Old 03-31-2008, 04:45 PM   #106
B.C.Biker
mighty fine
Oddometer: 622
Like the idea of juntion/fuse box installed = less cluter.
B.C.Biker is offline   Reply With Quote
Old 03-31-2008, 05:56 PM   #107
JAFO
displaced Jeep guy.....
JAFO's Avatar
Oddometer: 3,975
Originally Posted by Ian B
The OEM lights are wired from the battery via the ignition. The battery will have no problem powering the lights, but more to the point, can the alternator keep up with charging the battery. This is likely to be an issue of usage. Although these new H7 bulbs draw 65w, the existing setup will hardly notice the difference. However, if you're riding on High beam as well for extended periods, along with heated grips and vest, then there may be an issue. We are doing tests on this now.
In any event, it's better to leave the existing wiring alone (it has a dubious reputation at best !) and run good quality 12 guage separately for any significant increase on demand.
Why not run either/or? Low or high? This would avoid problems with the extra draw on the system. Also, allow you to use the stock wiring to trigger relays.
I'd sugget folks looking at a stator upgrade think long and hard about it. Seen lots of negatives regarding the electrosport version, right here....
JAFO is online now   Reply With Quote
Old 03-31-2008, 06:32 PM   #108
Ian B OP
Fairing Manufacturer
Oddometer: 590
Mmm, that's not a bad idea to run either/ or .
We'll try that, but I have a feeling that with the low 'off', it could be a bit dark directly in front of you and to the sides. The low is a projector type that gives a very sharp cutoff line, with loads of light below and darkness above. The high seems to fill in that darkness above. We'll see - thanks
Ian
Ian B is offline   Reply With Quote
Old 03-31-2008, 06:56 PM   #109
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,613
I plan on a stator up grade, after this riding season. I just ran out of time and money this winter.
johnwesley is offline   Reply With Quote
Old 03-31-2008, 07:21 PM   #110
Pangeist
Autodidact Polymath
Pangeist's Avatar
Oddometer: 165
Eek Love it all Ian!
I like it all. Any option over the stock set up is awesome. The twin headlight version is definitely going on my KLR. Awesome job. Can't wait!
Our days of plenty are numbered.
Pangeist screwed with this post 03-31-2008 at 07:29 PM
Pangeist is offline   Reply With Quote
Old 03-31-2008, 08:02 PM   #111
Hoder
Card carrying greeny
Hoder's Avatar
Oddometer: 1,019
Your fairing looks awsome! I just might have to sell the 950 parts.
See my pics
Dave:
The 610 really makes me want to ride like a punk everywhere I go.
bikefrk:
You now understand supermoto.
Your training is complete.
Hoder is offline   Reply With Quote
Old 03-31-2008, 08:49 PM   #112
Ian B OP
Oddometer: 590
A friend of mine is looking for some used 950 tanks, so if you do decide to sell them, you've got a buyer ! I think this fairing looks better on my 610 than on the KLR. Just a few mods and it'll go straight on. I'll post up some 'mock up' pictures on the TE610 thread as soon as we get a white one out of the new molds.
Thanks for the comments !!
Ian
Old 04-01-2008, 04:45 PM   #113
DirtyDog
Lust for dust.
DirtyDog's Avatar
Oddometer: 7,949
Ian- when you get a chance, can you show a pic of the dual headlights mounted from the underside/backside of the fairing? You're using the same mounting holes as the stocker, I assume.
"This place fucking runs on beer, you buy the right person a beer, and you get a job, a blow, a place to sleep, whatever.
You're hot, cold, thirsty, hungry... beer will fix that.
Beer is a god damn miracle, and don't you forget it!"
-DustyRags
DirtyDog is offline   Reply With Quote
Old 04-01-2008, 05:33 PM   #114
JAFO
JAFO's Avatar
Oddometer: 3,975
I'd like to see more pics, too. Including from the riding position, large sidelong shot, etc.. :)
MORE PORN!!! Please? :)
Old 04-01-2008, 07:05 PM   #115
Ian B OP
Oddometer: 590
No, fitting to the stock frame doesn't work out. The lights mount inside the fairing. They attach via 3 threaded rod adjusters (each with a thumbscrew) that allows you to adjust each light in all directions. It's a bit difficult to explain, so I'll take some pics when I get the chance.
To create the room inside the fairing, the existing light is removed from it's 2 pivot points on the frame. It's very tight !
Old 04-01-2008, 07:09 PM   #116
Ian B OP
Oddometer: 590
The view from the riding position is identical on all three versions of the fairing. You can see the view ( including the two dash's) earlier in this thread
Old 04-03-2008, 06:20 AM   #117
Bikerjosh
I was punk once.
Oddometer: 166
Awesome Job!
Great job IanB. Looks like I'm going to have to start listing some vintage mountain bike stuff on ebay.
Josh
Bikerjosh is offline   Reply With Quote
Old 04-03-2008, 07:41 AM   #118
R_W
wannabe
R_W's Avatar
Oddometer: 4,126
WOW
On the dual HELLA's, it wouldn't be too hard to make them selectable between either or a low always on--one switch or jumper in the wiring harness. If you include a fuseblock (like the Hella 4 or 6-position one) and a ground block, you have a real complete rally-prepped package.
That price is looking pretty good, I was about to spend about half that just on aux lights.
Red hair and black leather, my favorite color scheme...
R_W is offline   Reply With Quote
Old 04-03-2008, 08:03 AM   #119
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,563
I'll be doing full reviews on both of the 2 headlight fairings- shooting for a late June publishing date.
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 04-03-2008, 08:29 AM   #120
NomadRip
Always a n00b
NomadRip's Avatar
Oddometer: 3,366
OK, as promised, here are pics of the one we're testing. This is the 'model' (which is made of fibreglass, plywood, metal and filler !!) and will now be used to make the split molds in order to produce them. There are still some minor 'tweeks' to do, but largely this is it.
That looks MUCH better!
-James
"We are adventure riders. The needs are pretty simple. Bring what you need, share what you've got." -cRAsH
Save 20% when you sign up to the best photo hosting site around: SmugMug!
NomadRip is offline   Reply With Quote
Times are GMT -7.   It's 11:14 AM.
