Old 01-23-2013, 10:40 AM   #811
christian
Exchange your GPS Track!
christian's Avatar
Oddometer: 2,600
Originally Posted by Ian B View Post
Yes to February, but the fairings are likely to be ready to go before the new harnesses are here. So, people who are getting the power sockets will get the new wiring harness and may have to wait until the end of feb, whereas those who aren't, will be getting the fairings in the next couple of weeks.
Thanks -
side question, would a KTM 690 fairing work on a KTM 640 Enduro?
Reasoning being, I have a 640Enduro and planning to upgrade to a KTM 690
I wouldn't mind getting the 690 fairing and use it on my 640E, and when the 690E comes to me, swap the fairing.
Any chances you have the KTM 690 fairing mounting point pictures?
Yamaha Majesty '08
KTM 690 Enduro '10
christian is offline   Reply With Quote
Old 01-23-2013, 11:31 AM   #812
Harty
Bloody Good Bloke!
Harty's Avatar
Oddometer: 182
Originally Posted by christian View Post
Great pictures, thank you!
1- Any reason you have the cycra handguards "curve" below the clutch/brake cable instead the normal "above" position? is it due to the Lynx fairing? or personal choice?
2- Doesn't the brake cable bumps into the Montana when riding and the fork compresses?
3- for the 12v plug - wouldn't the male connector for your device interfere with the brake cable?
Thank you
Christian
Hi Christian
1. Congraulations you won!! Bit of a 'balls up' on my part there!! Now rectified
2. Nope it doesn't actually move, but I am going fix some rubber hose on the brake line, just in case
3. It's a 12v double usb charger for my iphone and compressor, so the usb plug is very small in comparison to a 12v plug
Cheers
Harty
I'll get me coat..............
2011 KTM 690
Harty is offline   Reply With Quote
Old 01-23-2013, 12:25 PM   #813
christian
christian's Avatar
Oddometer: 2,600
really? even when you compress the suspension? like jumps and stuff.
it's got to be moving... I ask because I had the issue the brake line was catching the GPS in some weirdo time.
Nice - I need one of these...
Yamaha Majesty '08
KTM 690 Enduro '10
Old 01-23-2013, 01:06 PM   #814
Ian B OP
Fairing Manufacturer
Oddometer: 482
Thanks -
Yes, The 690 fairing ( both existing and new Lynx ) are completely the same as the 640.
No photos yet of the fastening points for the new one. Email me if you want the installation instructions ( britanniacomposites@shaw.ca )on the existing one, although it's a bit irelavent if your looking at the new one, because it fits differently at the bottom. There's no cutting or permanent alteration to either bike.
www.britanniacomposites.com
Ian B is offline   Reply With Quote
Old 01-23-2013, 01:17 PM   #815
christian
christian's Avatar
Oddometer: 2,600
email sent - thank you
Yamaha Majesty '08
KTM 690 Enduro '10
Old 01-24-2013, 09:31 AM   #816
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 6,093
Any chance of getting a side by side pic of the new vs the old fairing?
Yellow Pig is online now   Reply With Quote
Old 01-30-2013, 11:33 PM   #817
jaywoo
jaywoo's Avatar
Oddometer: 21
I've had the globe go on the low beam HID unit, the markings on it, "A1DA HID 35W" aren't bringing up a globe spec on the internet so I can replace it. Anyone on here know where I can get one?
jaywoo is offline   Reply With Quote
Old 02-11-2013, 03:02 PM   #818
Ian B OP
Oddometer: 482
New Lynx ready to go !!
Well, it's been a long time and a lot of work, considering how similar the new Lynx looks to the original ! but by the time I was finished, there wasn't a single surface that remained the same !
Here are some shots of it in different colours, but none mounted to a real bike yet.
The fairings will start to go out to the guys who have them backordered this week. Although the website still shows the older version, all colour choices, decals, light spec etc remain the same as does the Price, so ordering can still be done from the website. The only additional items on the new Lynx is the optional stone guard ( $38) and the choice of clear or tinted screen.
Hope you like it !
Cheers
Ian
Ian B screwed with this post 02-11-2013 at 03:28 PM
Old 02-11-2013, 04:25 PM   #819
Kainic
Almost there
Kainic's Avatar
Oddometer: 308
Hope you like it !
Cheers
Ian
Looks good!
Any word on new 2 headlight fairing for the f650gs single?
Kainic is offline   Reply With Quote
Old 02-11-2013, 05:16 PM   #820
Ian B OP
Oddometer: 482
Originally Posted by Kainic View Post
Looks good!
Still looking for a bike to use, but it will definitely be a version of this fairing.
Old 02-12-2013, 06:39 AM   #821
Mr. Fisherman
oneandahalfassed
Mr. Fisherman's Avatar
Oddometer: 9,841
Looking good! Is there any way to mount that stone guard to the old version?
Mr. Fisherman is offline   Reply With Quote
Old 02-12-2013, 08:07 AM   #822
AustinJake
TE450-KLE-FXDWG
AustinJake's Avatar
Oddometer: 2,793
My older generic does not have as flat a middle divider as that new looks to have.
____________________________________
Get fit. Stay safe. Enjoy life. Learn something to help someone in need.
AustinJake is offline   Reply With Quote
Old 02-12-2013, 09:09 AM   #823
Ian B OP
Oddometer: 482
Wish I had 10 bucks for every time I've been asked this this week !!
I haven't figured out how yet, but that's mainly because I haven't had time to think it through. There's no doubt it could be made to fit, but I think you would need to be the 'handy' type. One of the main issues is how to make it reasonably easy to remove if needed. AS you can see, I've used threaded inserts, so it's easy to remove, but without them it would be difficult to keep accessing the back of the fairing.
Cheers Ian
Old 02-16-2013, 12:01 PM   #824
jwnsc
Hang in there.
jwnsc's Avatar
Oddometer: 317
Headlight protectors
Are the self-adhesive 80mm Lamin-X covers with the 20mil thick clear Vinyl still available?
Any particular reason for offering the metal grid? It reminds me of the one I had on my Uly headlight - great for "asteroids," not so much for "meteors!"
Were there many breakages or other problems with the Lamin-X covers
protectors?
An email sent regarding questions on an order. Will also PM.
"The traveler sees what he sees, the tourist sees
what he has come to see." G.K. Chesterton
"Travel is fatal to prejudice, bigotry, and narrow-
mindedness." Mark Twain
jwnsc is offline   Reply With Quote
Old 02-16-2013, 12:40 PM   #825
Ian B OP
Oddometer: 482
protectors?
Yes, the vinyl protectors ( actually now 40 ml ) are still an option and they have been very effective. We have been asked many times for a grill option and I think it's very much a 'looks' thing and you are quite right, a small stone can find it's way through and still hit the glass lens, but a large stone might defeat the vinyl protectors.
So, my view is that the vinyl protectors still do the job well and the rock guard is a visual addition. To give you some idea of the feedback, there are now 40 Lynx's on order and all but 2 have ordered the rock guards.
Cheers Ian
Times are GMT -7.   It's 12:26 PM.
