Old 04-15-2009, 08:34 PM   #1561
Jeff@TheQuadShop
TAT survivor
Jeff@TheQuadShop's Avatar
Oddometer: 4,658
Originally Posted by ArthDuro
I will keep you posted, maybe September
did you find a new NX yet?
I'm not really looking for one right now, I have the TA. I'd like to have another NX some day.
1998 RMX 250 singletrack bike
1999 DR350SEX Dual Sport bike
1996 XR600R adventure bike
KY state Vet A offroad champion
TAT, KAT and TWVT survivor
Jeff@TheQuadShop is offline   Reply With Quote
Old 04-15-2009, 09:24 PM   #1562
RogerThat
Old Guy Adventure Videos
RogerThat's Avatar
Oddometer: 159
Lift Table
Originally Posted by lvdukerider
That makes a really nice bike lift. What was it actually designed for?
It came from a wire shop. It was used to lift roles of wire in to a nail machine.
Roger
Simple solutions to complex problems will not be allowed.
RogerThat is offline   Reply With Quote
Old 04-15-2009, 09:28 PM   #1563
IheartmyNx
Ihave2draft
IheartmyNx's Avatar
Oddometer: 3,858
I don't know if they go that high, but I've seen something like that at Harbor Freight.
I was thinking about using it as a transmission jack for my 4WDs a long time ago...
Everyday IS 3/11!
Everybody's always talking out the side of their mouths about our "dependency on foreign oil", what about our dependency on cheap china crap? Who exactly again is killing our dollar?
IheartmyNx is offline   Reply With Quote
Old 04-16-2009, 10:46 AM   #1564
valvecrusher OP
tractus pro pensio™
valvecrusher's Avatar
Oddometer: 1,719
sent you a pm, I myNX
RogerThat, I sure would like to hang out with you for a while, I'm sure i would learn alot about darn near everything.
Please keep up the great work!
What did my NX do today?
"It rusted."
No photos, it was too graphic.
The tag expired. I blame, um....i'll find someone.
valvecrusher screwed with this post 04-16-2009 at 10:53 AM
valvecrusher is offline   Reply With Quote
Old 04-16-2009, 05:47 PM   #1565
RogerThat
RogerThat's Avatar
Oddometer: 159
Me and the NX went out and about.
VC I would love to spend some time with you and your rusting NX. I now a real neet way to remove rust.
I had some time this morning before I had to get ready for work so me and it took a little ride. The snow is moving up the mountian but not all that fast.
This at the snow park on FS70 they ran the grader down the road to make it some smoother for the sleds. It is 7 miles to where the snowmobilers really start having fun.
It was even sunny and 60 degs.
Nice ride.
Roger
Old 04-16-2009, 06:09 PM   #1566
dhw1179
Oddometer: 47
Question Master Cylinder rebuild
Working on rebuilding my master cylinder in hopes of correcting the spongy front brakes. Rebuild kit, check. Rubber boot off, check. C clip out, check. Washer and master piston out, Houston we have a problem. I cannot get the washer and master piston to come out for anything. Anyone else run into this problem? Have a possible solution? I've soaked it in brake cleaner, WD-40, PB Blaster, all to no avail. I'm tempted to order the aftermarket one on ebay, but would really like to get my bike going sooner than that. Any ideas?
DHW1179
Floyds Knobs, IN
dhw1179 is online now   Reply With Quote
Old 04-16-2009, 06:57 PM   #1567
drexNX
Oddometer: 81
ow ow ow.
NX250s do not like jumping off steps, for future reference.
drexNX is offline   Reply With Quote
Old 04-16-2009, 06:58 PM   #1568
IheartmyNx
Ihave2draft
IheartmyNx's Avatar
Oddometer: 3,858
DUDE!!! I just put some new brakes on and guess what? Same deal. Spongy as all get out! I tried cleaning the disc, and no go.
All I did was push the pistons back in....????
Wonder if it's the brake pads themselves?
I've got (stupid me) Parts Unlimited. What do you have?
I will replace them ASAP with Honda brakes...
This is weird! My speedo broke...then three others did too. Alright, who's the jinx?
Everyday IS 3/11!
Old 04-16-2009, 09:03 PM   #1569
dhw1179
Oddometer: 47
I got EBC Carbon X Pads from bikebandit.com. Once I got into my master cylinder, I could tell why they were spongy. It was all gunked up and barely pushing any fluid. I'm sure once I get it rebuilt or get a new once, they'll have no problem throwing me over the handlebars. I doubt its your pads. Gotta push the piston in to replace them, could have gotten some air in the system. If you've bled them and are in the same situation, you probably have the same problem I do. Though I did read something about old brake lines swelling...
My speedo was broke when I got my bike. Previous owner had replaced the cable, but the plastic gear had stripped out. Quick and easy fix. I'm guessing the cable gets tight or locks up and causes all the teeth on the gear to shear. Seeing that it's only plastic wouldn't take much. Only thing I can think of that would cause it.
DHW1179
Floyds Knobs, IN
Old 04-16-2009, 10:02 PM   #1570
ArthDuro
quarantined
ArthDuro's Avatar
Oddometer: 3,040
spongy brake feel =
dirty brake oil
worn pads
warped discs
but most likely
bubbly brake oil or old swelling brake lines
my mini ride reports
"parts made of unobtanium"
ArthDuro is offline   Reply With Quote
Old 04-16-2009, 10:10 PM   #1571
IheartmyNx
Ihave2draft
IheartmyNx's Avatar
Oddometer: 3,858
Maybe mine didn't like the regurgitation it got from me pushing the pistons back in?
As soon as I grabbed the brake, it was flat...I had to pump it like I was bleeding it.
Gonna do a fluid replacement ASAP to.
Everyday IS 3/11!
Old 04-16-2009, 10:54 PM   #1572
ArthDuro
quarantined
ArthDuro's Avatar
Oddometer: 3,040
Originally Posted by RogerThat
that is an awesome shot btw!
Old 04-16-2009, 11:02 PM   #1573
ArthDuro
quarantined
ArthDuro's Avatar
Oddometer: 3,040
That most definitely sounds like there might be air in there to me.
Give it a good through bleed, and be generous with the fluid, make sure you cycle all the bad stuff out and thensome for cleaning.
I would not stop til the fluid in the master looks as clean as it did when it came out of the bottle. Also shake and vibrate (kinda like short quick grabs) the brake handle a bit to release bubbles that might float right up to the valve. Bleeding from bottom up solves this but is less convenient to do and could be messier too.
The other guys have waaaay more experience with this then me.
They will chime in I am sure.
Old 04-17-2009, 12:24 PM   #1574
racingwoody
racingwoody's Avatar
Oddometer: 353
Yes, anytime you push the piston back into the caliper your brakes do not like it. A better and easier way to do it is to open the bleeder valve and then push the piston back into the caliper, it will flush the fluid as well as make pushing the piston in very, very, easy. Your pads will not give you a squishy feel or your rotor even if warped, all warped does is give you a vibration.
Replace the old rubber squishy hoses that expand with pressure rather then transfer the pressure to the pad as well as bleed the air out of your lines to get rid of squishy brakes.
Woody
1989 Honda NX250
CHEERS!
racingwoody is offline   Reply With Quote
Old 04-19-2009, 05:53 PM   #1575
drexNX
Oddometer: 81
stock shock blew, this one... doesn't.
Times are GMT -7.   It's 02:08 PM.
