07-25-2012, 07:44 AM
#20731 | |
6Sigma Knuckle Shflr
Oddometer: 8,115
Yes!
Stay half-assed, my friends. -- Mike West Bitch, I told you! Until someone is at the pinnacle of their craft, equipment is always...alwayyyys secondary to skill. -- Smart Fooker |
07-25-2012, 08:10 AM
#20732 |
Takin' it Easy
Oddometer: 4,270
Dr Z didnt ytou change front wheel ?
I am trying to get front wheel off my DL1000. Will not move.
I ASSUME you loosen pinch bolts and unthread axel but in which direction - left for loose or is it right handed thread for some strange reason... What tool did you use to get if free. I have a sparkplug sprocket but then what... 1/2 drive extension just spins... frustrated - over an hour to get axel free ???? Any help out there. At least confirm that it unscrews right or left? Thanks
KTM 500 EXC Yellow Vee. A few others in the past You dont quit riding when you get old, you get old when you quit riding. I don't always ride street bikes, but when I do I prefer VStroms |
07-25-2012, 08:35 AM
#20733 |
8 lug oil burner
Oddometer: 9,347
Vic, You can put a pipe wrench on that socket to turn it if you can't get an extension in from the wrong end. I set a socket up in a lathe and machined it so I could put the extension in from either end.. Also if you'r NOT a KLR rider you can buy a tool that fits and has a square drive for a ratchet.
When there is no way out - Find a way further in. 690 DL650 DR350 MMS Edition Past bikes |
07-25-2012, 08:44 AM
#20734 | |
Takin' it Easy
Oddometer: 4,270
My next step is to use a huge pipe wrench (36") but I want to trun it in the correct direction... Man that sucker is in there...
07-25-2012, 09:08 AM
#20735 |
Takin' it Easy
Oddometer: 4,270
Just talked to local dealer. Left hand threads, and should come right off....
I will let you know cause Im fixin to put ass on this thing...
07-25-2012, 10:11 AM
#20736 |
Behind Bars For Life
Oddometer: 117
threads
Technically, "left" & "right" refers to the direction of tightening. 99.9% of what you deal with normally is right hand thread. So Vic the old adage of "lefty loosey, righty tighty" applies here. There is no left hand threads anywhere on your bike.......yours has probably "galled" which typically is due to dissimilar materials. Use never-sieze on reassembly & never suffer this again
Nobody said life would be easy, they just promised it would be worth the ride. |
07-25-2012, 10:15 AM
#20737 | |
Semi-Goodlookin!
Oddometer: 2,629
07-25-2012, 10:42 AM
#20738 |
8 lug oil burner
Oddometer: 9,347
You know you can get 55 gal drums of it on Amazon :buzz
07-25-2012, 10:45 AM
#20739 |
8 lug oil burner
Oddometer: 9,347
Having been in machine work for 20 odd years (and yeah they were pretty odd) ONE thing I know is that there is a proper coating for every thread out there.
07-25-2012, 11:11 AM
#20740 |
Takin' it Easy
Oddometer: 4,270
Done
Ok 24 inch pipe wrench with long cheater bar got is loose.... yea... more ass wins again.
Had to take calipers off to get tire out.... But finally bike is wheel less... Waysheer - you are correct and I mispoke. Right hand threads are normal (lefty loosey - righty tighty) New Perili Scorpions are next with new chain and sprockets and power commander (different map) so we will see what happens... Thanks guys for the support....
07-25-2012, 11:55 AM
#20741 |
Oddometer: 8,115
Glad you got it squared away, Vic.
![]() I haven't taken the front wheel off my Vee yet but I will here shortly. I'm putting on some new rubber, chain, & sprockets.
07-25-2012, 12:00 PM
#20742 | |
Semi-Goodlookin!
Oddometer: 2,629
Did new tires/chains/ sprockets/brake pads on my Wee last Oct. It was a snap. Seems like the Vee would be as easy. |
07-25-2012, 12:04 PM
#20743 | |
Takin' it Easy
Oddometer: 4,270
![]() Hints: loosen pinch bolts Open gap with wedge insert special tool OR find right size spark plug and turn it around. Use pipe wrench of approporiate size and turn lefty to looseeee unthread axel hammer axel through hub remove brake caliper (so tire will clear) lift front end and remove tire snap - took me three hours- four changes of cloths- and a trip to Lowes....
07-25-2012, 12:22 PM
#20744 |
Oddometer: 117
Vic
Sure do like that high-tech air assisted hydraulic comealong chain fall jack thats holding your baby up
07-25-2012, 01:08 PM
#20745 | |
8 lug oil burner
Oddometer: 9,347
