03-15-2008, 01:14 PM
#1 |
Oddometer: 303
Garmin Nuvi 250W Mounted on V-Strom
After much debate, I decided to skip the refurb 2610 and went with a refurb 250W ($177 shipped) instead. I wanted a mapping unit that could do truck, bike, and foot so the lack of battery (and sheer size) of the 2610 took it out of consideration. I know the 2610 does routes and is waterproof. The Nuvi can't and is not.
For some crazy reason, the 250W is cheaper than the regular 200, even though it has a better mapset (full North America) and a much better screen. I got the original idea for this mount from ib, who mounted his Zumo in a very similar way. (http://11109.rapidforum.com/topic=109571797182). View his thread for more detail into the initial prep. This week RAM released a new cradle for the Nuvi's, so I bought the "Brake/Reservoir" mounting kit ( RAM-B-174-GA25U). It comes with everything you need, plus you get the "long" RAM arm rather than the short one that comes with the Zumo kit ib used. I have both arms, and like the long one much better (IMO) as it provides more installation/removal room, installation spots, and places the GPS closer to the rider. First off, I prepped my windshield mount by clipping off the "waffling" with a set of 45 degree dikes. This took about 3 minutes. (Click photos for larger versions) ![]() I clipped out the entire middle section of the mount to allow for the use of washers on the backside. ![]() Then I bolted on the mount included in the kit using nylon lined stop nuts, and used 2 rubber washers to isolate the RAM mount from the widshield mount. http://strom.selfip.net/Fotke/albums...O/IMG_5725.jpg is what it looks like afterwards (photo credit ib). This process took about 10 minutes, including a break for: ![]() Now all that is left to do is attach the Nuvi RAM cradle and RAM arm from the kit and you end up with a setup that looks like this: From the riders position: ![]() From the side: ![]() In use: ![]() Zoomed: ![]() I took it for a quick romp and noticed no vibration of the screen on paved roads. Enjoy! |
03-15-2008, 01:56 PM
#2 |
Oddometer: 4,738
Nice work! I was usig my Nuvi before I got a Zumo, and it worked out well. The 250W is a bargain. I had the 2610, 2720, and 2820 and feel the 250W is a better in any number of ways.
Theft of GPS units is skyrocketing, so take it with you!
2009 DL650A, 2008 Tiger 1050 ABS, 1994 XR100R |
03-15-2008, 03:23 PM
#3 |
Oddometer: 178
I run a NUVI 760 on my RT mounted in a similar manner. The 760 has FM transmit so I can get the voice prompts through the radio on the RT. I find the Nuvi a much better proposition than the Zumo, screen size for price, Mapsource adaptive and so on.
03-15-2008, 03:58 PM
#4 |
Oddometer: 10,901
Nice work! I went with a zumo as I ride probably as often as not in rain and otherwise messy conditions but that is a nice instal.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038 Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703 |
03-15-2008, 08:20 PM
#5 |
Daily Adventurer
Oddometer: 205
Nice work man!
Will |
03-16-2008, 05:25 AM
#6 | |
Oddometer: 4,738
There's one annoyance with the 760 for bike use. If you've selected a route, it does not show your speed on the front screen. It does show it if no route has been selected, or if you touch the lower left hand corner to bring up the trip data. But given the optimistic speedometers on virtually all motorcycles, it's an annoyance. They both share one shortcoming relative to the 2610: the front screen display cannot be customized to your needs. The Zumo and Nuvi both have the high-sensitivity receiver, recalculate faster, have higher resolution screens, an internal battery, and come pre-loaded with maps. But being able to change what was displayed on the front screen (for example, speed, heading, and elevation) was great. This information can still be accessed on the new models, but not continuously or in one place. Nontheless, if I had to choose a budget GPS, I'd pick the 250 or 250W as well in lieu of the 2610.
2009 DL650A, 2008 Tiger 1050 ABS, 1994 XR100R garandman screwed with this post 03-16-2008 at 05:46 AM |
03-18-2008, 10:11 AM
#7 |
Oddometer: 4,738
Got an email so I'll post some random info:
1. There are two new models - 255 and 255W - due out any time that are worth looking into. 2. You can buy the 250W for less than $200 on eBAY, YMMV. 3. Not sure about the 250W but on the 360, 660 and 760, you cannot change the size of the text displayed on the map as a parameter, although you can change the level of detail. 4. Another feature that Nuvis have that's not on the 2610: GarminLock. This is a number code to prevent use of the device without keying in the 4 digit code first. It can be broken by brute force or a lucky guess - it's only four digits after all. But if you get ripped off, you at least have some satisfaction in knowing they can't use it. 5. The Nuvi 760 will optimize a route with multiple destinations. Most of the old StreetPilot 2xx0 series will do this as well, as do the Zumos. Most lower-cost Nuvis will not: you can only add 1 via point to the destination.
03-18-2008, 11:06 AM
#8 | |
Oddometer: 303
https://buy.garmin.com/shop/compare....ompare=compare I got my refurb 250W for $177 shipped free from Amazon (DigitechDeals). Anyone buying one now may want to hold off registering it until the new City Nav becomes available. You SHOULD be eligible for a free map upgrade. |
03-18-2008, 11:33 AM
#9 | |
Oddometer: 4,738
03-18-2008, 01:26 PM
#10 | |
Oddometer: 303
08-10-2008, 06:18 AM
#11 | |||
Oddometer: 4,738
But when you go to "In the box," you learn that the 500: Quote:
08-10-2008, 09:36 AM
#12 |
Curmudgeonly
Oddometer: 8,793
Nice, I've been thinking about getting a RAM mount for my Nuvi 200, now I think I will.
Go forth, wander aimlessly, explore, have adventures and shit... |
09-08-2008, 01:27 PM
#13 |
Oddometer: 17
Ram Waterproof Mounts
You may want to check out these handy little devices.
http://www.ram-mount.com/aqua_box_mo...wide_mount.htm Supposed to keep your Nuvi dry and still allow you to mount it to your bike and use the touch screen. |
09-08-2008, 10:12 PM
#14 |
Oddometer: 88
Nice setup, you just held off my refurb 2720 purchase. So many options, so little $$$...
DL650AK8 |
09-09-2008, 07:11 AM
#15 |
Oddometer: 29
I did not think the low level nuvi would do multiple way points and let you plan out routes. I bought the 200 for the wifes car and its just a point a to point b type of device.
Prothos screwed with this post 09-09-2008 at 07:16 AM |
