Go Back   ADVrider > Riding > Regional Forums > Central From Da Nort Woods to the Plane States
View Results: .
. 0 0%
. 0 0%
Voters: 0. You may not vote on this poll
Old 09-02-2012, 04:11 PM   #12331
paulie77
Gopher
Oddometer: 17
Keidaish Point Park
Keidaish Point Park -Monroe County Twnshp Rd 419, Clarington, OH
I was not brave enough to ride my bike up the steep grass and rock hill!!! Looking up river at an Aluminum Plant!
paulie77 screwed with this post 09-02-2012 at 04:29 PM
paulie77 is offline   Reply With Quote
Old 09-02-2012, 04:20 PM   #12332
paulie77
Gopher
Oddometer: 17
Next Up
3 digit state route that in is a County named after our 5th President or some lady who sang happy birthday to our 35th President.
Old 09-02-2012, 04:48 PM   #12333
sion
sigh-own
sion's Avatar
Oddometer: 3,654
there are at least 6 3-digit state routes in that county...I think we're gonna need a bit more info
I say, there's no such thing as a bad day's riding. -metaljockey
whats the value of good gear?: http://www.advrider.com/forums/showp...ostcount=49301
sion is online now   Reply With Quote
Old 09-02-2012, 05:06 PM   #12334
paulie77
Gopher
Oddometer: 17
Adds up to 10
Old 09-02-2012, 05:15 PM   #12335
vivid dadas
vivid dadas's Avatar
Oddometer: 865
Option Explicit Function RealEqual(A, B, Optional Epsilon As Double = 0.00000001) RealEqual = Abs(A - B) <= Epsilon End Function Function ExtendRslt(CurrRslt, NewVal, Separator) If CurrRslt = "" Then ExtendRslt = NewVal _ Else ExtendRslt = CurrRslt & Separator & NewVal End Function Sub recursiveMatch(ByVal MaxSoln As Integer, ByVal TargetVal, InArr(), _ ByVal HaveRandomNegatives As Boolean, _ ByVal CurrIdx As Integer, _ ByVal CurrTotal, ByVal Epsilon As Double, _ ByRef Rslt(), ByVal CurrRslt As String, ByVal Separator As String) Dim I As Integer For I = CurrIdx To UBound(InArr) If RealEqual(CurrTotal + InArr(I), TargetVal, Epsilon) Then Rslt(UBound(Rslt)) = (CurrTotal + InArr(I)) _ & Separator & Format(Now(), "hh:mm:ss") _ & Separator & ExtendRslt(CurrRslt, I, Separator) If MaxSoln = 0 Then If UBound(Rslt) Mod 100 = 0 Then Debug.Print "Rslt(" & UBound(Rslt) & ")=" & Rslt(UBound(Rslt)) Else If UBound(Rslt) >= MaxSoln Then Exit Sub End If ReDim Preserve Rslt(UBound(Rslt) + 1) ElseIf IIf(HaveRandomNegatives, False, CurrTotal + InArr(I) > TargetVal + Epsilon) Then ElseIf CurrIdx < UBound(InArr) Then recursiveMatch MaxSoln, TargetVal, InArr(), HaveRandomNegatives, _ I + 1, _ CurrTotal + InArr(I), Epsilon, Rslt(), _ ExtendRslt(CurrRslt, I, Separator), _ Separator If MaxSoln <> 0 Then If UBound(Rslt) >= MaxSoln Then Exit Sub Else 'we've run out of possible elements and we _ still don't have a match End If Next I End Sub Function ArrLen(Arr()) As Integer On Error Resume Next ArrLen = UBound(Arr) - LBound(Arr) + 1 End Function Function checkRandomNegatives(Arr) As Boolean Dim I As Long I = LBound(Arr) Do While Arr(I) < 0 And I < UBound(Arr): I = I + 1: Loop If I = UBound(Arr) Then Exit Function Do While Arr(I) >= 0 And I < UBound(Arr): I = I + 1: Loop checkRandomNegatives = Arr(I) < 0 End Function Sub startSearch() 'The selection should be a single contiguous range in a single column. _ The first cell indicates the number of solutions wanted. Specify zero for all. _ The 2nd cell is the target value. _ The rest of the cells are the values available for matching. _ The output is in the column adjacent to the one containing the input data. If Not TypeOf Selection Is Range Then GoTo ErrXIT If Selection.Areas.Count > 1 Or Selection.Columns.Count > 1 Then GoTo ErrXIT If Selection.Rows.Count < 3 Then GoTo ErrXIT Dim TargetVal, Rslt(), InArr(), StartTime As Date, MaxSoln As Integer, _ HaveRandomNegatives As Boolean StartTime = Now() MaxSoln = Selection.Cells(1).Value TargetVal = Selection.Cells(2).Value InArr = Application.WorksheetFunction.Transpose( _ Selection.Offset(2, 0).Resize(Selection.Rows.Count - 2).Value) HaveRandomNegatives = checkRandomNegatives(InArr) If Not