: 993
Nice shop! Way cleaner than mine.
Keep us posted, great project.
duckrider is offline   Reply With Quote
Old 03-17-2008, 08:45 PM   #34
tonymorr OP
tonymorr's Avatar
Oddometer: 2,530
Thanks. I have a big shed to keep the bikes in but it's cold out there. I need to build a garage. Buying bikes keeps getting in the way I really think I'm going to get to build it this year one way or another.
Old 03-18-2008, 04:15 AM   #35
dancolin
Weeeehaaa!
dancolin's Avatar
Oddometer: 1,004
I actually think a bike in the house is a beautiful thing..like fine art..
http://picasaweb.google.com/dancolin/TheBikes
06 KTM 950 Adventure
dancolin is offline   Reply With Quote
Old 03-18-2008, 05:37 AM   #36
llamapacker
Mr. Conservative
llamapacker's Avatar
Oddometer: 1,363
Originally Posted by pilot
The wheel I have doesn't have rotors on it. I borrowed it, so I can't sell it. I may get around to looking at it today. If I can get off the site long enough.
I would be interested in a picture of the hub if you can get one. We can machine an adaptor out of T6 to adapt the different bolt patterns for the rotors and wheel to the Versys.
The hub width, axle size would also be a concern.
14 KTM 1190 Adventure
llamapacker is offline   Reply With Quote
Old 03-18-2008, 08:39 AM   #37
kevrider
kevrider's Avatar
Oddometer: 300
I'm trying to make (pick one)
A twin cylinder KLR
A Versys with better dirt road suspension/more clearance.
A cheaper, lighter, less BMW-ish (sorry) F800GS
worthy goals. i've been waiting for someone to ADV a versys, knew it had to happen sooner or later. i don't understand why you started with a ninja instead of a versys, but i'm sure much that you learn will be transferable.
kevrider is offline   Reply With Quote
Old 03-18-2008, 08:53 AM   #38
dancolin
Weeeehaaa!
dancolin's Avatar
Oddometer: 1,004
i dont think you can pickup a versys for a lil over 4k...
Old 03-18-2008, 09:03 AM   #39
Rode2Nowhere
Rode2Nowhere's Avatar
Oddometer: 2,213
Just as long as she's done by June 7th
- Jonathan
'88/'96/'08/'09 KLR650 Amalgamation
IBA #45896
Adirondack Tags
Rode2Nowhere is offline   Reply With Quote
Old 03-18-2008, 09:21 AM   #40
kevrider
kevrider's Avatar
Oddometer: 300
roger, that!
Old 03-18-2008, 10:01 AM   #41
intheways
intheways's Avatar
Oddometer: 419
A twin cylinder KLR
I'm a bit confused with Kawasaki's lineup in this area. It seems like there is too much overlap between the 2008 KLR and the Versys. Suzuki has more versatility in their 650 category with the 650 Vstrom and DR650 SE. The DR is clearly a dirt-worthy steed and the Vstrom has a pretty substantial following for road -oriented tours.
Kawasaki seemed to go the wrong way with the KLR. I don't know why they would push the KLR toward more road worthiness and introduce the Versys as the same time. They would be better off combining them as you intend to do. A Versys engine in the 2008 frame with a set of 19/17 spoked wheels for $6500 would have my attention. They could even have two models that use the same frame: one with the single cylinder and a twin.
Good luck with the project!
Old 03-18-2008, 10:31 AM   #42
scarysharkface
30-125
scarysharkface's Avatar
Oddometer: 13,273
To make the KLR more dirt-centric they would need to apply the suspension changes of the 2008 to a lighter frame, imho, which would be pretty much a complete re-design. Of course, dropping that Versys engine into a KLR frame might be fun...
The road to Hell is paved...
Save $5 on a Smugmug subscription when you use my coupon:
yBr7OofIPuOP6
scarysharkface is offline   Reply With Quote
Old 03-19-2008, 09:04 AM   #43
tonymorr OP
tonymorr's Avatar
Oddometer: 2,530
Preliminary numbers.....
REAR: A 12" long rear shock (5/8" longer than stock) will raise the rear 1.8" and give approx 6.7" wheel travel compared to the stock 4.9". Chain doesn't look like it will rub on the guide much and everything else LOOKS like it will be ok as far as clearance.
FRONT: Shrortening the WP 4860 forks 2" will still give me 9.8" of travel in the front. I'm going to make one attempt at doing this myself by shortening the spring and installing spacers. (I still don't know exactly what I'm doing inside the forks but I'm a fart smellar) I hear that cutting fork springs increases their force . These forks came off of a 525SX so I'm thinking that they are too soft anyway. If the first attempt doesn't get me close to the sag # I need (2.5"-3") I'll just send them out to a pro shop and let them handle it. I should be able to raise the forks 1.5"~2" in the triple clamps without the 19" tire bottoming out at full compression.
If this all works the way I figure I'll be changing the rake from 25 to 26.5~27 degrees and the trail should fall between 4.0"-4.5"
tonymorr screwed with this post 03-19-2008 at 03:01 PM
Old 03-19-2008, 02:52 PM   #44
intheways
intheways's Avatar
Oddometer: 419
Old 03-22-2008, 08:47 AM   #45
joe a
awryder
joe a's Avatar
Oddometer: 617
OK...........It took me a while but I finally found the thread...
Did last nights beer,wings and pizza help get ya focused...??
The traveler in me is the most loved or most hated quality I possess, depending on who you ask.
joe a is offline   Reply With Quote
Times are GMT -7.   It's 03:55 AM.
