Old 04-03-2008, 09:45 AM   #121
kanur
cu new er
kanur's Avatar
Oddometer: 744
Ian, Your products look fantastic.
How about putting the Yamaha XT 225 on the to do list.
kanur is offline   Reply With Quote
Old 04-03-2008, 11:02 AM   #122
Kinsman
Ribs....for her pleasure
Kinsman's Avatar
Oddometer: 4,113
XRL owners would probably be interested as well.
Chris R
Schreckendgust Field, Montana
Kinsman is online now   Reply With Quote
Old 04-03-2008, 04:41 PM   #123
kewlcat
Mr.
Oddometer: 43
Looks good Ian, any tips on how to attempt some thing like this for myself?
07 G650 Xchallenge
kewlcat is offline   Reply With Quote
Old 04-04-2008, 08:38 AM   #124
Ian B OP
Fairing Manufacturer
Oddometer: 590
Originally Posted by R_W
WOW
On the dual HELLA's, it wouldn't be too hard to make them selectable between either or a low always on--one switch or jumper in the wiring harness. If you include a fuseblock (like the Hella 4 or 6-position one) and a ground block, you have a real complete rally-prepped package.
That price is looking pretty good, I was about to spend about half that just on aux lights.
You're right, there's a number of light switching combinations but I have a feeling that having low on all the time may be a DOT requirement. I'm not sure on this. I'm hoping that we find a good (and economical) HID solution for the projector low beam - that should solve all the electrical issues.
Dual light XS is coming along, but won't be done by this weekend.
Ian B is offline   Reply With Quote
Old 04-04-2008, 08:52 AM   #125
Ian B OP
Oddometer: 590
It's a lot of work to do a nicely finished job for just yourself, so you have to decide at the outset, whether your project is just a one off, or with production in mind. If you aren't in the composite business, it can be very difficult using the products (and even dangerous !)
If you want to have a go (and you have a fair amount of time), I would start by reading up as much as you can on using composites and mold making (Google) and go from there. Please feel free to pm me anytime for guidance on specifics britanniacomposites@shaw.ca
Ian
PS. A good freind of mine is nagging us to do something with the X Challenge, so I spent a bit of time looking at the posibility of a smallish fairing that also incorporated a 3 litre gas tank in it as well. That would be different !!
Old 04-04-2008, 08:58 AM   #126
Ian B OP
Oddometer: 590
Yep, we're lining up an XLR, TE610 ,X-Chalenge and a 640 KTM to see if there's enough common ground and interest to get the subframes designed to take a new design (that also uses a slide-away screen) using the same (or similar ) lights.
Old 04-04-2008, 08:59 AM   #127
Ian B OP
Oddometer: 590
Added !
Old 04-04-2008, 09:03 AM   #128
Ruffus
Dirty Old Mudder
Ruffus's Avatar
Oddometer: 4,084
Originally Posted by Ian B
You're right, there's a number of light switching combinations but I have a feeling that having low on all thetime may be a DOT requirement. I'm not sure on this. I'm hoping that we find a good (and economical) HID solution for the projector low beam - that should solve all the electrical issues.
I don't think so, many dual light systems have one on at the time, even in cages, it's one or the other, but for cages, kits are available to convert to both being on at the same time. My Buell setup is one or the other. I'm pretty sure even on single light setup, you either have high beam, or low beam, not both at the same time
We spend our lives chipping away at our ignorance :wisdom by Dakez
Friendship is like peeing your pants, everyone can see it, but only you
can feel the true warmth.: wisdom by ??
Reverse Darwinism...he's only alive because he's to stupid to die. : wisdom by AZRamjet
06 Husky TE510
Ruffus is online now   Reply With Quote
Old 04-04-2008, 09:36 AM   #129
JAFO
displaced Jeep guy.....
JAFO's Avatar
Oddometer: 3,975
Low on all the time is not a req.
My KLR doesn't have the low on al the time, neither do any of my cages, all of which use high/low beams.
JAFO is online now   Reply With Quote
Old 04-04-2008, 09:49 AM   #130
humvee
humvee's Avatar
Oddometer: 1,655
Daytime Running Lights are mandatory here though.
"Explore an unpaved road with a new friend" - Fortune Cookie, September 30, 2013
humvee is online now   Reply With Quote
Old 04-04-2008, 10:04 AM   #131
JAFO
JAFO's Avatar
Oddometer: 3,975
here too, unless your vehicle is old enough.
My KLR is old enough.
I think the bigger issue, though, is the liine of demarcation between high and low beam, as you mentioned earlier.
Old 04-04-2008, 12:18 PM   #132
kewlcat
Mr.
Oddometer: 43
Ian
Thanks! I was thinking to do some thing for my xchallenge the touratech fairing is nice but WAY to pricy for me (real shitty exchange rate) please post your ideas for the X!
07 G650 Xchallenge
Old 04-04-2008, 08:11 PM   #133
Meatwad
NimRod
Meatwad's Avatar
Oddometer: 100
BRAVO!!
Just what I've been waiting for (& it looks like a perfect color match for my 2001)
Meatwad is offline   Reply With Quote
Old 04-06-2008, 01:58 PM   #134
Ian B OP
Oddometer: 590
Originally Posted by Meatwad
BRAVO!!
All of the OEM colours are available for the KLR and you're right, the colour of the prototype shown, is a match for the 01 Olive green (withouth the fading !!)
Old 04-11-2008, 03:26 AM   #135
JAFO
JAFO's Avatar
Oddometer: 3,975
new pics of the other version??
Times are GMT -7.   It's 07:53 AM.