HaveRandomNegatives Then ElseIf MsgBox("At least 1 negative number is present between positive numbers" _ & vbNewLine _ & "It may take a lot longer to search for matches." & vbNewLine _ & "OK to continue else Cancel", vbOKCancel) = vbCancel Then Exit Sub End If ReDim Rslt(0) recursiveMatch MaxSoln, TargetVal, InArr, HaveRandomNegatives, _ LBound(InArr), 0, 0.00000001, _ Rslt, "", ", " Rslt(UBound(Rslt)) = Format(Now, "hh:mm:ss") ReDim Preserve Rslt(UBound(Rslt) + 1) Rslt(UBound(Rslt)) = Format(StartTime, "hh:mm:ss") Selection.Offset(0, 1).Resize(ArrLen(Rslt), 1).Value = _ Application.WorksheetFunction.Transpose(Rslt) Exit Sub ErrXIT: MsgBox "Please select cells in a single column before using this macro" & vbNewLine _ & "The selection should be a single contiguous range in a single column." & vbNewLine _ & "The first cell indicates the number of solutions wanted. Specify zero for all." & vbNewLine _ & "The 2nd cell is the target value." & vbNewLine _ & "The rest of the cells are the values available for matching." & vbNewLine _ & "The output is in the column adjacent to the one containing the input data." End Sub
"Five stinking radicals in a three cylinder Saab!"
vivid dadas is offline   Reply With Quote
Old 09-02-2012, 05:18 PM   #12336
bikeridermark
Oddometer: 2,387
Quite a mouthful, there, vivid! Does that add up to ten?
bikeridermark is offline   Reply With Quote
Old 09-02-2012, 05:21 PM   #12337
vivid dadas
Oddometer: 865
Supposed to be the Excel macro that finds a combination of numbers that equals a given sum.
Old 09-02-2012, 06:36 PM   #12338
jimjim
Just another FF!
jimjim's Avatar
Oddometer: 1,770
Thanks but I think I'll just get the map out.
jimjim is offline   Reply With Quote
Old 09-02-2012, 06:59 PM   #12339
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 11,072
"Nerd alert!!!!!!!!!!!!!!!!"
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 09-02-2012, 07:09 PM   #12340
vivid dadas
Oddometer: 865
It's not my tag, (even though I was "tagging" along,) so I can't really give a hint. I know where it is, so I'll refrain from tagging it. I will observe that 1+4+5 =10, but I also think this tag isn't in a county with the same name as someone well known for singing "Happy Birthday Mr President" to JFK unless there's a singer named Noble who later married Joe DiMaggio that I don't know about.
Old 09-03-2012, 06:02 AM   #12341
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 11,072
SR 145 in Noble County, named after President Noble. His greatest achievement, as we all know, was restarting the reactor on Mars, giving free air to it's long oppressed people.
MeefZah screwed with this post 09-03-2012 at 06:09 AM
Old 09-03-2012, 06:17 AM   #12342
bikeridermark
Oddometer: 2,387
Is he the one that sang Happy Birthday to Marilyn?
Old 09-03-2012, 06:20 AM   #12343
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 11,072
Next up is this sign, on a 3 digit state route, near an unincorporated community whose name always makes me think of an orgasm. No, not Elizabethberkleyville. It's also right across a county road from a cemetery.
Old 09-03-2012, 06:24 AM   #12344
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 11,072
That was "Pimp" Rufus Noble, officially no relation; though historians have long surmised that President Noble banged Rufus's slave great grandmother on his plantation, Mt. Bernon, thus siring a second family that was half black and all awesome.
Old 09-03-2012, 06:32 AM   #12345
McTacticool
Importer/Exporter
McTacticool's Avatar
Oddometer: 254
I thought President Noble, and Vice President Muskingum, established "THE BUSINESS THEORY WHICH EXPLAINS THAT BUSINESSES CAN'T GIVE MERCHANDISE AWAY, AND THAT PEOPLE NEGATIVELY AFFECT THE ECONOMIC CONTRACT PRESUMED BY THE BUSINESS BY (PEOPLE) TRYING TO TAKE STORE ITEMS WITHOUT RECIPROCATING BY GIVING THE BUSINESS THE FAIR MARKET VALUE OF SAID ITEMS."
No?
McTacticool is offline   Reply With Quote
Times are GMT -7.   It's 08:56 PM.
