Old 03-22-2008, 08:55 AM   #46
joe a
awryder
joe a's Avatar
Oddometer: 632
So this is what you are gonna do ? Only better ?
When/if you go to test ride the stocker,let me know.
The traveler in me is the most loved or most hated quality I possess, depending on who you ask.
joe a is online now   Reply With Quote
Old 03-23-2008, 06:03 AM   #47
Ko
Observant as never
Ko's Avatar
Oddometer: 1,110
no snowflake ever feels responsible for the avalanche...
Ko is offline   Reply With Quote
Old 03-24-2008, 07:32 AM   #48
EsconDeasy
Ectomorph
EsconDeasy's Avatar
Oddometer: 1,489
Note the wife in the extreme left of the shot, fingers nervously interlaced. "Hopefully, once this MISadventure is over, it'll be out of his system"
Is nothing scared!?
EsconDeasy is offline   Reply With Quote
Old 03-28-2008, 11:59 AM   #49
tonymorr OP
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,511
Stuff to do this weekend.....................
1. I found a KTM triple clamp to use this weekend to see if it will work. I should be able to figure out the stem and bearings as well.
2. I realized that the Vstrom wheel uses a 525 chain whereas the Ninja has a 520 . So, after a little research I found that a 520 conversion sprocket is available for Gixxers and will bolt up to the Vstrom wheel. Pick it up tonight from Marshalls. Over the weekend I hope to machine the rear wheel rotor boss a little to narrow the width. I also need to machine the Vstrom spacers down a little and make a bracket for the caliper.
Things are slowly progressing.
By the way, I found a little trick last night. The front axle on the Ninja takes a 14mm allen wrench. Who has one of them laying around? Ya, neither do I, and neither does Sears. So, I went to Home Depot and and bought a 3/8" threaded rod coupler (2 for $.81). It's 9/16" hex on the outside and about 1.5" long. I stuck it in the hole, put a long handled ratchet on it and blamo, loosey goosey, good to go
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is offline   Reply With Quote
Old 03-30-2008, 08:14 PM   #50
tonymorr OP
tonymorr's Avatar
Oddometer: 2,511
Borrowed a set of KTM triples this weekend to try. Looks like I can make them work but the Vstrom front wheel didn't show up yet so I have to wait for that to see if the width is going to be ok. I just threw a 17" front wheel in there for the pic.
Forks shortened 2" for mockup with nylon straps. Note, it's suspended up in the air right now. Will actually sit much differently when all set up and sitting on the ground.
Old 03-31-2008, 05:57 PM   #51
hunting1
hunting1's Avatar
Oddometer: 289
How did I or my pic get mixxed up in this?
God Bless the USA!
hunting1 is offline   Reply With Quote
Old 03-31-2008, 07:34 PM   #52
tonymorr OP
tonymorr's Avatar
Oddometer: 2,511
I told my freind Joe (Awryders) about my project and I guess he hadn't seen a Versys till he came across your pic here on ADV
Old 03-31-2008, 08:08 PM   #53
DragoSapien
RAD
DragoSapien's Avatar
Oddometer: 88
Hi Hunting1. I meet you in Ft.Stockton at the Dairy Queen. Ill take it you made it back OK.
I cant wait to get me a Versys.
DragoSapien is offline   Reply With Quote
Old 04-01-2008, 05:47 AM   #54
hunting1
hunting1's Avatar
Oddometer: 289
Hey DragoSapien! Small world ha! Made it back and what an AWSOME trip! That entire route is a motorcycle riders dream! Great country, no accidents, sucks to be back at work. Was nice meeting you and hope you get your Happy Trail boxxes! Maybe we can hook up down south for a ride!
Larry
God Bless the USA!
Old 04-01-2008, 06:13 AM   #55
dancolin
Weeeehaaa!
dancolin's Avatar
Oddometer: 1,004
http://picasaweb.google.com/dancolin/TheBikes
06 KTM 950 Adventure
dancolin is offline   Reply With Quote
Old 04-05-2008, 05:28 PM   #56
llamapacker
Mr. Conservative
llamapacker's Avatar
Oddometer: 1,329
TonyMorr,
Got a look at a new wee-strom today at the dealer and the ninja 650r which has the same front wheel as the Versys (I have a Versys).
Looks to me like the 19" wee-strom front wheel is like .200" more narrow at the discs (measured with my hand, not a mike) and the bolt pattern is no good, but who cares, we knew that a hub would have to be machined. It would be nice if the wee's discs were 300mm instead of 310mm, then would only have to add spacers on each side. Must be turned unless there is 5mm slack in the calipers on the Versys, hmmm.
Now, I don't know what obstacles lie ahead in the axle and bearings.
Wish I could get my hands on a used wheel to measure and check tho.
14 KTM 1190 Adventure
14 500xc-w plated
llamapacker screwed with this post 04-05-2008 at 05:47 PM
llamapacker is offline   Reply With Quote
Old 04-05-2008, 05:31 PM   #57
tonymorr OP
tonymorr's Avatar
Oddometer: 2,511
I have a Vstom 1000 wheel on the way. I'll make some comparisons to the Ninja wheel when it arrives.
Old 04-05-2008, 05:44 PM   #58
llamapacker
Mr. Conservative
Oddometer: 1,329
Cool, I will be watching. I just checked the specs on both bikes on the web, both the 650 and 1000 V-strom have a 310mm disc, could turn them to 300mm, add spacers, bingo, fit the versys. Looks when the discs are turned to 300mm some lightening holes will be cut into, so might need to hand mill some scallops (home made pedals). Appears to be enough discs for the brake pads after machineing.
Only thing, the Versys discs are prettier, v-strom are just round.
The axle appears to be same size as Versys (18 mm), got to get my little grubby hands on a wheel soon!
14 500xc-w plated
llamapacker screwed with this post 04-08-2008 at 06:00 PM
Old 04-08-2008, 04:38 PM   #59
LiveFast
LiveFast's Avatar
Oddometer: 357
Hot Damn. Love the idea and how its looking, I got a thing for naked bikes....
Hope that all goes well in your quest (or should i assume its an obsession w this bike already)
I'll be watching, best of luck
Live Fast Take Chances
07 KLR 650
(Red is the fastest color)
Anything that has wheels, an engine, or can go fast....I'm there....
LiveFast is offline   Reply With Quote
Old 04-10-2008, 02:00 PM   #60
Jet Jaguar
King of the poseurs
Jet Jaguar's Avatar
Oddometer: 349
-Jet Jaguar
It's not an adventure unless you need a tent, a passport, and a leather glove for your shooting hand.
'05 Suzuki DL650 V-Strom
Jet Jaguar is offline   Reply With Quote
Times are GMT -7.   It's 07:48 AM.
